[ Upstream commit 1b377924841df1e13ab5b225be3a83f807a92b52 ]
Trats2 uses gpf2-1 as the panel reset GPIO. gpy4-5 was only used
on early revisions of the board.
Fixes: 420ae8451a22 ("ARM: dts: exynos4412-trats2: add panel node")
Signed-off-by: Simon Shields <simon@lineageos.org>
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
dwmmc driver deprecated num-slots and plan to get rid
of it finally. Just move a step to cleanup it from DT.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
The OF graph is not needed because the panel is a child of dsi. Remove
the ports node in DSI node, and port node in panel node.
Signed-off-by: Hoegeun Kwon <hoegeun.kwon@samsung.com>
Reviewed-by: Andrzej Hajda <a.hajda@samsung.com>
Reviewed-by: Andi Shyti <andi.shyti@samsung.com>
sources
Replace hard-coded values of interrupt flags with respective macros from
header to increase code readability.
Suggested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Add the burst and esc clock frequency properties to the parent (DSI node).
Currently the clock is parsed from the port node, while it should be
taken from the dsi node.
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
The skeleton.dtsi file was removed in ARM64 for different reasons as
explained in commit ("3ebee5a2e141 arm64: dts: kill skeleton.dtsi").
These also applies to ARM and it will also allow to get rid of the
following DTC warnings in the future:
The disassembled DTB are almost the same besides an empty chosen
node being removed and nodes reordered, so it should not have
functional changes.
As Murata Manufactures the NTC based thermistors. The vendor
name in the compatibility is preposed to change to "murata".
This patch uses the new compatibility string in Exynos4412 based
Trats2 board.
Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
Cc: Chanwoo Choi <cw00.choi@samsung.com>
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Pull ARM SoC late DT updates from Arnd Bergmann:
"This is a collection of a few late fixes and other misc stuff that had
dependencies on things being merged from other trees.
The Renesas R-Car power domain handling, and the Nvidia Tegra USB
support both hand notable changes that required changing the DT
binding in a way that only provides compatibility with old DT blobs on
new kernels but not vice versa. As a consequence, the DT changes are
based on top of the driver changes and are now in this branch.
For NXP i.MX and Samsung Exynos, the changes in here depend on other
changes that got merged through the clk maintainer tree"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (35 commits)
ARM: dts: exynos: Add support of Bus frequency using VDD_INT for exynos5422-odroidxu3
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos542x SoC
ARM: dts: exynos: Add NoC Probe dt node for Exynos542x SoC
ARM: dts: exynos: Add support of bus frequency for exynos4412-trats/odroidu3
ARM: dts: exynos: Expand the voltage range of buck1/3 regulator for exynos4412-odroidu3
ARM: dts: exynos: Add support of bus frequency using VDD_INT for exynos3250-rinato
ARM: dts: exynos: Add exynos4412-ppmu-common dtsi to delete duplicate PPMU nodes
ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4210
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos4x12
ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4x12
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos3250
ARM: dts: exynos: Add DMC bus frequency for exynos3250-rinato/monk
ARM: dts: exynos: Add DMC bus node for Exynos3250
ARM: tegra: Enable XUSB on Nyan
ARM: tegra: Enable XUSB on Jetson TK1
ARM: tegra: Enable XUSB on Venice2
ARM: tegra: Add Tegra124 XUSB controller
ARM: tegra: Move Tegra124 to the new XUSB pad controller binding
ARM: dts: r8a7794: Use SYSC "always-on" PM Domain
ARM: dts: r8a7793: Use SYSC "always-on" PM Domain
This patch adds the bus device tree nodes for both MIF (Memory) and INT
(Internal) block to enable the bus frequency.
The DMC bus is parent device in MIF block using VDD_MIF and the LEFTBUS
bus is parent device in INT block using VDD_INT.
