path: root/arch/arm/boot/dts/exynos5250-snow-rev5.dts
2016-09-16ARM: dts: exynos: Use macros for pinctrl configuration on exynos5250Krzysztof Kozlowski
Usage of DTS macros instead of hard-coded numbers makes code easier to read. One does not have to remember which value means pull-up/down or specific driver strength. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-09-30ARM: dts: Add Exynos5250 Snow Rev5+ support on exynos5250-snow-rev5Javier Martinez Canillas
There are 2 revisions of the Exynos5250 Snow Chromebook that were shipped: Rev4 and Rev5. The only difference between these 2 revisions is the codec, Rev4 has a max98095 codec while Rev5 has a max98090. Mainline only supports Rev4 so this patch moves the common device nodes to a DTSI file and adds a DTS for the Exynos5250 Snow Rev5. The Snow Rev5 DTS is based on the DTS found in the ChromiumOS 3.8 tree. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Tested-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Reviewed-by: Douglas Anderson <dianders@chromium.org> Signed-off-by: Kukjin Kim <kgene@kernel.org>
