Usage of DTS macros instead of hard-coded numbers makes code easier to
read. One does not have to remember which value means pull-up/down or
specific driver strength.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
There are 2 revisions of the Exynos5250 Snow Chromebook that were
shipped: Rev4 and Rev5. The only difference between these 2 revisions
is the codec, Rev4 has a max98095 codec while Rev5 has a max98090.
Mainline only supports Rev4 so this patch moves the common device
nodes to a DTSI file and adds a DTS for the Exynos5250 Snow Rev5.
The Snow Rev5 DTS is based on the DTS found in the ChromiumOS 3.8
tree.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Tested-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
Although there is only one choice of chipselect it is necessary to
specify it. The driver cannot claim the gpio otherwise.
Signed-off-by: Michal Suchanek <hramrach@gmail.com>
Acked-by: Javier Martinez Canillas <javier@osg.samsung.com>
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
For Exynos5250 platforms, add CPU operating points and CPU regulator
supply properties for migrating from Exynos specific cpufreq driver
to using generic cpufreq driver.
Cc: Doug Anderson <dianders@chromium.org>
Cc: Andreas Faerber <afaerber@suse.de>
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
[b.zolnierkie: split Exynos5250 support from the original patch]
[b.zolnierkie: added CPU regulator supply property for Spring boards]
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org>
Tested-by: Javier Martinez Canillas <javier@dowhile0.org>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
The i2c_7 node (i2c@12CD0000) with LVDS bridge child node was put in
Exynos5250 Snow DTS file twice. Move the LVDS bridge to proper existing
i2c_7 node.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
The Marvell mwifiex driver prevents the system to enter into a suspend
state if the card power is not preserved during a suspend/resume cycle.
So Suspend-to-RAM and Suspend-to-idle are failing on Exynos5250 Snow.
Add the keep-power-in-suspend Power Management property to the SDIO/MMC
node so the mwifiex suspend handler doesn't fail and the system is able
to enter into a suspend state.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Reviewed-by: Doug Anderson <dianders@chromium.org>
The kernel can use as the default console a serial port if is defined
as stdout device in the Device Tree.
This allows a board to be booted without the need of having a console
parameter in the kernel command line.
Currently the Snow DTS has a bootargs in the /chosen node and this is
kept since users that don't have a serial console on this board might
be using it to have the boot log shown in the display. This will have
more precedence than the stdout-path but it's fine since is only used
when CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is enabled.
Define videoports and use endpoints to describe the connection between
the encoder, bridge and the panel, instead of using phandles.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
Acked-by: Inki Dae <inki.dae@samsung.com>
Tested-by: Rahul Sharma <rahul.sharma@samsung.com>
Tested-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Tested-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
Tested-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Enabling SDIO IRQ signalling for the wifi MMC/SDIO slot
doubles the transmission transfer rate.
The Snow board has a MMC/SDIO wifi chip that is always powered but it
needs a power sequence involving a reset (active low) and an enable
(active high) pins. Both pins are marked as active low since the MMC
simple power sequence driver asserts the pins prior to the card power
up procedure and de-asserts the pins after the card has been powered.
So the reset line will be left de-asserted and the enable pin will be
left asserted.
The chip also needs an external 32kHz reference clock to be operational
that is by the MAX77686 PMIC clock.
Add a simple MMC power sequence provider for the wifi MMC/SDIO slot.
The Exynos5250 Snow Chromebook has GPIO keys for power and lid
so the SoC I/O pins have to be configured in external interrupt
mode. Currently, this is working without setting the pinctrl
lines but is better to set it explicitly instead of relying on
the previous state of the I/O pins.
The DTS snippets were taken from the downstream ChromeOS tree.
Pull ARM SoC DT updates from Arnd Bergmann:
"The DT branch adds a lot of new stuff for additional SoC and board
support. The branch is the largest one and contains 513 out of the
total 972 non-merge arm-soc changesets for 3.19.