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
[m.reichl and linux.amoon: Tested it on exynos4412-odroidu3 board]
Tested-by: Markus Reichl <m.reichl@fivetechno.de>
Tested-by: Anand Moon <linux.amoon@gmail.com>
This patch adds the exynos4412-ppmu-common.dtsi to remove duplicate PPMU nodes
because exynos3250-rinato/monk, exynos4412-trats2/odroidu3 has the same
PPMU device tree node.
There is no external dependency for Security SubSystem (SSS) block so
the nodes for Pseudo Random Number Generator and AES hardware
acceleration can be enabled always for all Exynos4 devices.
Fix following DTC warnings in Trats2 board:
Warning (unit_address_vs_reg): Node /i2c-gpio-1/max77693@66/regulators/ESAFEOUT1@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c-gpio-1/max77693@66/regulators/ESAFEOUT2@2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c-gpio-1/max77693@66/regulators/CHARGER@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /thermistor-ap@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /thermistor-battery@1 has a unit name, but no reg property
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Enable the Security SubSystem (SSS) on Trats2 (Exynos4412) board to
provide hardware acceleration for AES operations.
Though the keyboard and other driver will continue to support the legacy
"gpio-key,wakeup", "linux-keypad,wakeup" boolean property to enable the
wakeup source, "wakeup-source" is the new standard binding.
This patch replaces all the legacy wakeup properties with the unified
"wakeup-source" property in order to avoid any further copy-paste
duplication.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Enable Pseudo Random Number Generator (PRNG) on Trats2 board. This
allows using hardware random number generator:
$ echo exynos > /sys/class/misc/hw_random/rng_current
exynos4412 boards
Exynos USB2 PHY driver now supports VBUS regulator, so add it to all
boards which have it available. This also fixes commit
7eec1266751b ("ARM: dts: Add Maxim 77693 PMIC to exynos4412-trats2"),
which added new regulators to Trats2 board, but without linking them to
the consumers.
Fixes: 7eec1266751b ("ARM: dts: Add Maxim 77693 PMIC to exynos4412-trats2")
Signed-off-by: Kukjin Kim <kgene@kernel.org>
The board DTS are using numeric values instead of the defined GPIO
constanst to express polarity, use them to make the DTS more clear.
The regulator-compatible property from the regulator DT binding was
deprecated and the correct approach is to use the node's name.
This patch has no functional changes but by not using a deprecated
property, new DTS based on this one will not carry the same issue.
For Exynos4x12 platforms, add CPU operating points (using
opp-v2 bindings) and CPU regulator supply properties for
migrating from Exynos specific cpufreq driver to using
generic cpufreq driver.
Based on the earlier work by Thomas Abraham.
Cc: Doug Anderson <dianders@chromium.org>
Cc: Andreas Faerber <afaerber@suse.de>
Cc: Thomas Abraham <thomas.ab@samsung.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Tested-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Add some safe values for over heat and over voltage. The Trats2 uses
3.8 V battery and during testing it operated properly under 4.48 V.
Usage of labels instead of full paths reduces possible mistakes when
overriding nodes.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
This patch sets display clock correctly. If Display clock isn't set
correctly then you would find below messages and Display controller
doesn't work correctly.
exynos-drm: No connectors reported connected with modes
[drm] Cannot find any crtc or sizes - going 1024x768
Fixes: abc0b1447d49 ("drm: Perform basic sanity checks on probed modes")
Cc: <stable@vger.kernel.org>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
Extend the S3C RTC node with rtc_src clock so it could be operational.
The rtc_src clock is provided by MAX77686 (Trats2) or S2MPS11 (Arndale
Octa).
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Presented patch aims to move data necessary for correct CPU cooling device
configuration from exynos_tmu_data.c to device tree.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Eduardo Valentin <edubezval@gmail.com>
Pull ARM SoC DT updates from Olof Johansson:
"DT changes continue to be the bulk of our merge window contents.
We continue to have a large set of changes across the board as new
platforms and drivers are added.
