commit 5628a8ca14149ba4226e3bdce3a04c3b688435ad upstream.
According to the comment added to exynos_dt_pmu_match[] in commit
8b283c025443 ("ARM: exynos4/5: convert pmu wakeup to stacked domains"),
the RTC is not able to wake up the system through the PMU on Exynos5410,
unlike Exynos5420.
However, when the RTC DT node got added, it was a straight copy of
the Exynos5420 node, which now causes a warning from dtc.
This removes the incorrect interrupt-parent, which should get the
interrupt working and avoid the warning.
Fixes: e1e146b1b062 ("ARM: dts: exynos: Add RTC and I2C to Exynos5410")
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Move watchdog and Security SubSystem nodes from exynos5420.dtsi to file
shared with Exynos5410 and configure the clocks on the latter.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Add nodes for Thermal Management Unit to exynos5410.dtsi. Use the same
compatible as for Exynos5420 however without second base for TRIMINFO
register and without TMU for GPU.
On Exynos5410 the SPI interrupt for second USB DWC3 (called DRD: Dual
Role Device) is different - 200 instead of 73.
Configure Exynos5410-specific properties of RTC, I2C and HSI2C nodes.
This still does not enable them on the board level though.
Move USB 3.0 DWC and 2.0 EHCI/OHCI nodes from exynos5420.dtsi to
exynos54xx.dtsi common for entire family. For Exynos542x/5800 this
should not have functional impact but for Exynos5410 this effectively
adds USB support.
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com>
The Exynos5410/542x/5800 are very similar designs. Create a new
DTSI with common nodes to remove DTS duplication. Although currently
only MCT and SysRAM are shared but in future more nodes will be added to
the common file.
The patch should not have functional impact.
Just like other Exynos5 family SoCs, this one has four UARTs. Configure
clocks for UART3 and enable it.
The exynos5.dtsi is used for common nodes shared between Exynos5250 and
Exynos542x. Since Exynos5410 is very similar to Exynos5420 it can
include the common file as well to remove duplication and make
everything more consistent.
For consistency lowercase node labels are used.
The CLKOUT (which control is provided by PMU) is necessary for some of
the drivers using this as a clock, e.g. usb3503 USB HUB on Odroid XU
board.
This patch changes SROM nodes compatible from generic to model specific
to match with binding documentation. Also updating property
"samsung,srom-page-mode" as it is not defined as bool instead of int
Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com>
All Exynos SoCs have the same syscon reboot and poweroff device nodes so
there is no need to duplicate the same on each SoC dtsi and can be moved
to a common dtsi that can be included by all the SoCs dtsi files.
Suggested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Reviewed-by: Alim Akhtar <alim.akhtar@samsung,com>
The chip is smsc9115, connected via SROMc bank 3. Additionally, some GPIO
initialization is required.
Signed-off-by: Pavel Fedin <p.fedin@samsung.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Device Tree changes for v4.6 adding the nodes for Exynos SROM controller
driver. The driver saves and restores SROM registers during suspend to RAM.
DT changes should go in before removal of SROM support from mach-exynos.
This machine uses own SoC device tree file, add missing part.
Add the required pin configuration support to Exynos5410 using pinctrl
interface.
Signed-off-by: Hakjoo Kim <ruppi.kim@hardkernel.com>
[AF: Rebased, style changes]
Signed-off-by: Andreas Färber <afaerber@suse.de>
Tested-by: Pavel Fedin <p.fedin@samsung.com>
[k.kozlowski: Move pinctrl nodes into soc node]
This patch adds syscon-{reboot, poweroff} nodes to allow the
generic syscon-{reboot, poweroff} driver to reset/poweroff exynos5410 SoC.
Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com>
Reviewed-by: Pankaj Dubey <pankaj.dubey@samsung.com>
Tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Moritz Fischer <moritz.fischer@ettus.com>
Pull ARM SoC device-tree changes from Olof Johansson:
"Unlike the board branch, this keeps having large sets of changes for
every release, but that's quite expected and is so far working well.
Most of this is plumbing for various device bindings and new
platforms, but there's also a bit of cleanup and code removal for
things that are moved from platform code to DT contents (some OMAP
clock code in particular).
There's also a pinctrl driver for tegra here (appropriately acked),
that's introduced this way to make it more bisectable.
I'm happy to say that there were no conflicts at all with this branch
this release, which means that changes are flowing through our tree as
expected instead of merged through driver maintainers (or at least not
done with conflicts).
There are several new boards added, and a couple of SoCs. In no
particular order:
- Rockchip RK3288 SoC support, including DTS for a dev board that
they have seeded with some community developers.
- Better support for Hardkernel Exynos4-based ODROID boards.
- CCF conversions (and dtsi contents) for several Renesas platforms.
- Gumstix Pepper (TI AM335x) board support
- TI eval board support for AM437x
- Allwinner A23 SoC, very similar to existing ones which mostly has
resulted in DT changes for support. Also includes support for an
Ippo tablet with the chipset.
- Allwinner A31 Hummingbird board support, not to be confused with
the SolidRun i.MX-based Hummingboard.
- Tegra30 Apalis board support"
* tag 'dt-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (334 commits)
ARM: dts: Enable USB host0 (EHCI) on rk3288-evb
ARM: dts: add rk3288 ehci usb devices
ARM: dts: Turn on USB host vbus on rk3288-evb
ARM: tegra: apalis t30: fix device tree compatible node
ARM: tegra: paz00: Fix some indentation inconsistencies
ARM: zynq: DT: Clarify Xilinx Zynq platform
ARM: dts: rockchip: add watchdog node
ARM: dts: rockchip: remove pinctrl setting from radxarock uart2
ARM: dts: Add missing pinctrl for uart0/1 for exynos3250
ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250
ARM: dts: Add TMU dt node to monitor the temperature for exynos3250
ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250
ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only
ARM: dts: max77686 is exynos5250-snow only
ARM: zynq: DT: Remove DMA from board DTs
ARM: zynq: DT: Add CAN node
ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table
ARM: dts: Add PMU DT node for exynos5260 SoC
ARM: EXYNOS: Add support for Exynos5410 PMU
ARM: dts: Add PMU to exynos5410
Exynos initialization code now relies on obtaining the PMU address,
so prepare a PMU node for Exynos5410.
Fixes: fce9e5bb2526 ("ARM: EXYNOS: Add support for mapping PMU base
address via DT")
Signed-off-by: Andreas Faerber <afaerber@suse.de>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This patch adds alias entries for UART nodes of all SoCs using
samsung-uart compatible UART controllers, so that the dependency on
probe order is removed and deterministic device naming is assured.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
It's 1.6 GHz for the Cortex-A15.
Avoids warnings like "/cpus/cpu@0 missing clock-frequency property".
Reviewed-by: Tarek Dakhran <t.dakhran@samsung.com>
Add initial device tree nodes for EXYNOS5410 SoC and SMDK5410 board.
Signed-off-by: Tarek Dakhran <t.dakhran@samsung.com>
Signed-off-by: Vyacheslav Tyrtov <v.tyrtov@samsung.com>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
