Instead of hardcoding the SYSRAM details for each SoC,
pass this information through device tree (DT) and make
the code SoC agnostic. Generic DT SRAM bindings are
used for achieving this.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup3
Merge "Exynos cleanup for v3.15" from Kukjin Kim:
- reorganize code for
- add support reserve memory for mfc-v7
- consolidate exynos4 and exynos5 machine codes
- add generic compatible strings for exynos4 and exynos5
- update DT with generic compatible strings
- move clk related dt-binding header file in dt-bindings/clock
* tag 'exynos-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
dt-bindings: clock: Move exynos-audss-clk.h to dt-bindings/clock
ARM: dts: Update Exynos DT files with generic compatible strings
ARM: EXYNOS: Add generic compatible strings
ARM: EXYNOS: Consolidate exynos4 and exynos5 machine files
ARM: EXYNOS: Consolidate CPU init code
ARM: SAMSUNG: Introduce generic Exynos4 and 5 helpers
ARM: EXYNOS: Add support to reserve memory for MFC-v7
ARM: SAMSUNG: Reorganize calls to reserve memory for MFC
arch/arm/mach-exynos/exynos.c
Signed-off-by; Arnd Bergmann <arnd@arndb.de>
Most of the clock related dt-binding header files are located in
dt-bindings/clock folder. It would be good to keep all the similar
header files at a single location.
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
Reviewed-by: Sachin Kamat <sachin.kamat@linaro.org>
Acked-by: Tomasz Figa <t.figa@samsung.com>
Add generic compatible strings to the respective board DT files.
This patch adds dt entry for ahci sata controller and its
corresponding phy controller.phy node has been added w.r.t
new generic phy framework.
Signed-off-by: Yuvaraj Kumar C D <yuvaraj.cd@samsung.com>
Acked-by: Kishon Vijay Abraham I <kishon@ti.com>
This patch adds the device tree node for SSS module
found on Exynos5420 and Exynos5250
Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
The patch replaces magic numbers with macros defined in DT header
in exynos5250 clock bindings.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Acked-by: Mike Turquette <mturquette@linaro.org>
Some boards might not have RTC xtal, so RTC shouldn't really be
enabled by default. Enable it in the required board files. For
now enable it for all board files to maintain the enabled status
exisitng prior to this patch.
In EXYNOS5 series SoCs, PMU has registers to enable/disable mask/unmask
watchdog timer which is not the case with s3c series SoCs so, there is a
need to have different compatible names for watchdog to handle these pmu
registers access.
Hence this patch removes watchdog node from Exynos5.dtsi common file and
make it separate by updating existing node in Exynos5250 and adding new node
to Exynos5420. This patch also makes the watchdog node enabled by default
Signed-off-by: Leela Krishna Amudala <l.krishna@samsung.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
Tested-by: Doug Anderson <dianders@chromium.org>
Acked-by: Guenter Roeck <linux@roeck-us.net>
This patch adds pmusysreg node to exynos5250 and exynos5420 dtsi files to
handle PMU register accesses in a centralized way using syscon driver
git://git.linaro.org/people/mike.turquette/linux
Pull clk framework changes from Mike Turquette:
"The first half of the clk framework pull request is made up almost
entirely of new platform/driver support. There are some conversions
of existing drivers to the common-clock Device Tree binding, and a few
non-critical fixes to the framework.
Due to an entirely unnecessary cyclical dependency with the arm-soc
tree this pull request is broken into two pieces. The second piece
will be sent out after arm-soc sends you the pull request that merged
in core support for the HiSilicon 3620 platform. That same pull
request from arm-soc depends on this pull request to merge in those
HiSilicon bits without causing build failures"
[ Just did the ARM SoC merges, so getting ready for the second clk tree
pull request - Linus ]
* tag 'clk-for-linus-3.14-part1' of git://git.linaro.org/people/mike.turquette/linux: (97 commits)
devicetree: bindings: Document qcom,mmcc
devicetree: bindings: Document qcom,gcc
clk: qcom: Add support for MSM8660's global clock controller (GCC)
clk: qcom: Add support for MSM8974's multimedia clock controller (MMCC)
clk: qcom: Add support for MSM8974's global clock controller (GCC)
clk: qcom: Add support for MSM8960's multimedia clock controller (MMCC)
clk: qcom: Add support for MSM8960's global clock controller (GCC)
clk: qcom: Add reset controller support
clk: qcom: Add support for branches/gate clocks
clk: qcom: Add support for root clock generators (RCGs)
clk: qcom: Add support for phase locked loops (PLLs)
clk: qcom: Add a regmap type clock struct
clk: Add set_rate_and_parent() op
reset: Silence warning in reset-controller.h
clk: sirf: re-arch to make the codes support both prima2 and atlas6
clk: composite: pass mux_hw into determine_rate
clk: shmobile: Fix MSTP clock array initialization
clk: shmobile: Fix MSTP clock index
ARM: dts: Add clock provider specific properties to max77686 node
clk: max77686: Register OF clock provider
Pull ARM SoC DT updates from Olof Johansson:
"DT and DT-conversion-related changes for various ARM platforms. Most
of these are to enable various devices on various boards, etc, and not
necessarily worth enumerating.