Most of the changes are about enabling additional on-chip devices for
existing machines, but there are also an unusual number of new SoC
types being added this time:
- AMLogic Meson8
- ARM Realview in DT mode
- Allwinner A80
- Broadcom BCM47081
- Broadcom Cygnus
- Freescale LS1021A
- Freescale Vybrid 500 series
- Mediatek MT6592, MT8127, MT8135
- STMicroelectronics STiH410
- Samsung Exynos4415
The level of support for the above differs widely, some are just stubs
with nothing more than CPU, memory and a UART, but others are fairly
complete. As usual, these get extended over time.
There are also many new boards getting added, this is the list of
model strings that are showing up in new dts files:
- ARM RealView PB1176
- Altera SOCFPGA Arria 10
- Asus RT-N18U (BCM47081)
- Buffalo WZR-1750DHP (BCM4708)
- Buffalo WZR-600DHP2 (BCM47081)
- Cygnus Enterprise Phone (BCM911360_ENTPHN)
- D-Link DIR-665
- Google Spring
- IGEP COM MODULE Rev. G (TI OMAP AM/DM37x)
- IGEPv2 Rev. F (TI OMAP AM/DM37x)
- LS1021A QDS Board
- LS1021A TWR Board
- LeMaker Banana Pi
- MarsBoard RK3066
- MediaTek MT8127 Moose Board
- MediaTek MT8135 evaluation board
- Mele M3
- Merrii A80 Optimus Board
- Netgear R6300 V2 (BCM4708)
- Nomadik STN8815NHK
- NovaTech OrionLXm
- Olimex A20-OLinuXino-LIME2
- Raspberry Pi Model B+
- STiH410 B2120
- Samsung Monk board
- Samsung Rinato board
- Synology DS213j
- Synology DS414
- TBS2910 Matrix ARM mini PC
- TI AM5728 BeagleBoard-X15
- Toradex Colibri VF50 on Colibri Evaluation Board
- Zynq ZYBO Development Board
Other notable changes include:
- exynos: cleanup of existing dts files
- mvebu: improved pinctrl support for Armada 370/XP
- nomadik: restructuring dts files
- omap: added CAN bus support
- shmobile: added clock support for some SoCs
- shmobile: added sound support for some SoCs
- sirf: reset controller support
- sunxi: continuing the relicensing under dual GPL/MIT
- sunxi: lots of new on-chip device support
- sunxi: working simplefb support (long awaited)
- various: provide stdout-path property for earlycon"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (510 commits)
ARM: dts: rk3288: add arm,cpu-registers-not-fw-configured
Revert "ARM: dts: rockchip: temporarily disable smp on rk3288"
ARM: BCM5301X: Add DT for Buffalo WZR-600DHP2
ARM: BCM5301X: Add DT for Asus RT-N18U
ARM: BCM5301X: Add DT for Buffalo WZR-1750DHP
ARM: BCM5301X: Add DT for Netgear R6300 V2
ARM: BCM5301X: Add buttons for Netgear R6250
ARM: dts: rockchip: Add input voltage supply regulators in pmic for Marsboard
ARM: BCM5301X: Add IRQs to Broadcom's bus-axi in DTS file
arm: dts: zynq: Add Digilent ZYBO board
arm: dts: zynq: Move crystal freq. to board level
doc: dt: vendor-prefixes: Add Digilent Inc
Documentation: devicetree: Fix Xilinx VDMA specification
ARM: dts: rockchip: set FIFO size for SDMMC, SDIO and EMMC on rk3066 and rk3188
ARM: dts: rockchip: add label property for leds on Radxa Rock
ARM: BCM5301X: Add LEDs for Netgear R6250 V1
ARM: BCM5301X: Add Broadcom's bus-axi to the DTS file
ARM: dts: add sysreg phandle to i2c device nodes for exynos
ARM: dts: Remove unused bootargs from exynos3250-rinato
ARM: dts: add board dts file for Exynos3250-based Monk board
Explicitly set the dr_mode for the dwc3 controller on the
Snow board to host mode. This is required to ensure the
controller is initialized in the right mode if the kernel is
build with USB gadget support.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
commit 546b117fdf17 ("rtc: s3c: add support for RTC of Exynos3250 SoC")
added an "rtc_src" DT property for the Samsung's S3C Real Time Clock
controller that specifies the 32.768 kHz clock that uses the RTC as
its source clock. In the case of the Exynos5250 based Snow board, the
Maxim 77686 32kHz AP clock is used as the source clock.
