dtc recently added PCI bus checks. Fix these warnings.
Signed-off-by: Rob Herring <robh@kernel.org>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Replace hard-coded values of type of GIC interrupt and its flags with
respective macros from header to increase code readability.
Suggested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Exynos5440
In soft (no-reboot) mode, the driver self-pings watchdog upon expiration
of an interrupt. The interrupt has to be cleared, because otherwise
system enters infinite interrupt handling loop.
Use a samsung,s3c6410-wdt compatible to select appropriate quirk for
clearing the watchdog interrupt.
Acked-by: Guenter Roeck <linux@roeck-us.net>
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Add pcie-phy node to phy-exynos-pcie along with some changes to other
nodes:
1. Remove the configuration space from "ranges" property because this
was the old way of getting it. Preferred is to use "config" reg.
2. Use the reg-names as "elbi" and "config" so the purpose of addresses
will be easily known.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Reviewed-by: Pankaj Dubey <pankaj.dubey@samsung.com>
Since everybody copied my own mistake from the DT binding example,
let's address all the offenders in one swift go.
Most of them got the CPU interface size wrong (4kB, while it should
be 8kB), except for both keystone platforms which got the control
interface wrong (4kB instead of 8kB).
In a few cases where I knew for sure what implementation was used,
I've added the "arm,gic-400" compatible string. I'm 99% sure that
this is what everyone is using, but short of having the TRM for
all the other SoCs, I've left them alone.
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into next/dt
Pull "Samsung DeviceTree second update for v4.10" from Krzysztof Kozłowski:
1. Cleanups in MSHC nodes.
2. Enable ADC on Odroid boards.
3. Fix interrupt flags on recently added DMA sound nodes in Exynos5410.
* tag 'samsung-dt-4.10-2' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: dts: exynos: Remove the cd-gpios property for eMMC of Odroid XU3/4
ARM: dts: exynos: Specify snps, dwmac in compatible string for gmac
ARM: dts: exynos: Fix invalid GIC interrupt flags in audio block of Exynos5410
ARM: dts: exynos: Add ADCs on 4412 and 5422 based odroid boards.
ARM: dts: exynos: Replace "clock-freq-min-max" with "max-frequency"
devicetree binding for stmmac states:
- compatible: Should be "snps,dwmac-<ip_version>", "snps,dwmac"
For backwards compatibility: "st,spear600-gmac" is also supported.
No functional change intended.
Signed-off-by: Niklas Cassel <niklas.cassel@axis.com>
exynos5440
Interrupt of type IRQ_TYPE_NONE is not allowed for GIC interrupts and
generates an error:
genirq: Setting trigger mode 0 for irq 16 failed (gic_set_type+0x0/0x68)
The GIC requires shared interrupts to be edge rising or level high.
Platform declares support for both. Arbitrarily choose level high
everywhere hoping it will work on each platform.
Reported-by: Marek Szyprowski <m.szyprowski@samsung.com>
Reported-by: Alban Browaeys <alban.browaeys@gmail.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Reviewed-by: Alim Akhtar <alim.akhtar@samsung.com>
The skeleton.dtsi file was removed in ARM64 for different reasons as
explained in commit ("3ebee5a2e141 arm64: dts: kill skeleton.dtsi").
These also applies to ARM and it will also allow to get rid of the
following DTC warnings in the future:
"Node /memory has a reg or ranges property, but no unit name"
The disassembled DTB are almost the same besides an empty chosen
node being removed and nodes reordered, so it should not have
functional changes.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Fix following DTC warnings in Exynos5440 boards:
Warning (unit_address_vs_reg): Node /pinctrl has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /rtc has a reg or ranges property, but no unit name
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
The compatible string "simple-bus" is well defined in ePAPR, while
I see no documentation for the "arm,amba-bus" arnywhere in ePAPR or
Documentation/devicetree/.
DT is also used by other projects than Linux kernel. It is not a
good idea to rely on such an unofficial binding.
This commit
- replaces "arm,amba-bus" with "simple-bus"
- drops "arm,amba-bus" where it is used along with "simple-bus"
Add new labels to certain nodes so they could be easily referenced by
Exynos5 board DTS files.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
Presented device tree bindings provide data already hardcoded in the
exynos_tmu_data.c file.
