ARM Performance Monitoring Units (PMUs) are permanently disabled in the
Exynos5422 SoC version used on Odroid XU3-lite boards. Disable them in
boards dtb to avoid confusing user and getting following warning on boot:
hw-breakpoint: Failed to enable monitor mode on CPU 0
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Replace GPL v2.0 license statements with SPDX license identifiers.
The LED nodes can be shared between Odroid XU3, XU3-Lite and XU (not yet
added) thus removing duplication.
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com>
DWC3 device found on Exynos SoCs cannot work in OTG mode alone, because
it lacks some OTG related control part. OTG mode operation is possible
only with external hardware logic (usually GPIO-based) specific to
the board. Right now, however, there is no driver for such logic and no
bindings, so the OTG mode is dysfunctional at all (this means that it
doesn't work as a peripheral nor as a host). This patch sets the operation
mode to peripheral to get DWC3_1 device at least somehow working. This can
be later updated, when proper OTG driver and bindings get developed.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Add Hardkernel Odroid XU4 board Device Tree sources. The board differs
from Odroid XU3 and XU3-Lite by:
1. No green and red LEDs (except standard red power LED).
2. Only two PWM outputs are used (fan and blue LED)
3. No audio codec.
4. Two USB3 ports in host mode (no micro USB3 connector for OTG).
5. Realtek RTL8153-CG gigabit network adapter (instead of SMSC9514).
6. Additional connector with IO ports (I2S_0, I2C_5).
7. No DisplayPort (like XU3-Lite).
8. No TI INA231 power measurement sensors (like XU3-Lite).
Signed-off-by: Kukjin Kim <kgene@kernel.org>
The Odroid XU4 board does not have audio codec so before adding DTS
for new board split the audio codec to separate DTSI file. Include
the audio codec DTSI in Odroid XU3 and XU3-Lite boards.
The Odroid XU3 Lite is almost the same as XU3, except:
1. Lower CPU frequencies (1.8 GHz for A15 and 1.3 GHz for A7, instead of
2.0 GHz and 1.4 GHz).
2. No DisplayPort.
3. No TI INA231 energy measurement sensors.
This patch moves common nodes (which is almost everything) to a common
DTSI file and adds a new XU3 Lite DTS.
Currently in comparison to XU3, only the INA231 sensors are disabled to
remove the warning:
ina2xx 0-0040: error configuring the device: -6
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