Use the new style for referencing inherited nodes and use symbolic
names. Goal is the alignment of all exynos5250 based device trees
for comparison.
Signed-off-by: Andreas Faerber <afaerber@suse.de>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
[kgene.kim@samsung.com: rebased and squashed]
exynos5250-cros-common.dtsi had an empty /chosen node.
Fill in exemplary boot arguments.
Use the new style of referencing inherited nodes and use symbolic
names. Reorder one pinctrl node in GPIO order.
Goal is the alignment of all exynos5250 based device trees for
comparison.
Suggested-by: Doug Anderson <dianders@chromium.org>
Add DT nodes for ptn3460 bridge chip and panel.
Add backlight enable pin and backlight power supply for pwm-backlight.
Also add bridge phandle needed by dp to enable display on snow.
dw-mmc in exynos
dw-mmc controller can support multiple slots.
But, there are no use-cases anywhere. So we don't need to support the
slot-node for dw-mmc controller.
And "supports-highspeed" property in dw-mmc is deprecated.
"supports-highspeed" property can be replaced with "cap-sd/mmc-highspeed".
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Reviewed-by: Tushar Behera <trblinux@gmail.com>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Tested-by: Sachin Kamat <sachin.kamat@samsung.com>
[kgene.kim@samsung.com: rebased exynos5250-snow changes]
exynos5250-cros-common.dtsi was meant for sharing common pieces across
ChromeOS devices. This turned out premature, as several devices ended up
in the common file that are not common after all. Since the remaining
common ChromeOS pieces are fairly minor, exynos5250-cros-common.dtsi
was requested to be merged into the Snow device tree, sharing only the
keyboard controller for now. This may be re-evaluated as both mature.
The pinctrl properties should be on the device directly and not on the
slot sub-node.
Reported-by: Doug Anderson <dianders@chromium.org>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/dt
Merge "Samsung DT 2nd updates for v3.17" from Kukjin Kim:
This is based on tags/exynos-power because this DT changes
are depending PMU cleanup.
Fixes boot for exynos5260 and exynos5410,
- Since exynos cannot boot without obtaining PMU address via
DT from now on, add PMU node for exynos5260 and exynos5410
For preparing exynos5250-spring,
- move max77686 and cypress,cyapa trackpad from exynos5250-
cros-common to exynos5250-snow DT file
(Note exynos5250-spring is not included in this branch yet)
For exynos3250,
- add TMU node and remove duplicated interrupt-parent
- add missing pinctrl property for uart0 and uart1
For exynos5250-smdk5250 board
- add max77686 pmic interrupt property which is connected to
gpx3
* tag 'samsung-dt-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: (28 commits)
ARM: dts: Add missing pinctrl for uart0/1 for exynos3250
ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250
ARM: dts: Add TMU dt node to monitor the temperature for exynos3250
ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250
ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only
ARM: dts: max77686 is exynos5250-snow only
ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table
ARM: dts: Add PMU DT node for exynos5260 SoC
ARM: EXYNOS: Add support for Exynos5410 PMU
ARM: dts: Add PMU to exynos5410
ARM: dts: Document exynos5410 PMU
ARM: EXYNOS: Move cpufreq and cpuidle device registration to init_machine
ARM: EXYNOS: Refactored code for using PMU address via DT
ARM: EXYNOS: Support cluster power off on exynos5420/5800
ARM: EXYNOS: populate suspend and powered_up callbacks for mcpm
ARM: EXYNOS: do not allow cpuidle registration for exynos5420
cpuidle: big.LITTLE: init driver for exynos5420
cpuidle: big.LITTLE: Add ARCH_EXYNOS entry in config
ARM: EXYNOS: add generic function to calculate cpu number
cpuidle: big.LITTLE: add of_device_id structure
Move it from exynos5250-cros-common.dtsi to exynos5250-snow.dts.