After this commit, it should be possible to reuse common thermal core
framework in Exynos SoCs.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Eduardo Valentin <edubezval@gmail.com>
This patch adds alias entries for UART nodes of all SoCs using
samsung-uart compatible UART controllers, so that the dependency on
probe order is removed and deterministic device naming is assured.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Made it as per DT node naming convention <name@reg_addr>.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Reviewed-by: Jingoo Han <jg1.han@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup3
Merge "Exynos cleanup for v3.15" from Kukjin Kim:
- reorganize code for
- add support reserve memory for mfc-v7
- consolidate exynos4 and exynos5 machine codes
- add generic compatible strings for exynos4 and exynos5
- update DT with generic compatible strings
- move clk related dt-binding header file in dt-bindings/clock
* tag 'exynos-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
dt-bindings: clock: Move exynos-audss-clk.h to dt-bindings/clock
ARM: dts: Update Exynos DT files with generic compatible strings
ARM: EXYNOS: Add generic compatible strings
ARM: EXYNOS: Consolidate exynos4 and exynos5 machine files
ARM: EXYNOS: Consolidate CPU init code
ARM: SAMSUNG: Introduce generic Exynos4 and 5 helpers
ARM: EXYNOS: Add support to reserve memory for MFC-v7
ARM: SAMSUNG: Reorganize calls to reserve memory for MFC
arch/arm/mach-exynos/exynos.c
Signed-off-by; Arnd Bergmann <arnd@arndb.de>
Add generic compatible strings to the respective board DT files.
The patch replaces magic numbers with macros defined in DT header
in exynos5440 clock bindings.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Acked-by: Tomasz Figa <t.figa@samsung.com>
Acked-by: Mike Turquette <mturquette@linaro.org>
For consistency with other device tree nodes, this patch adds missing
spaces after node labels.
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Set the default status for PCIe to disabled in the exynos5440.dtsi
file and let the board dts files such as exynos5440-ssdk5440.dts
enable the PCIe. However, keep the PCIe for SD5v1 board disabled,
because there is no PCIe slot on SD5v1 board.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Pull ARM SoC DT updates from Olof Johansson:
"Device tree and bindings updates for 3.12.
General additions of various on-chip and on-board peripherals on
various platforms as support gets added. Some of the bigger changes
are:
- Addition of (new) PCI-e support on Tegra.
- More Tegra4 support, including PMC configuration for Dalmore.
- Addition of a new board for Exynos4 (trats2) and more bindings for
4x12 IP.
- Addition of Allwinner A20 and A31 SoC and board files.
- Move of the ST Ericsson device tree files to now use ste-* prefix.
- More move of hardware description of shmobile platforms to DT.
- Two new board dts files for Freescale MXs"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (177 commits)
dts: Rename DW APB timer compatible strings
dts: Deprecate ALTR as a vendor prefix
of: add vendor prefix for Altera Corp.
ARM: at91/dt: sam9x5ek: add sound configuration
ARM: at91/dt: sam9x5ek: enable SSC
ARM: at91/dt: sam9x5ek: add WM8731 codec
ARM: at91/dt: sam9x5: add SSC DMA parameters
ARM: at91/dt: add at91rm9200 PQFP package version
ARM: at91: at91rm9200: set default mmc0 pinctrl-names
ARM: at91: at91sam9n12: correct pin number of gpio-key
ARM: at91: at91sam9n12: add qt1070 support
ARM: at91: at91sam9n12: add pinctrl of TWI
ARM: at91: Add PMU support for sama5d3
ARM: at91: at91sam9260: add missing pinctrl-names on mmc
ARM: tegra: configure power off for Dalmore
ARM: DT: binding fixup to align with vendor-prefixes.txt (DT)
ARM: dts: add sdio blocks to bcm28155-ap board
ARM: dts: align sdio numbers to HW definition
ARM: sun7i: Add Olimex A20-Olinuxino-Micro support
ARM: sun7i: Add Allwinner A20 DTSI
Pull ARM SoC cleanups from Olof Johansson:
"This branch contains code cleanups, moves and removals for 3.12.
There's a large number of various cleanups, and a nice net removal of
13500 lines of code.
Highlights worth mentioning are:
- A series of patches from Stephen Boyd removing the ARM local timer
API.
- Move of Qualcomm MSM IOMMU code to drivers/iommu.
- Samsung PWM driver cleanups from Tomasz Figa, removing legacy PWM
driver and switching over to the drivers/pwm one.
- Removal of some unusued auto-generated headers for OMAP2+ (PRM/CM).
