During my research I found that some of the requirements for the memory
buffers for MFC v6+ devices were blindly copied from the previous (v5)
version and simply turned out to be excessive. The relaxed requirements
are applied by the recent patches to the MFC driver and the driver is
now fully functional even without the reserved memory blocks for all
v6+ variants. This patch removes those reserved memory nodes from all
boards having MFC v6+ hardware block.
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com>
Acked-by: Andrzej Hajda <a.hajda@samsung.com>
Tested-by: Smitha T Murthy <smitha.t@samsung.com>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into next/dt
Pull "Topic branch for Samsung DeviceTree cleanup for 4.9" from Krzysztof Kozłowski:
Replace in DT sources hard-coded values for pinctrl configuration like pull
up/down, drive strength and function. This makes the DTS easier to read,
especially that some drive strengths values are quite non-obvious.
* tag 'samsung-dt-pinctrl-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: dts: s3c64xx: Use macros for pinctrl configuration
ARM: dts: s3c2416: Use macros for pinctrl configuration
ARM: dts: s5pv210: Use macros for pinctrl configuration
ARM: dts: s3c64xx: Use common macros for pinctrl configuration
ARM: dts: exynos: Fix mismatched values of SD drive strengh configuration on exynos4415
ARM: dts: exynos: Fix mismatched value for SD4 pull up/down configuration on exynos4210
ARM: dts: exynos: Use macros for pinctrl configuration on exynos542x/exynos5800
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5410
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5260
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5250
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4415
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4x12
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4210
ARM: dts: exynos: Use macros for pinctrl configuration on exynos3250
ARM: dts: exynos: Use common macros for pinctrl configuration
pinctrl: dt-bindings: samsung: Update documentation with new macros
pinctrl: dt-bindings: samsung: Add header with values used for configuration
Usage of DTS macros instead of hard-coded numbers makes code easier to
read. One does not have to remember which value means pull-up/down or
specific driver strength.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
The skeleton.dtsi file was removed in ARM64 for different reasons as
explained in commit ("3ebee5a2e141 arm64: dts: kill skeleton.dtsi").
These also applies to ARM and it will also allow to get rid of the
following DTC warnings in the future:
The disassembled DTB are almost the same besides an empty chosen
node being removed and nodes reordered, so it should not have
functional changes.
This patch enables getting a HPD GPIO descriptor quicker.
The exynos-hdmi driver uses "hpd" for HDMI hot plug detection.
static int hdmi_resources_init(struct hdmi_context *hdata)
hdata->hpd_gpio = devm_gpiod_get(dev, "hpd", GPIOD_IN);
This calls 'of_find_gpio()' and it generates the GPIO consumer ID by referring
GPIO suffix. So 'hpd-gpios' is preferred on getting a GPIO descriptor.
However, if the device tree uses 'hpd-gpio', then the exynos-hdmi driver
always retries to get a GPIO descriptor because the first GPIO suffix is not
'gpio' but 'gpios'. So you always see the debug message below.
of_get_named_gpiod_flags: can't parse 'hpd-gpios' property of node '/soc/hdmi@14530000[0]'
Use the preferred property, 'hpd-gpios' instead of 'hpd-gpio'.
Acked-by: Rob Herring <robh@kernel.org>
Reviewed-by: Andrzej Hajda <a.hajda@samsung.com>
Cc: devicetree@vger.kernel.org
Cc: linux-samsung-soc@vger.kernel.org
Signed-off-by: Milo Kim <woogyom.kim@gmail.com>
This patch moves assigning reserved memory regions from each board dts
to common exynos-mfc-reserved-memory.dtsi file, where those regions are
defined.
This patch replaces custom properties for defining reserved memory
regions with generic reserved memory bindings for MFC video codec
device.
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
[k.kozlowski: Add Samsung copyrights]
Pull drm updates from Dave Airlie:
"Here's the main drm pull request for 4.7, it's been a busy one, and
I've been a bit more distracted in real life this merge window. Lots
more ARM drivers, not sure if it'll ever end. I think I've at least
one more coming the next merge window.