New boards and systems continue to come in as new devicetree files
that don't require corresponding C changes any more, which is
indicating that the system is starting to work fairly well.
A few things worth pointing out:
* ST Ericsson ux500 platforms have made the major push to move over
to fully support the platform with DT
* Renesas platforms continue their conversion over from legacy
platform devices to DT-based for hardware description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (327 commits)
ARM: dts: SiRF: add pin group for USP0 with only RX or TX frame sync
ARM: dts: SiRF: add lost usp1_uart_nostreamctrl pin group for atlas6
ARM: dts: sirf: add lost minigpsrtc device node
ARM: dts: sirf: add clock, frequence-voltage table for CPU0
ARM: dts: sirf: add lost bus_width, clock and status for sdhci
ARM: dts: sirf: add lost clocks for cphifbg
ARM: dts: socfpga: add pl330 clock
ARM: dts: socfpga: update L2 tag and data latency
arm: sun7i: cubietruck: Enable the i2c controllers
ARM: dts: add support for EXYNOS4412 based TINY4412 board
ARM: dts: Add initial support for Arndale Octa board
ARM: bcm2835: add USB controller to device tree
ARM: dts: MSM8974: Add MMIO architected timer node
ARM: dts: MSM8974: Add restart node
ARM: dts: sun7i: external clock outputs
ARM: dts: sun7i: Change 32768 Hz oscillator node name to clk@N style
ARM: dts: sun7i: Add pin muxing options for clock outputs
ARM: dts: sun7i: Add rtp controller node
ARM: dts: sun5i: Add rtp controller node
ARM: dts: sun4i: Add rtp controller node
Pull ARM SoC non-critical fixes from Olof Johansson:
"As usual, we have a batch of fixes that weren't considered significant
enough to warrant going into the later -rcs for previous release, so
they are queued up on this branch.
A handful of these are for various DT fixups for Samsung platforms,
and a handful of other minor things.
There are also a couple of stable-marked patches for mvebu -- they
came in quite late and we decided to keep them deferred until the
first -stable release to get more coverage instead of squeezing them
into 3.13"
* tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits)
ARM: at91: smc: bug fix in sam9_smc_cs_read()
i2c: mv64xxx: Document the newly introduced Armada XP A0 compatible
i2c: mv64xxx: Fix bus hang on A0 version of the Armada XP SoCs
ARM: mvebu: Add quirk for i2c for the OpenBlocks AX3-4 board
ARM: mvebu: Add support to get the ID and the revision of a SoC
ARM: dts: msm: Fix gpio interrupt and reg length
irqchip: sirf: set IRQ_LEVEL status_flags
ARM: OMAP2+: gpmc: Move legacy GPMC width setting
ARM: OMAP2+: gpmc: Introduce gpmc_set_legacy()
ARM: OMAP2+: gpmc: Move initialization outside the gpmc_t condition
ARM: OMAP2+: board-generic: update SoC compatibility strings
Documentation: dt: OMAP: explicitly state SoC compatible strings
ARM: OMAP2+: enable AM33xx SOC EVM audio
ARM: OMAP2+: Select USB PHY for AM335x SoC
ARM: bcm2835: Fix grammar in help message
ARM: msm: trout: fix uninit var warning
ARM: dts: Use MSHC controller for eMMC memory for exynos4412-trats2
ARM: dts: Fix definition of MSHC device tree nodes for exynos4x12
ARM: dts: add clock provider for mshc node for Exynos4412 SOC
clk: samsung: exynos4: Fix definition of div_mmc_pre4 divider
Specify pll_ref, pll_in, sclk_audio, and sclk_pcm_in for the AudioSS
clock controller.