There's also a move of a header file out of include/linux/i2c/ to
platform_data, where it really belongs. It touches mostly ARM
platform code for include changes so we took it through our tree"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits)
ARM: OMAP2+: Add back the define for AM33XX_RST_GLOBAL_WARM_SW_MASK
gpio: (gpio-pca953x) move header to linux/platform_data/
arm: zynq: hotplug: Remove unreachable code
ARM: SAMSUNG: Remove unnecessary exynos4_default_sdhci*()
tegra: simplify use of devm_ioremap_resource
ARM: SAMSUNG: Remove plat/regs-timer.h header
ARM: SAMSUNG: Remove remaining uses of plat/regs-timer.h header
ARM: SAMSUNG: Remove pwm-clock infrastructure
ARM: SAMSUNG: Remove old PWM timer platform devices
pwm: Remove superseded pwm-samsung-legacy driver
ARM: SAMSUNG: Modify board files to use new PWM platform device
ARM: SAMSUNG: Rework private data handling in dev-backlight
pwm: Add new pwm-samsung driver
ARM: mach-mvebu: remove redundant DT parsing and validation
ARM: msm: Only compile io.c on platforms that use it
iommu/msm: Move mach includes to iommu directory
ARM: msm: Remove devices-iommu.c
ARM: msm: Move mach/board.h contents to common.h
ARM: msm: Migrate msm_timer to CLOCKSOURCE_OF_DECLARE
ARM: msm: Remove TMR and TMR0 static mappings
Exynos PCIe IP consists of Synopsys specific part and Exynos
specific part. Only core block is a Synopsys Designware part;
other parts are Exynos specific.
Also, the Synopsys Designware part can be shared with other
platforms; thus, it can be split two parts such as Synopsys
Designware part and Exynos specific part.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Pratyush Anand <pratyush.anand@st.com>
Cc: Mohit KUMAR <Mohit.KUMAR@st.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
This patch adds device node for TMU controller. There are 3
instances of the controllers so 3 nodes are created.
Acked-by: Jonghwa Lee <jonghwa3.lee@samsung.com>
Reviewed-by: Eduardo Valentin <eduardo.valentin@ti.com>
Signed-off-by: Amit Daniel Kachhap <amit.daniel@samsung.com>
Pull ARM SoC driver specific changes from Arnd Bergmann:
"These changes are all driver specific and cross over between arm-soc
contents and some other subsystem, in these cases cpufreq, crypto,
dma, pinctrl, mailbox and usb, and the subsystem owners agreed to have
these changes merged through arm-soc.
As we proceed to untangle the dependencies between platform code and
driver code, the amount of changes in this category is fortunately
shrinking, for 3.11 we have 16 branches here and 101 non-merge
changesets, the majority of which are for the stedma40 dma engine
driver used in the ux500 platform. Cleaning up that code touches
multiple subsystems, but gets rid of the dependency in the end.
The mailbox code moved out from mach-omap2 to drivers/mailbox is an
intermediate step and is still omap specific at the moment. Patches
exist to generalize the subsystem and add other drivers with the same
API, but those did not make it for 3.11."
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (101 commits)
crypto: ux500: use dmaengine_submit API
crypto: ux500: use dmaengine_prep_slave_sg API
crypto: ux500: use dmaengine_device_control API
crypto: ux500/crypt: add missing __iomem qualifiers
crypto: ux500/hash: add missing static qualifiers
crypto: ux500/hash: use readl on iomem addresses
dmaengine: ste_dma40: Declare memcpy config as static
ARM: ux500: Remove mop500_snowball_ethernet_clock_enable()
ARM: ux500: Correct the EN_3v3 regulator's on/off GPIO
ARM: ux500: Provide a AB8500 GPIO Device Tree node
gpio: rcar: fix gpio_rcar_of_table
gpio-rcar: Remove #ifdef CONFIG_OF around OF-specific sections
gpio-rcar: Reference core gpio documentation in the DT bindings
clk: exynos5250: Add enum entries for divider clock of i2s1 and i2s2
ARM: dts: Update Samsung I2S documentation
ARM: dts: add clock provider information for i2s controllers in Exynos5250
ARM: dts: add Exynos audio subsystem clock controller node
clk: samsung: register audio subsystem clocks using common clock framework
ARM: dts: use #include for all device trees for Samsung
pinctrl: s3c24xx: use correct header for chained_irq functions
Pull ARM SoC device tree changes from Arnd Bergmann:
"These changes from 30 individual branches for the most part update
device tree files, but there are also a few source code changes that
have crept in this time, usually in order to atomically move over a
driver from using hardcoded data to DT probing.