But changes are all over the place, support for AMD Polaris GPUs is in
here, some missing GM108 support for nouveau (found in some Lenovos),
a bunch of MST and skylake fixes.
I've also noticed a few fixes from Arnd in my inbox, that I'll try and
get in asap, but I didn't think they should hold this up.
New drivers:
- Hisilicon kirin display driver
- Mediatek MT8173 display driver
- ARC PGU - bitstreamer on Synopsys ARC SDP boards
- Allwinner A13 initial RGB output driver
- Analogix driver for DisplayPort IP found in exynos and rockchip
DRM Core:
- UAPI headers fixes and C++ safety
- DRM connector reference counting
- DisplayID mode parsing for Dell 5K monitors
- Removal of struct_mutex from drivers
- Connector registration cleanups
- MST robustness fixes
- MAINTAINERS updates
- Lockless GEM object freeing
- Generic fbdev deferred IO support
panel:
- Support for a bunch of new panels
i915:
- VBT refactoring
- PLL computation cleanups
- DSI support for BXT
- Color manager support
- More atomic patches
- GEM improvements
- GuC fw loading fixes
- DP detection fixes
- SKL GPU hang fixes
- Lots of BXT fixes
radeon/amdgpu:
- Initial Polaris support
- GPUVM/Scheduler/Clock/Power improvements
- ASYNC pageflip support
- New mesa feature support
nouveau:
- GM108 support
- Power sensor support improvements
- GR init + ucode fixes.
- Use GPU provided topology information
vmwgfx:
- Add host messaging support
gma500:
- Some cleanups and fixes
atmel:
- Bridge support
- Async atomic commit support
fsl-dcu:
- Timing controller for LCD support
- Pixel clock polarity support
rcar-du:
- Misc fixes
exynos:
- Pipeline clock support
- Exynoss4533 SoC support
- HW trigger mode support
- export HDMI_PHY clock
- DECON5433 fixes
- Use generic prime functions
- use DMA mapping APIs
rockchip:
- Lots of little fixes
vc4:
- Render node support
- Gamma ramp support
- DPI output support
msm:
- Mostly cleanups and fixes
- Conversion to generic struct fence
etnaviv:
- Fix for prime buffer handling
- Allow hangcheck to be coalesced with other wakeups
tegra:
- Gamme table size fix"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (1050 commits)
drm/edid: add displayid detailed 1 timings to the modelist. (v1.1)
drm/edid: move displayid validation to it's own function.
drm/displayid: Iterate over all DisplayID blocks
drm/edid: move displayid tiled block parsing into separate function.
drm: Nuke ->vblank_disable_allowed
drm/vmwgfx: Report vmwgfx version to vmware.log
drm/vmwgfx: Add VMWare host messaging capability
drm/vmwgfx: Kill some lockdep warnings
drm/nouveau/gr/gf100-: fix race condition in fecs/gpccs ucode
drm/nouveau/core: recognise GM108 chipsets
drm/nouveau/gr/gm107-: fix touching non-existent ppcs in attrib cb setup
drm/nouveau/gr/gk104-: share implementation of ppc exception init
drm/nouveau/gr/gk104-: move rop_active_fbps init to nonctx
drm/nouveau/bios/pll: check BIT table version before trying to parse it
drm/nouveau/bios/pll: prevent oops when limits table can't be parsed
drm/nouveau/volt/gk104: round up in gk104_volt_set
drm/nouveau/fb/gm200: setup mmu debug buffer registers at init()
drm/nouveau/fb/gk20a,gm20b: setup mmu debug buffer registers at init()
drm/nouveau/fb/gf100-: allocate mmu debug buffers
drm/nouveau/fb: allow chipset-specific actions for oneinit()
Exynos5420 boards
The bindings like s2mps11,buck6-ramp-enable or s2mps11,buck2-ramp-delay
were ignored. They were never parsed by s2mps11 regulator driver. Also
the values used in these bindings were equal to default reset values of
S2MPS11 device. It is safe to remove them.