Signed-off-by: Andrew Bresticker <abrestic@chromium.org>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Due to incorrect clock specified in MDMA0 node, using MDMA0 controller
could cause system failures, due to wrong clock being controlled. This
patch fixes this by specifying correct clock.
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
[t.figa: Corrected commit message and description.]
Ensure that unused I2C controllers are not activated, causing problems due
to inappropriate pinmuxing or similar, by marking the controllers as
disabled by default and requiring boards to explicitly enable those that
are in use.
Signed-off-by: Mark Brown <broonie@linaro.org>
Rather than requiring each board to explicitly disable the SPI controllers
it is not using instead require boards to enable those that they are using.
This is less work overall since normally at most one of the controllers is
in use and avoids issues caused by inappropriate pinmuxing.
Add the device-tree binding for the PWM controller to Exynos5250 and Exynos5420
Signed-off-by: Olof Johansson <olofj@chromium.org>
This patch rename's the device tree mmc node's from "dwmmc" to "mmc".
According to ePAPR chapter 2.2.2 generic node name recommendation,
it has been opted change from dwmmc to mmc.Also this patch remove the
instance index from the node name.
As fifo-depth property in dw_mmc device tree node is SOC
specific, move this property to exynos5250 SOC specific
file.
[kgene.kim@samsung.com: squashed fifo-depth patch for cros5250-common]
According to ePAPR, chapter 2.3.4, the status property has
defined that it should be set to "disabled" when "the device
is not presently operational, but it might become operational
in the future".
So this patch disable dwmmc node by "status = disabled" in SOC
dts file and enable dwmmc node by "status = okay" in board specific
dts file.
Added missing clock frequency property to CPU node to avoid
boot time warnings.
Exynos5 series SOC's 5250 and 5420 have different versions of
DWMMC controller.So there is a new compatible string to distinguish
between them.So these nodes should be moved out of Exynos5 series
common device tree source to SOC specific device tree source.
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung.git into next/dt
From Kukjin Kim, these are device-tree updates for Exynos. Among the changes:
- add MIPI PHY node for exynos4
- update regulator for origen and exynos5250-arndale
- add support HDMI for exynos5250, exynos5420
* commit '93457b9cb980ffeeef020c3bcd99065c3807619b':
ARM: dts: Add HDMI related I2C nodes for Arndale board
ARM: dts: enable hdmi subsystem for exynos5420 smdk board
ARM: dts: add dt nodes for hdmi subsystem for exynos5420
ARM: dts: add i2c device nodes for Exynos5420
ARM: dts: add clocks to hdmi dt node for exynos5250
ARM: dts: add mixer clocks to mixer node for Exynos5250
of/documentation: update with clock information for exynos hdmi subsystem
ARM: dts: Disable Exynos5250 I2S controllers by default
ARM: dts: Add reg property to regulator nodes in exynos5250-arndale
ARM: dts: Add fixed voltage regulator to simple bus for origen
ARM: dts: Add MIPI PHY node to exynos4.dtsi
Without the "clock-frequency" property in arch timer node, could able
to see the below crash dump.
[<c0014e28>] (unwind_backtrace+0x0/0xf4) from [<c0011808>] (show_stack+0x10/0x14)
[<c0011808>] (show_stack+0x10/0x14) from [<c036ac1c>] (dump_stack+0x7c/0xb0)
[<c036ac1c>] (dump_stack+0x7c/0xb0) from [<c01ab760>] (Ldiv0_64+0x8/0x18)
[<c01ab760>] (Ldiv0_64+0x8/0x18) from [<c0062f60>] (clockevents_config.part.2+0x1c/0x74)
[<c0062f60>] (clockevents_config.part.2+0x1c/0x74) from [<c0062fd8>] (clockevents_config_and_register+0x20/0x2c)
[<c0062fd8>] (clockevents_config_and_register+0x20/0x2c) from [<c02b8e8c>] (arch_timer_setup+0xa8/0x134)
[<c02b8e8c>] (arch_timer_setup+0xa8/0x134) from [<c04b47b4>] (arch_timer_init+0x1f4/0x24c)
[<c04b47b4>] (arch_timer_init+0x1f4/0x24c) from [<c04b40d8>] (clocksource_of_init+0x34/0x58)
[<c04b40d8>] (clocksource_of_init+0x34/0x58) from [<c049ed8c>] (time_init+0x20/0x2c)
[<c049ed8c>] (time_init+0x20/0x2c) from [<c049b95c>] (start_kernel+0x1e0/0x39c)
THis is because the Exynos u-boot, for example on the Chromebooks, doesn't set
up the CNTFRQ register as expected by arch_timer. Instead, we have to specify
the frequency in the device tree like this.