Some of the new platforms are:
- Alphascale ASM9260
- Marvell Armada 388
- CSR Atlas7
- TI Davinci DM816x
- Hisilicon HiP01
- ST STiH418
There have also been some sweeping changes, including relicensing of
DTS contents from GPL to GPLv2+/X11 so that the same files can be
reused in other non-GPL projects more easily. There's also been
changes to the DT Makefile to make it a little less conflict-ridden
and churny down the road"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (330 commits)
ARM: dts: Add PPMU node for exynos4412-trats2
ARM: dts: Add PPMU node for exynos3250-monk and exynos3250-rinato
ARM: dts: Add PPMU dt node for exynos4 and exynos4210
ARM: dts: Add PPMU dt node for exynos3250
ARM: dts: add mipi dsi device node for exynos4415
ARM: dts: add fimd device node for exynos4415
ARM: dts: Add syscon phandle to the video-phy node for Exynos4
ARM: dts: Add sound nodes for exynos4412-trats2
ARM: dts: Fix CLK_MOUT_CAMn parent clocks assignment for exynos4412-trats2
ARM: dts: Fix CLK_UART_ISP_SCLK clock assignment in exynos4x12.dtsi
ARM: dts: Add max77693 charger node for exynos4412-trats2
ARM: dts: Switch max77686 regulators to GPIO control for exynos4412-trats2
ARM: dts: Add suspend configuration for max77686 regulators for exynos4412-trats2
ARM: dts: Add Maxim 77693 fuel gauge node for exynos4412-trats2
ARM: dts: am57xx-beagle-x15: Fix USB2 mode
ARM: dts: am57xx-beagle-x15: Add extcon nodes for USB
ARM: dts: dra72-evm: Add extcon nodes for USB
ARM: dts: dra7-evm: Add extcon nodes for USB
ARM: dts: rockchip: move the hdmi ddc-i2c-bus property to the actual boards
ARM: dts: rockchip: enable vops and hdmi output on rk3288-firefly and -evb
This patch add dt node for PPMU_{DMC0|DMC1|LEFTBUS|RIGHTBUS} for
exynos4412-trats2 board. Each PPMU dt node includes one event of
'PPMU Count3'.
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com>
This patch add WM1811 audio codec, I2S interface and the sound
machine nodes to enable audio on exynos4412-trats2 board.
Signed-off-by: Inha Song <ideal.song@samsung.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
In order to get exact 24MHz clock frequency value for the camera
sensor and avoid rounding errors the parent clock must be CLK_XUSBXTI,
not CLK_MOUT_MPLL_USER_T. Currently the sensor's master clock
frequency is too high and the sensor doesn't work properly.
This fixes commit 0357a4438d531ef3cf529e80ffcd208eb8e35f55
("ARM: dts: Specify default clocks for Exynos4 camera devices").
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Add to Trats2 DTS new node for configuring the max77693 charger driver.
Only the maxim,constant-microvolt differs from default value but set all
of the optional properties anyway.
Remove fixed regulators (duplicating what max77686 provides) and
add GPIO enable control to max77686 regulators.
This gives the system full control over those regulators. Previously
the state of such regulators was a mixture of what max77686 driver set
over I2C and what regulator-fixed set through GPIO.
Removal of 'regulator-always-on' from CAM_ISP_CORE_1.2V (buck9) allows
disabling it when it is not used. Previously this regulator was always
enabled because its enable state is a OR of:
- ENB9 GPIO (turned always on by regulator-fixed),
- BUCK9EN field in BUCK9CTRL register (off by max77686 through I2C).
exynos4412-trats2
Add suspend to RAM configuration for max77686 regulators. Some LDOs
and bucks are disabled. This reduces energy consumption during S2R,
approximately from 17 mA to 9 mA.
Additionally remove old and not supported bindings:
- regulator-mem-off
- regulator-mem-idle
- regulator-mem-on
The max77686 driver does not parse them and they are not documented
anywere.
Add node for fuel gauge present in Maxim 77693 PMIC. This allows control
over battery charging state on Trats2 board.
The fuel gauge is compatible with max17042 battery driver (Maxim
17042/17047/17050). Although datasheet rev 2.2 for MAX77693 describes
fuel gauge as Maxim 17042-like, the chip on Trats2 board identifies
itself as Maxim 17047-like.