Fix following DTC warnings in Exynos5420 SMDK5420:
Warning (unit_address_vs_reg): Node /dp-controller@145B0000/display-timings/timing@0 has a unit name, but no reg property
drm-next
This pull request want to land the analogix_dp driver into drm/bridge directory,
which reused the Exynos DP code, and add Rockchip DP support. And those
patches have been:
* 'drm-next-analogix-dp-v2' of github.com:yakir-Yang/linux:
drm: bridge: analogix/dp: Fix the possible dead lock in bridge disable time
drm: bridge: analogix/dp: add panel prepare/unprepare in suspend/resume time
drm: bridge: analogix/dp: add edid modes parse in get_modes method
drm: bridge: analogix/dp: move hpd detect to connector detect function
drm: bridge: analogix/dp: try force hpd after plug in lookup failed
drm: bridge: analogix/dp: add max link rate and lane count limit for RK3288
drm: bridge: analogix/dp: add some rk3288 special registers setting
dt-bindings: add document for rockchip variant of analogix_dp
drm: rockchip: dp: add rockchip platform dp driver
ARM: dts: exynos/dp: remove some properties that deprecated by analogix_dp driver
dt-bindings: add document for analogix display port driver
drm: bridge: analogix/dp: dynamic parse sync_pol & interlace & dynamic_range
drm: bridge: analogix/dp: remove duplicate configuration of link rate and link count
drm: bridge: analogix/dp: fix some obvious code style
drm: bridge: analogix/dp: rename register constants
drm/exynos: dp: rename implementation specific driver part
drm: bridge: analogix/dp: split exynos dp driver to bridge directory
driver
After exynos_dp have been split the common IP code into analogix_dp driver,
the analogix_dp driver have deprecated some Samsung platform properties which
could be dynamically parsed from EDID/MODE/DPCD message, so this is an update
for Exynos DTS file for dp-controller.
Beside the backward compatibility is fully preserved, so there are no
bisectability break that make this change in a separate patch.
Signed-off-by: Yakir Yang <ykk@rock-chips.com>
Add cluster regulator supply properties as a preparation to
adding generic cpufreq-dt driver support for Exynos542x and
Exynos5800 based boards.
Cc: Doug Anderson <dianders@chromium.org>
Cc: Javier Martinez Canillas <javier@osg.samsung.com>
Cc: Andreas Faerber <afaerber@suse.de>
Cc: Thomas Abraham <thomas.ab@samsung.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Exynos5420 and Exynos5800 boards boot from big core (A15) but
Exynos5422 boards choose otherwise: LITTLE core (A7) (on Exynos5422 this
is property of the board - configurable by pulling up/down gpg2-1).
To make user-visible CPU ordering more consistent the 'cpus' node was
overridden by exynos5422-cpus.dtsi.
However this is a little bit ugly and error-prone. Overriding the CPU
child nodes requires to basically reverse what was done initially in
exynos5420.dtsi.
Instead, split CPU configuration entirely to separate files which should
be included by board DTS.
Suggested-by: Viresh Kumar <viresh.kumar@linaro.org>
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
Reviewed-by: Chanho Park <parkch98@gmail.com>
The board DTS are using numeric values instead of the defined GPIO
constanst to express polarity, use them to make the DTS more clear.
Signed-off-by: Kukjin Kim <kgene@kernel.org>
smdk5250 and smdk5420
This patch moves the display-timings node from fimd to dp to reflect the
device tree bindings change.
Signed-off-by: Sean Paul <seanpaul@chromium.org>
[tomeu.vizoso@collabora.com: Rebased]
Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Usage of labels instead of full paths reduces possible mistakes when
overriding nodes.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
HS400 timing values are added for SMDK5420, exynos5420-peach-pit
and exynos5800-peach-pi boards. This also adds RCLK GPIO line,
this gpio should be in pull-down state.
This also enables HS400 on peach-pi and this updates the clock
frequency to 800MHz to be set as input clock to controller.
Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com>
[alim.akhtar@samsung.com: addressed review comments]
Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
The Exynos5420 SoC has 3 sets of 8 pads used as data lines for the 3
MMC/SD/SDIO slots. These needs to be muxed as SD_n_DATA instead of a
GPIO or external interrupt to allow the MMC controller to communicate
with the attached cards or SDIO devices.