[olof: Changed subject, added comment, elaborated on commit message]
Fix wrong clock numbers in hdmi dt node. Removed hdmiphy
clock which was a dummy clock earlier and not required now.
Also added mux clock to change the clock parent.
Signed-off-by: Rahul Sharma <rahul.sharma@samsung.com>
This patch adds the mixer clocks to the mixer node in the
exynos 5250 dts file.
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Rather than requiring each board to explicitly disable the I2S controllers
This is required for audio operation on Arndale, one of the unused I2S
controllers is pinmuxed with the LDO enable GPIOs for the WM1811A.
Acked-by: Mark Rutland <mark.rutland@arm.com>
Pull ARM SoC late changes from Kevin Hilman:
"These are changes that arrived a little late before the merge window,
or had dependencies on previous branches.
Highlights:
- ux500: misc. cleanup, fixup I2C devices
- exynos: DT updates for RTC; PM updates
- at91: DT updates for NAND; new platforms added to generic defconfig
- sunxi: DT updates: cubieboard2, pinctrl driver, gated clocks
- highbank: LPAE fixes, select necessary ARM errata
- omap: PM fixes and improvements; OMAP5 mailbox support
- omap: basic support for new DRA7xx SoCs"
* tag 'late-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (60 commits)
ARM: dts: vexpress: Add CCI node to TC2 device-tree
ARM: EXYNOS: Skip C1 cpuidle state for exynos5440
ARM: EXYNOS: always enable PM domains support for EXYNOS4X12
ARM: highbank: clean-up some unused includes
ARM: sun7i: Enable the A20 clocks in the DTSI
ARM: sun6i: Enable clock support in the DTSI
ARM: sun5i: dt: Use the A10s gates in the DTSI
ARM: at91: at91_dt_defconfig: enable rm9200 support
ARM: dts: add ADC device tree node for exynos5420/5250
ARM: dts: Add RTC DT node to Exynos5420 SoC
ARM: dts: Update the "status" property of RTC DT node for Exynos5250 SoC
ARM: dts: Fix the RTC DT node name for Exynos5250
irqchip: mmp: avoid to include irqs head file
ARM: mmp: avoid to include head file in mach-mmp
irqchip: mmp: support irqchip
irqchip: move mmp irq driver
ARM: OMAP: AM33xx: clock: Add RNG clock data
ARM: OMAP: TI81XX: add always-on powerdomain for TI81XX
ARM: OMAP4: clock: Lock PLLs in the right sequence
ARM: OMAP: AM33XX: hwmod: Add hwmod data for debugSS
"Device tree and bindings updates for 3.12.
General additions of various on-chip and on-board peripherals on
various platforms as support gets added. Some of the bigger changes
are:
- Addition of (new) PCI-e support on Tegra.
- More Tegra4 support, including PMC configuration for Dalmore.
- Addition of a new board for Exynos4 (trats2) and more bindings for
4x12 IP.
- Addition of Allwinner A20 and A31 SoC and board files.
- Move of the ST Ericsson device tree files to now use ste-* prefix.
- More move of hardware description of shmobile platforms to DT.
- Two new board dts files for Freescale MXs"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (177 commits)
dts: Rename DW APB timer compatible strings
dts: Deprecate ALTR as a vendor prefix
of: add vendor prefix for Altera Corp.
ARM: at91/dt: sam9x5ek: add sound configuration
ARM: at91/dt: sam9x5ek: enable SSC
ARM: at91/dt: sam9x5ek: add WM8731 codec
ARM: at91/dt: sam9x5: add SSC DMA parameters
ARM: at91/dt: add at91rm9200 PQFP package version
ARM: at91: at91rm9200: set default mmc0 pinctrl-names
ARM: at91: at91sam9n12: correct pin number of gpio-key
ARM: at91: at91sam9n12: add qt1070 support
ARM: at91: at91sam9n12: add pinctrl of TWI
ARM: at91: Add PMU support for sama5d3
ARM: at91: at91sam9260: add missing pinctrl-names on mmc
ARM: tegra: configure power off for Dalmore
ARM: DT: binding fixup to align with vendor-prefixes.txt (DT)
ARM: dts: add sdio blocks to bcm28155-ap board
ARM: dts: align sdio numbers to HW definition
ARM: sun7i: Add Olimex A20-Olinuxino-Micro support
ARM: sun7i: Add Allwinner A20 DTSI
Pull ARM SoC cleanups from Olof Johansson:
"This branch contains code cleanups, moves and removals for 3.12.
