path: root/arch/arm/boot/dts/exynos5420-pinctrl.dtsi
2018-11-13ARM: dts: exynos: Add pin configuration for SD write protect on Odroid ↵Anand Moon
XU3/XU4/HC1 Add SD card write-protect pin configuration to be sure that it will be properly pulled down to indicate write access. Suggested-by: Krzysztof Kozlowski <krzk@kernel.org> Signed-off-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
2018-01-03ARM: dts: exynos: Add SPDX license identifiersKrzysztof Kozlowski
Replace GPL v2.0 license statements with SPDX license identifiers. Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
2017-06-02ARM: dts: exynos: Add HDMI CEC device to Exynos5 SoC familyMarek Szyprowski
Exynos5250 and Exynos542x SoCs have the same CEC hardware module as Exynos4 SoC series, so enable support for it using the same compatible string. Tested on Odroid XU3 (Exynos5422) and Google Snow (Exynos5250) boards. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
2016-09-16ARM: dts: exynos: Use macros for pinctrl configuration on exynos542x/exynos5800Krzysztof Kozlowski
Usage of DTS macros instead of hard-coded numbers makes code easier to read. One does not have to remember which value means pull-up/down or specific driver strength. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2016-09-16ARM: dts: exynos: Use common macros for pinctrl configurationKrzysztof Kozlowski
Replace duplicated macros in each DTSI file with a common macro coming from header. Include the header in each pinctrl DTSI so further changes could use it. Although PIN_FUNC_SPC_2 does not bring much information about the function itself, it still is more descriptive then hard-coded number <2>. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2016-05-31ARM: dts: exynos: Re-order alphabetically Exynos5420 SD0/SD1 pinctrl nodesKrzysztof Kozlowski
The 'sd0_rclk' was put in the middle of SD1 nodes. Remove the confusion. Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com> Tested-by: Javier Martinez Canillas <javier@osg.samsung.com>
2015-07-21ARM: dts: Extend exynos5420-pinctrl nodes using labels instead of pathsJavier Martinez Canillas
A previously defined Device Tree node, can be extended either by defining a node using the same full path or by creating a label for the node and referencing to it. Using full paths is more error prone since if there was a typo error, a new node will be created instead of extending the node as it was desired. This will lead to run-time errors that could be hard to detect. A mistyped label on the other hand, will cause a dtc compile error which makes it easier to detect the mistake since happens at build-time instead. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2015-03-27ARM: dts: Add HS400 support for exynos5420 and exynos5800Seungwon Jeon
HS400 timing values are added for SMDK5420, exynos5420-peach-pit and exynos5800-peach-pi boards. This also adds RCLK GPIO line, this gpio should be in pull-down state. This also enables HS400 on peach-pi and this updates the clock frequency to 800MHz to be set as input clock to controller. Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com> [alim.akhtar@samsung.com: addressed review comments] Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kukjin Kim <kgene@kernel.org>
2014-05-09ARM: dts: Add pwmX_out pinctrl nodes to exynos5420Arun Kumar K
Adds the PWM nodes to 5420 pinctrl dtsi file. Signed-off-by: Arun Kumar K <arun.kk@samsung.com> Reviewed-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-12-12ARM: dts: Fix a typo in exynos5420-pinctrl.dtsiSachin Kamat
Fixed samaung -> samsung in property name. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Reviewed-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-08-19ARM: dts: Add pin state information for DP HPD support to Exynos5420Vikas Sajjan
Add pin state information for DP HPD support that requires pin configuration support using pinctrl interface. Signed-off-by: Vikas Sajjan <vikas.sajjan@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-06-19ARM: dts: add pinctrl support to EXYNOS5420Leela Krishna Amudala
Add the required pin configuration support to EXYNOS5420 using pinctrl interface. Signed-off-by: Leela Krishna Amudala <l.krishna@samsung.com> Reviewed-by: Doug Anderson <dianders@chromium.org> Acked-by: Tomasz Figa <t.figa@samsung.com> Tested-by : Sunil Joshi <joshi@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