This patch adds stdout-path property to chosen nodes of Exynos4 boards
to enable use of earlycon feature without the need to hardcode port
number in kernel itself.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
All currently supported boards use hsotg/dwc2 controller in device
('peripheral') mode, so add property which sets correct operation mode.
This patch fixes support in recent changes in dwc2 driver, which added
support for dual-role devices.
Suggested-by: Paul Zimmerman <paulz@synopsys.com>
This patch adds max77693-haptic node to support for haptic motor driver.
Signed-off-by: Jaewon Kim <jaewon02.kim@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This patch add PWM(Pulse Width Modulation) node and
handle to use pwm property.
Specify the default mux and divider clocks in device tree
to ensure the FIMC devices on Trats, Trats2, Universal_c210
and Odroid X2/U3 boards are clocked from recommended clock
source and with maximum supported frequency.
For Trats2 also the MIPI-CSIS and the camera sensor clocks
are configured, the 'clock-frequency' property is deprecated
in favour of 'assigned-clock-rates' property.
This patch enables support for TMU at Exynos4412 based Trats2 board.
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Reviewed-by: Tomasz Figa <tomasz.figa@gmail.com>
Add SDHCI node for supporting the micro SD card. On Trats2 board the
SDHCI does not use sd2_cd pins (gpk2-2) for card detect but gpx3-4
instead.
Power is supplied from LDO21 regulator which in off state is controlled
by external GPIO pin.
The MAX77693 is a companion power management IC for smart phones and
tablets.
The MAX77693 contains input over-voltage protection (OVP),
a fully-integrated 2.5A switching charger for Lithium Ion battery with
integrated battery disconnect, OTG/accessory 5V output power,
a high-current white LED driver for camera flash, two safeout LDOs,
a haptic motor driver, Model Gauge m3 battery fuel gauge and MicroUSB
Interface Controller (MUIC). I2C serial interface is used for
communicating.
Add MAX77693 node to the Trats2 board. This allows using:
- charger regulator,
- 2 safeout LDO regulators (for USB OTG),
- extcon.
This patch adds sleep mode pin configuration using pin control hog
mechanism to configure states of GPIO pins in sleep mode. This is
required to reduce leakage current in sleep mode and prevent glitching
of components on the board.
In MAX77686 PMIC two regulators dedicated for eMMC memory can be
controlled both by I2C interface and a GPIO pin, with the resulting
regulator state being a logical OR of both. Since the GPIO control is
used both by the kernel and the lowest level bootloader at reset, the
regulator should be disabled by I2C control to allow it to be turned off
by GPIO control.
This patch removes regulator-always-on properties from both regulators
and, while at it, also unsupported regulator-mem-off.
dw-mmc in exynos
dw-mmc controller can support multiple slots.
But, there are no use-cases anywhere. So we don't need to support the
slot-node for dw-mmc controller.
And "supports-highspeed" property in dw-mmc is deprecated.
"supports-highspeed" property can be replaced with "cap-sd/mmc-highspeed".
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Reviewed-by: Tushar Behera <trblinux@gmail.com>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Tested-by: Sachin Kamat <sachin.kamat@samsung.com>
[kgene.kim@samsung.com: rebased exynos5250-snow changes]
This patch replaces the "cs-gpio" from "controller-data" node
as was specified in the old binding and uses the standard
"cs-gpios" property expected by the SPI core as is defined now
in the spi-s3c64xx driver DT binding.
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next
Pull ARM SoC devicetree updates from Olof Johansson:
"As with previous release, this continues to be among the largest
branches we merge, with lots of new contents.