There's a large number of various cleanups, and a nice net removal of
13500 lines of code.
Highlights worth mentioning are:
- A series of patches from Stephen Boyd removing the ARM local timer
API.
- Move of Qualcomm MSM IOMMU code to drivers/iommu.
- Samsung PWM driver cleanups from Tomasz Figa, removing legacy PWM
driver and switching over to the drivers/pwm one.
- Removal of some unusued auto-generated headers for OMAP2+ (PRM/CM).
There's also a move of a header file out of include/linux/i2c/ to
platform_data, where it really belongs. It touches mostly ARM
platform code for include changes so we took it through our tree"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits)
ARM: OMAP2+: Add back the define for AM33XX_RST_GLOBAL_WARM_SW_MASK
gpio: (gpio-pca953x) move header to linux/platform_data/
arm: zynq: hotplug: Remove unreachable code
ARM: SAMSUNG: Remove unnecessary exynos4_default_sdhci*()
tegra: simplify use of devm_ioremap_resource
ARM: SAMSUNG: Remove plat/regs-timer.h header
ARM: SAMSUNG: Remove remaining uses of plat/regs-timer.h header
ARM: SAMSUNG: Remove pwm-clock infrastructure
ARM: SAMSUNG: Remove old PWM timer platform devices
pwm: Remove superseded pwm-samsung-legacy driver
ARM: SAMSUNG: Modify board files to use new PWM platform device
ARM: SAMSUNG: Rework private data handling in dev-backlight
pwm: Add new pwm-samsung driver
ARM: mach-mvebu: remove redundant DT parsing and validation
ARM: msm: Only compile io.c on platforms that use it
iommu/msm: Move mach includes to iommu directory
ARM: msm: Remove devices-iommu.c
ARM: msm: Move mach/board.h contents to common.h
ARM: msm: Migrate msm_timer to CLOCKSOURCE_OF_DECLARE
ARM: msm: Remove TMR and TMR0 static mappings
Add ADC device tree node for exynos5420 and exynos5250
Signed-off-by: Doug Anderson <dianders@chromium.org>
Moves the RTC DT node's "status" property from exynos5250 board
(arndale & snow) dts files to exynos5250.dtsi, since the bindings
in exynos5250.dtsi depicts the RTC h/w completely.
Signed-off-by: Vikas Sajjan <vikas.sajjan@linaro.org>
Fixes the RTC DT node name for Exynos5250 as per the DT node naming
convention.
The patch adds the MFC clock entry for the 5250 SoC.
Signed-off-by: Arun Kumar K <arun.kk@samsung.com>
Moves the properties of DP controller to exynos5.dtsi which are common
across exynos5 SoCs like Exynos5250 and Exynos5420.
The PHY DP Node is based on Jingoo Han's <jg1.han@samsung.com> patch
at https://patchwork.linuxtv.org/patch/19189/
Moves the properties of FIMD DT node which are common across Exynos5 based
SoCs like Exynos5250 and Exynos5420 to exynos5.dtsi
This patch removes quirks from i2s node and change the i2s
compatible names.
Signed-off-by: Padmavathi Venna <padma.v@samsung.com>
Revert "ARM: dts: Change i2s compatible string on exynos5250" (c7f7e6)
and "ARM: dts: exynos5250: move common i2s properties to exynos5 dtsi"
618728) since they reference DMA controller nodes that don't exist
causing DT build issues.
Reported-by: Olof Johansson <olof@lixom.net>
compatible names.
I2S nodes shares some properties across exynos5 SoCs (exynos5250
and exyno5420). Common code is moved to exynos5.dtsi which is
included in exyno5250 and exynos5420 SoC files.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Adds G2D node to exynos5250 DT file.
Pull drm updates from Dave Airlie:
"Okay this is the big one, I was stalled on the fbdev pull req as I
stupidly let fbdev guys merge a patch I required to fix a warning with
some patches I had, they ended up merging the patch from the wrong
place, but the warning should be fixed. In future I'll just take the
patch myself!