Spring does not need it, it uses an Atmel maXTouch instead.
Spring does not need it, it uses an s5m8767 instead.
Merge "Samsung DT updates for v3.17" from Kukjin Kim:
exynos3250: add i2s dt for audio interface
exynos4
- cleanup arm-pmu node because of 4 pmu on
exynos4412 but 2 pmu on other exynos4 SoCs
- add support sub-nodes to exynos usb host for exynos4
exynos4412-odroid-common
- fix T-FLASH hotplug detection
- disable 'always on' for BUCK8
- add support for GPIO based buttons
- add MAX98090 audio codec
exynos4412-odroidx2 and exynos4412-odroidu3
- refactor exynos4412-odroidx and exynos4412-odroid-common
for odroid-x2 and u2/u3
exynos4412-odroidx
- add support for USB phy, host and device
- enable common hardware blocks, secure firmware calls,
watchdog, g2d and fimc (mem2mem) multimedia accelerators
- correct memory size
exynos5410
- fill in CPU clock-frequency property to avoid warning
exynos5420
- remove display pd because of instability
exynos5420-peach-pit and exynos5800-peach-pi
- sort nodes each other to check its differences easily
- enable audio support and add sound-card name property
- add mask-tpm-reset node
- add cros_ec including keyboard, i2c tunnel and tps65090
and battery under the i2c tunnel
* tag 'samsung-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: dts: Add I2S dt node for exynos3250
ARM: dts: Add cros_ec to exynos5420-peach-pit and exynos5800-peach-pi
ARM: dts: clean up arm-pmu node for exynos4
ARM: dts: remove display power domain for exynos5420
ARM: dts: Add sound nodes for Odroid-X2/U3 boards
ARM: dts: fix T-FLASH hotplug detection for exynos4412-odroid-common
ARM: dts: add support for GPIO buttons for exynos4412-odroid
ARM: dts: disable 'always on' for BUCK8 regulator for exynos4412-odroid-common
ARM: dts: refactor Odroid DTS file and add support for Odroid X2 and U2/U3
ARM: dts: correct memory size for exynos4412-odroidx
ARM: dts: add support for USB phy, host and device for exynos4412-odroidx
ARM: dts: enable common hardware blocks for exynos4412-odroidx
ARM: dts: add port sub-nodes to exynos usb host modules for exynos4
ARM: dts: Add mask-tpm-reset node in exynos5800-peach-pi
ARM: dts: Add mask-tpm-reset node in exynos5420-peach-pit
ARM: dts: Add sound-card name for Snow/Peach-Pit/Peach-Pi
ARM: dts: Fill in CPU clock-frequency for exynos5410
ARM: dts: Sort nodes within Peach-pit/Peach-pi dts files
ARM: dts: Enable audio support for exynos5800-peach-pi
Add sound-card name property to Snow/Peach-Pit/Peach-Pi boards.
Signed-off-by: Tushar Behera <tushar.b@samsung.com>
Acked-by: Mark Brown <broonie@linaro.org>
Signed-off-by: Doug Anderson <dianders@chromium.org>
Enable dp-controller for snow board.
Signed-off-by: Rahul Sharma <rahul.sharma@samsung.com>
Enable fimd node for snow board.
Add PWM backlight node for exynos5250 based snow board.
Add required fixed-regulator for VBUS supply for USB 3.0
controller phy.
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
The audio codec on Snow board, MAX98095 is connected on I2C7 bus.
Also it requires the GPX1-7 line to be pulled up.
