dwmmc driver deprecated num-slots and plan to get rid
of it finally. Just move a step to cleanup it from DT.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into next/dt
Pull "Topic branch for Samsung DeviceTree cleanup for 4.9" from Krzysztof Kozłowski:
Replace in DT sources hard-coded values for pinctrl configuration like pull
up/down, drive strength and function. This makes the DTS easier to read,
especially that some drive strengths values are quite non-obvious.
* tag 'samsung-dt-pinctrl-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: dts: s3c64xx: Use macros for pinctrl configuration
ARM: dts: s3c2416: Use macros for pinctrl configuration
ARM: dts: s5pv210: Use macros for pinctrl configuration
ARM: dts: s3c64xx: Use common macros for pinctrl configuration
ARM: dts: exynos: Fix mismatched values of SD drive strengh configuration on exynos4415
ARM: dts: exynos: Fix mismatched value for SD4 pull up/down configuration on exynos4210
ARM: dts: exynos: Use macros for pinctrl configuration on exynos542x/exynos5800
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5410
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5260
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5250
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4415
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4x12
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4210
ARM: dts: exynos: Use macros for pinctrl configuration on exynos3250
ARM: dts: exynos: Use common macros for pinctrl configuration
pinctrl: dt-bindings: samsung: Update documentation with new macros
pinctrl: dt-bindings: samsung: Add header with values used for configuration
Usage of DTS macros instead of hard-coded numbers makes code easier to
read. One does not have to remember which value means pull-up/down or
specific driver strength.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
The skeleton.dtsi file was removed in ARM64 for different reasons as
explained in commit ("3ebee5a2e141 arm64: dts: kill skeleton.dtsi").
These also applies to ARM and it will also allow to get rid of the
following DTC warnings in the future:
The disassembled DTB are almost the same besides an empty chosen
node being removed and nodes reordered, so it should not have
functional changes.
The exynos5.dtsi is used for common nodes shared between Exynos5250 and
Exynos542x. Since Exynos5410 is very similar to Exynos5420 it can
include the common file as well to remove duplication and make
everything more consistent.
This patch changes SROM nodes compatible from generic to model specific
to match with binding documentation. Also updating property
"samsung,srom-page-mode" as it is not defined as bool instead of int
Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com>
The chip is smsc9115, connected via SROMc bank 3. Additionally, some GPIO
initialization is required.
Signed-off-by: Pavel Fedin <p.fedin@samsung.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
The UART status properties are indented one level too deep, and we want
to derive a device tree for the ODROID-XU. Fix this before it propagates.
Signed-off-by: Andreas Faerber <afaerber@suse.de>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
dw-mmc in exynos
dw-mmc controller can support multiple slots.
But, there are no use-cases anywhere. So we don't need to support the
slot-node for dw-mmc controller.
And "supports-highspeed" property in dw-mmc is deprecated.
"supports-highspeed" property can be replaced with "cap-sd/mmc-highspeed".
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Reviewed-by: Tushar Behera <trblinux@gmail.com>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Tested-by: Sachin Kamat <sachin.kamat@samsung.com>
[kgene.kim@samsung.com: rebased exynos5250-snow changes]
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Add initial device tree nodes for EXYNOS5410 SoC and SMDK5410 board.
Signed-off-by: Tarek Dakhran <t.dakhran@samsung.com>
Signed-off-by: Vyacheslav Tyrtov <v.tyrtov@samsung.com>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