Outside drm:
There are some snd changes for the HDMI audio interactions on haswell,
they've been acked for inclusion via my tree. This relies on the
wound/wait tree from Ingo which is already merged.
Major changes:
AMD finally released the dynamic power management code for all their
GPUs from r600->present day, this is great, off by default for now but
also a huge amount of code, in fact it is most of this pull request.
Since it landed there has been a lot of community testing and Alex has
sent a lot of fixes for any bugs found so far. I suspect radeon might
now be the biggest kernel driver ever :-P p.s. radeon.dpm=1 to enable
dynamic powermanagement for anyone.
New drivers:
Renesas r-car display unit.
Other highlights:
- core: GEM CMA prime support, use new w/w mutexs for TTM
reservations, cursor hotspot, doc updates
- dvo chips: chrontel 7010B support
- i915: Haswell (fbc, ips, vecs, watermarks, audio powerwell),
Valleyview (enabled by default, rc6), lots of pll reworking, 30bpp
support (this time for sure)
- nouveau: async buffer object deletion, context/register init
updates, kernel vp2 engine support, GF117 support, GK110 accel
support (with external nvidia ucode), context cleanups.
- exynos: memory leak fixes, Add S3C64XX SoC series support, device
tree updates, common clock framework support,
- qxl: cursor hotspot support, multi-monitor support, suspend/resume
support
- mgag200: hw cursor support, g200 mode limiting
- shmobile: prime support
- tegra: fixes mostly
I've been banging on this quite a lot due to the size of it, and it
seems to okay on everything I've tested it on."
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (811 commits)
drm/radeon/dpm: implement vblank_too_short callback for si
drm/radeon/dpm: implement vblank_too_short callback for cayman
drm/radeon/dpm: implement vblank_too_short callback for btc
drm/radeon/dpm: implement vblank_too_short callback for evergreen
drm/radeon/dpm: implement vblank_too_short callback for 7xx
drm/radeon/dpm: add checks against vblank time
drm/radeon/dpm: add helper to calculate vblank time
drm/radeon: remove stray line in old pm code
drm/radeon/dpm: fix display_gap programming on rv7xx
drm/nvc0/gr: fix gpc firmware regression
drm/nouveau: fix minor thinko causing bo moves to not be async on kepler
drm/radeon/dpm: implement force performance level for TN
drm/radeon/dpm: implement force performance level for ON/LN
drm/radeon/dpm: implement force performance level for SI
drm/radeon/dpm: implement force performance level for cayman
drm/radeon/dpm: implement force performance levels for 7xx/eg/btc
drm/radeon/dpm: add infrastructure to force performance levels
drm/radeon: fix surface setup on r1xx
drm/radeon: add support for 3d perf states on older asics
drm/radeon: set default clocks for SI when DPM is disabled
Pull ARM SoC late changes from Arnd Bergmann:
or that have multiple dependencies on previous branches so they did
not fit into one of the earlier ones. There are 10 branches merged
here, a total of 39 non-merge commits. Contents are a mixed bag for
the above reasons:
* Two new SoC platforms: ST microelectronics stixxxx and the TI
'Nspire' graphing calculator. These should have been in the 'soc'
branch but were a little late
* Support for the Exynos 5420 variant in mach-exynos, which is based
on the other exynos branches to avoid conflicts.
* Various small changes for sh-mobile, ux500 and davinci
* Common clk support for MSM"
* tag 'late-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (39 commits)
ARM: ux500: bail out on alien cpus
ARM: davinci: da850: adopt to pinctrl-single change for configuring multiple pins
serial: sh-sci: Initialise variables before access in sci_set_termios()
ARM: stih41x: Add B2020 board support
ARM: stih41x: Add B2000 board support
ARM: sti: Add DEBUG_LL console support
ARM: sti: Add STiH416 SOC support
ARM: sti: Add STiH415 SOC support
ARM: msm: Migrate to common clock framework
ARM: msm: Make proc_comm clock control into a platform driver
ARM: msm: Prepare clk_get() users in mach-msm for clock-pcom driver
ARM: msm: Remove clock-7x30.h include file
ARM: msm: Remove custom clk_set_{max,min}_rate() API
ARM: msm: Remove custom clk_set_flags() API
msm: iommu: Use clk_set_rate() instead of clk_set_min_rate()
msm: iommu: Convert to clk_prepare/unprepare
msm_sdcc: Convert to clk_prepare/unprepare
usb: otg: msm: Convert to clk_prepare/unprepare
msm_serial: Use devm_clk_get() and properly return errors
msm_serial: Convert to clk_prepare/unprepare
Pull ARM SoC driver specific changes from Arnd Bergmann:
"These changes are all driver specific and cross over between arm-soc
contents and some other subsystem, in these cases cpufreq, crypto,
dma, pinctrl, mailbox and usb, and the subsystem owners agreed to have
these changes merged through arm-soc.