Updated Snow DTS file to incorporate above changes and added a
sound node to instantiate the I2S-based sound card.
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
Enable support for HDMI for exynos5250 based Snow board.
Acked-by: Tomasz Figa <t.figa@samsung.com>
Added TPS65090 regulator related nodes to Snow board.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Added pinctrl node for embedded controller (EC) IRQ
on Snow board.
Added i2c-arbitrator pinctrl node to Snow board.
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup3
Merge "Exynos cleanup for v3.15" from Kukjin Kim:
- reorganize code for
- add support reserve memory for mfc-v7
- consolidate exynos4 and exynos5 machine codes
- add generic compatible strings for exynos4 and exynos5
- update DT with generic compatible strings
- move clk related dt-binding header file in dt-bindings/clock
* tag 'exynos-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
dt-bindings: clock: Move exynos-audss-clk.h to dt-bindings/clock
ARM: dts: Update Exynos DT files with generic compatible strings
ARM: EXYNOS: Add generic compatible strings
ARM: EXYNOS: Consolidate exynos4 and exynos5 machine files
ARM: EXYNOS: Consolidate CPU init code
ARM: SAMSUNG: Introduce generic Exynos4 and 5 helpers
ARM: EXYNOS: Add support to reserve memory for MFC-v7
ARM: SAMSUNG: Reorganize calls to reserve memory for MFC
arch/arm/mach-exynos/exynos.c
Signed-off-by; Arnd Bergmann <arnd@arndb.de>
Add generic compatible strings to the respective board DT files.
Some boards might not have RTC xtal, so RTC shouldn't really be
enabled by default. Enable it in the required board files. For
now enable it for all board files to maintain the enabled status
exisitng prior to this patch.
Make it easier to notice the common file for ChromeOS devices based on
the Exynos5250 by giving it the exynos5250 prefix that the boards have.
Signed-off-by: Mark Brown <broonie@linaro.org>
Commit e908d5c5 ("ARM: dts: change status property of dwmmc nodes
for exynos5250") missed out handling the exynos5250 snow dts file.
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Signed-off-by: Yuvaraj Kumar C D <yuvaraj.cd@samsung.com>
The device tree sent upstream for exynos5250-snow encoded the search
key as CAPSLK. However in all ChromeOS kernels it is L_META. One can
certainly have long debates about which it ought to be, but I'm
proposing setting it to L_META because:
* That's how _all_ ChromeOS kernels do it and will do it.
* There is no L_META key on the board, so it's nice to have.
* For those people who really want it to be caps lock, they can use
xmodmap or somesuch.
When the exynos5250 device tree was sent upstream the keyboard mapping
was missing the 2nd instance of the "\" key. There are two copies of
the "\" because it simply has a different row and column on US and
non-US keyboards.
For more details, see the previous patch in this series: (mkbp: Fix
problems with backslash).
This patch rename's the device tree mmc node's from "dwmmc" to "mmc".
According to ePAPR chapter 2.2.2 generic node name recommendation,
it has been opted change from dwmmc to mmc.Also this patch remove the
instance index from the node name.
Moves the RTC DT node's "status" property from exynos5250 board
(arndale & snow) dts files to exynos5250.dtsi, since the bindings
in exynos5250.dtsi depicts the RTC h/w completely.
Signed-off-by: Vikas Sajjan <vikas.sajjan@linaro.org>
Fixes the RTC DT node name for Exynos5250 as per the DT node naming
convention.
Replace /include/ (dtc) with #include (C pre-processor) for all
Samsung DT files
Signed-off-by: Padmavathi Venna <padma.v@samsung.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
By default the exynos RTC is disabled. Enable it for snow. There's
also an external RTC on the max77686 PMIC but we haven't yet enabled
that.
The 'samsung,vbus-gpio' was submitted before pinmux landed for
exynos5250 and uses the old-style gpio specifier. Fix the two
exynos5250 boards that use it.