New things for this release are among other things:
- DTSI contents for the new SoCs supported in 3.16 (see SoC pull request)
- Qualcomm APQ8064 and APQ8084 SoCs and eval boards
- Nvidia Jetson TK1 development board (Tegra T124-based)
Two new SoCs that didn't need enough new platform code to stand out
enough for me to notice when writing the SoC tag, but that adds new DT
contents are:
- TI DRA72
- Marvell Berlin 2Q"
* tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits)
ARM: dts: add secure firmware support for exynos5420-arndale-octa
ARM: dts: add pmu sysreg node to exynos3250
ARM: dts: correct the usb phy node in exynos5800-peach-pi
ARM: dts: correct the usb phy node in exynos5420-peach-pit
ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410
ARM: dts: add dts files for exynos3250 SoC
ARM: dts: add mfc node for exynos5800
ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi
ARM: dts: enable fimd for exynos5800-peach-pi
ARM: dts: enable display controller for exynos5800-peach-pi
ARM: dts: enable hdmi for exynos5800-peach-pi
ARM: dts: add dts file for exynos5800-peach-pi board
ARM: dts: add dts file for exynos5800 SoC
ARM: dts: add dts file for exynos5260-xyref5260 board
ARM: dts: add dts files for exynos5260 SoC
ARM: dts: update watchdog node name in exynos5440
ARM: dts: use key code macros on Origen and Arndale boards
ARM: dts: enable RTC and WDT nodes on Origen boards
ARM: dts: qcom: Add APQ8084-MTP board support
ARM: dts: qcom: Add APQ8084 SoC support
Pull part one of ARM SoC updates from Olof Johansson:
"A quite large set of SoC updates this cycle. In no particular order:
- Multi-cluster power management for Samsung Exynos, adding support
for big.LITTLE CPU switching on EXYNOS5
- SMP support for Marvell Armada 375 and 38x
- SMP rework on Allwinner A31
- Xilinx Zynq support for SOC_BUS, big endian
- Marvell orion5x platform cleanup, modernizing the implementation
and moving to DT.
- _Finally_ moving Samsung Exynos over to support MULTIPLATFORM, so
that their platform can be enabled in the same kernel binary as
most of the other v7 platforms in the tree. \o/
The work isn't quite complete, there's some driver fixes still
needed, but the basics now work.
New SoC support added:
- Freescale i.MX6SX
- LSI Axxia AXM55xx SoCs
- Samsung EXYNOS 3250, 5260, 5410, 5420 and 5800
- STi STIH407
plus a large set of various smaller updates for different platforms.
I'm probably missing some important one here"
* tag 'soc-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (281 commits)
ARM: exynos: don't run exynos4 l2x0 setup on other platforms
ARM: exynos: Fix "allmodconfig" build errors in mcpm and hotplug
ARM: EXYNOS: mcpm rename the power_down_finish
ARM: EXYNOS: Enable mcpm for dual-cluster exynos5800 SoC
ARM: EXYNOS: Enable multi-platform build support
ARM: EXYNOS: Consolidate Kconfig entries
ARM: EXYNOS: Add support for EXYNOS5410 SoC
ARM: EXYNOS: Support secondary CPU boot of Exynos3250
ARM: EXYNOS: Add Exynos3250 SoC ID
ARM: EXYNOS: Add 5800 SoC support
ARM: EXYNOS: initial board support for exynos5260 SoC
clk: exynos5410: register clocks using common clock framework
ARM: debug: qcom: add UART addresses to Kconfig help for APQ8084
ARM: sunxi: allow building without reset controller
Documentation: devicetree: arm: sort enable-method entries
ARM: rockchip: convert smp bringup to CPU_METHOD_OF_DECLARE
clk: exynos5250: Add missing sysmmu clocks for DISP and ISP blocks
ARM: dts: axxia: Add reset controller
power: reset: Add Axxia system reset driver
ARM: axxia: Adding defconfig for AXM55xx
This patch enables exynos_usbphy and hsotg device nodes.
Cc: Tomasz Figa <t.figa@samsung.com>
Cc: Kamil Debski <k.debski@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Signed-off-by: Chanho Park <chanho61.park@samsung.com>
This patch fixed gpio key device node.
First, fix incorrect gpio property.
And then, add ok-key node where locate bottom center.
I have tested on exynos4412-trats2 board.
Signed-off-by: Beomho Seo <beomho.seo@samsung.com>
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