As we proceed to untangle the dependencies between platform code and
driver code, the amount of changes in this category is fortunately
shrinking, for 3.11 we have 16 branches here and 101 non-merge
changesets, the majority of which are for the stedma40 dma engine
driver used in the ux500 platform. Cleaning up that code touches
multiple subsystems, but gets rid of the dependency in the end.
The mailbox code moved out from mach-omap2 to drivers/mailbox is an
intermediate step and is still omap specific at the moment. Patches
exist to generalize the subsystem and add other drivers with the same
API, but those did not make it for 3.11."
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (101 commits)
crypto: ux500: use dmaengine_submit API
crypto: ux500: use dmaengine_prep_slave_sg API
crypto: ux500: use dmaengine_device_control API
crypto: ux500/crypt: add missing __iomem qualifiers
crypto: ux500/hash: add missing static qualifiers
crypto: ux500/hash: use readl on iomem addresses
dmaengine: ste_dma40: Declare memcpy config as static
ARM: ux500: Remove mop500_snowball_ethernet_clock_enable()
ARM: ux500: Correct the EN_3v3 regulator's on/off GPIO
ARM: ux500: Provide a AB8500 GPIO Device Tree node
gpio: rcar: fix gpio_rcar_of_table
gpio-rcar: Remove #ifdef CONFIG_OF around OF-specific sections
gpio-rcar: Reference core gpio documentation in the DT bindings
clk: exynos5250: Add enum entries for divider clock of i2s1 and i2s2
ARM: dts: Update Samsung I2S documentation
ARM: dts: add clock provider information for i2s controllers in Exynos5250
ARM: dts: add Exynos audio subsystem clock controller node
clk: samsung: register audio subsystem clocks using common clock framework
ARM: dts: use #include for all device trees for Samsung
pinctrl: s3c24xx: use correct header for chained_irq functions
Pull ARM SoC device tree changes from Arnd Bergmann:
"These changes from 30 individual branches for the most part update
device tree files, but there are also a few source code changes that
have crept in this time, usually in order to atomically move over a
driver from using hardcoded data to DT probing.
A number of platforms change their DT files to use the C preprocessor,
which is causing a bit of churn, but that is hopefully only this once"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (372 commits)
ARM: at91: dt: rm9200ek: add spi support
ARM: at91: dt: rm9200: add spi support
ARM: at91/DT: at91sam9n12: add SPI DMA client infos
ARM: at91/DT: sama5d3: add SPI DMA client infos
ARM: at91/DT: fix SPI compatibility string
ARM: Kirkwood: Fix the internal register ranges translation
ARM: dts: bcm281xx: change comment to C89 style
ARM: mmc: bcm281xx SDHCI driver (dt mods)
ARM: nomadik: add the new clocks to the device tree
clk: nomadik: implement the Nomadik clocks properly
ARM: dts: omap5-uevm: Provide USB Host PHY clock frequency
ARM: dts: omap4-panda: Fix DVI EDID reads
ARM: dts: omap4-panda: Add USB Host support
arm: mvebu: enable mini-PCIe connectors on Armada 370 RD
ARM: shmobile: irqpin: add a DT property to enable masking on parent
ARM: dts: AM43x EPOS EVM support
ARM: dts: OMAP5: Add bandgap DT entry
ARM: dts: AM33XX: Add pinmux configuration for CPSW to am335x EVM
ARM: dts: AM33XX: Add pinmux configuration for CPSW to EVMsk
ARM: dts: AM33XX: Add pinmux configuration for CPSW to beaglebone
This patch renames the combatible strings for hdmi, mixer, ddc
and hdmiphy. It follows the convention of using compatible string
which represent the SoC in which the IP was added for the first
time.
Signed-off-by: Inki Dae <inki.dae@samsung.com>
Instead of having to specify the number for CPUs in EXYNOS5250 in
platsmp.c file, let the number of CPUs be determined by having this
information listed in EXYNOS5250 device tree file.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