Which data lines needs to be muxed as SD_n_DATA depends on the bus
width used for data transfer:
* bus-width = <1> needs SD_n_DATA[0]
* bus-width = <4> needs SD_n_DATA[0-3]
* bus-width = <8> needs SD_n_DATA[0-7]
The Exynos5250-pinctrl.dtsi file that defines the groups of pins has
SD_n_DATA[0] muxed for both sdn_bus1 and sdn_bus4 so just one of them
needs to be included in the device node's pinctrl property.
But Exynos5420-pinctrl has a different definition and only includes
SD_n_DATA[1-3] for sdn_bus4. So for a bus-width = <4>, both sdn_bus1
and sdn_bus4 have to be in the dev pinctrl to mux all the needed pads.
It seems all Exynos5420 boards had just cargo cult the pinctrl lines
assuming that sdn_bus4 also included SD_n_DATA[0] and it only works
because the bootloader muxes the pads correctly. But that is not the
case for the devices not used by the bootloader such as WiFi modules.
Add sdn_bus1 too in the nodes pinctrl to not rely on the bootloader.
Suggested-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
dw-mmc in exynos
dw-mmc controller can support multiple slots.
But, there are no use-cases anywhere. So we don't need to support the
slot-node for dw-mmc controller.
And "supports-highspeed" property in dw-mmc is deprecated.
"supports-highspeed" property can be replaced with "cap-sd/mmc-highspeed".
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Reviewed-by: Tushar Behera <trblinux@gmail.com>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Tested-by: Sachin Kamat <sachin.kamat@samsung.com>
[kgene.kim@samsung.com: rebased exynos5250-snow changes]
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Add MFC memory banks to Exynos5420 based SMDK and Arndale-octa boards.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Add required fixed-regulator for VBUS supply for USB 3.0
controller phy.
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup3
Merge "Exynos cleanup for v3.15" from Kukjin Kim:
- reorganize code for
- add support reserve memory for mfc-v7
- consolidate exynos4 and exynos5 machine codes
- add generic compatible strings for exynos4 and exynos5
- update DT with generic compatible strings
- move clk related dt-binding header file in dt-bindings/clock
* tag 'exynos-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
dt-bindings: clock: Move exynos-audss-clk.h to dt-bindings/clock
ARM: dts: Update Exynos DT files with generic compatible strings
ARM: EXYNOS: Add generic compatible strings
ARM: EXYNOS: Consolidate exynos4 and exynos5 machine files
ARM: EXYNOS: Consolidate CPU init code
ARM: SAMSUNG: Introduce generic Exynos4 and 5 helpers
ARM: EXYNOS: Add support to reserve memory for MFC-v7
ARM: SAMSUNG: Reorganize calls to reserve memory for MFC
arch/arm/mach-exynos/exynos.c
Signed-off-by; Arnd Bergmann <arnd@arndb.de>
Add generic compatible strings to the respective board DT files.
Fixed voltage regulators required by audio codec added.
Some boards might not have RTC xtal, so RTC shouldn't really be
enabled by default. Enable it in the required board files.
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
This patch adds the mmc device tree node entries for exynos5420 SOC.
Exynos5420 has a different version of DWMMC controller,so a new
compatible string is used to distinguish it from the prior SOC's.
Signed-off-by: Yuvaraj Kumar C D <yuvaraj.cd@samsung.com>
Add pinctrl node for hdmi hpd gpio pin to exynos5420 smdk board
file. hpd Gpio property is added to the hdmi node. This patch also
adds hdmi ddc node.
Both hdmi device and ddc i2c channel are enabled in
exynos5420-smdk5420.dts
Signed-off-by: Rahul Sharma <rahul.sharma@samsung.com>
Add pin state information for DP HPD support that requires pin configuration
support using pinctrl interface.
Signed-off-by: Vikas Sajjan <vikas.sajjan@linaro.org>
Adds DP controller DT node to exynos5420 SoC
Adds FIMD DT node to exynos5420 based SMDK. Also adds display-timimg
information node.
Add initial device tree nodes for EXYNOS5420 SoC and SMDK5420 board.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