A number of platforms change their DT files to use the C preprocessor,
which is causing a bit of churn, but that is hopefully only this once"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (372 commits)
ARM: at91: dt: rm9200ek: add spi support
ARM: at91: dt: rm9200: add spi support
ARM: at91/DT: at91sam9n12: add SPI DMA client infos
ARM: at91/DT: sama5d3: add SPI DMA client infos
ARM: at91/DT: fix SPI compatibility string
ARM: Kirkwood: Fix the internal register ranges translation
ARM: dts: bcm281xx: change comment to C89 style
ARM: mmc: bcm281xx SDHCI driver (dt mods)
ARM: nomadik: add the new clocks to the device tree
clk: nomadik: implement the Nomadik clocks properly
ARM: dts: omap5-uevm: Provide USB Host PHY clock frequency
ARM: dts: omap4-panda: Fix DVI EDID reads
ARM: dts: omap4-panda: Add USB Host support
arm: mvebu: enable mini-PCIe connectors on Armada 370 RD
ARM: shmobile: irqpin: add a DT property to enable masking on parent
ARM: dts: AM43x EPOS EVM support
ARM: dts: OMAP5: Add bandgap DT entry
ARM: dts: AM33XX: Add pinmux configuration for CPSW to am335x EVM
ARM: dts: AM33XX: Add pinmux configuration for CPSW to EVMsk
ARM: dts: AM33XX: Add pinmux configuration for CPSW to beaglebone
This patch adds pcie controller node for exynos5440-ssdk5440,
and also adds a phandle for pin controller node.
Exynos5440 has two PCIe controllers which can be used as root complex
for PCIe interface.
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/dt
From Kukjin Kim:
2nd exynos dt update based on tags/exynos-dt-1
- enable RTC on exynos5250 snow and Arndale boards
- add support LCD and PWM for exynos4210 Origen board
- update bootargs to support 8GiB for exynos5440 SSDK5440 and SD5v1 boards
- enable spi and add opp level for exynos5440
- add example doc for samsung-pinctrl dt bindings
* tag 'exynos-dt-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: dts: Set BUCK7 as always on for Origen board
ARM: dts: Add FIMD node to Origen4210 board
ARM: dts: Add LCD related pinctrl entries for exynos4210
ARM: dts: Add PWM related pinctrl entries for exynos4210
Documentation: Add examples to samsung-pinctrl device tree bindings documentation
ARM: dts: Enable RTC node for exynos5250-snow
ARM: dts: Enable RTC node for Arndale
ARM: dts: Removing pdma for exynos5440
ARM: dts: update bootargs to support 8GiB for SSDK5440 and SD5v1
ARM: dts: Add more opp levels in exynos5440
ARM: dts: Add wm8994 regulator support on smdk5250
ARM: dts: enable spi for EXYNOS5440 SOC
Replace /include/ (dtc) with #include (C pre-processor) for all
Samsung DT files
Signed-off-by: Padmavathi Venna <padma.v@samsung.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
Since the pdma works only in secure mode, accessing the same
in hypervisor mode gives an abort. As we are not using pdma
anywhere, removing the same.
Signed-off-by: Giridhar Maruthy <giridhar.m@samsung.com>
This patch updates cpu frequency level from 1500 to 800MHZ in steps
of 100MHZ. The corresponding voltage(in uV) is also added.
This patch enables the SPI in EXYNOS5440 SoC. The NOR
Flash can be accessed by enabling the spi interface
Signed-off-by: Girish K S <ks.giri@samsung.com>
From Kukjin Kim:
Update exynos DT for
- usb3phy and dwc3 for exynos5250
- keypad for exynos4412
- TMU clock for exynos4210
- MFC clock for exynos4
- DP controller for exynos5250
- G2D clock for exynos4
- some exynos boards
* tag 'exynos-dt-1' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: (456 commits)
ARM: dts: add ohci and ehci controller nodes for EXYNOS5440
ARM: dts: Update G2D documentation for clock entries
ARM: dts: Add clock entries to G2D node for exynos4x12
ARM: dts: Add clock entries to G2D node for exynos4210
ARM: dts: Remove duplicate and add missing G2D nodes
clk: exynos4: Add additional G2D clocks
ARM: dts: Document DP clock in samsung,exynos5-dp binding
ARM: dts: add pin state information for DP HPD support to Exynos5250
ARM: dts: add dts node for the ahci sata exynos5440
ARM: dts: add vmmc regulator support for ODROID-X
ARM: dts: add max77686 node entry for ODROID-X
ARM: dts: Enable RTC by default on EXYNOS5440
ARM: dts: Add display timing node to exynos5250-arndale.dts
ARM: dts: Add clock provider information for DP controller in Exynos5250 SoC
ARM: dts: Add DT node for DP controller for Arndale Board
ARM: dts: Remove combiner IRQ node from exynos4x12.dtsi
ARM: dts: add max8997 device node for exynos4210-origen board
ARM: dts: Enable TMU on Origen4210 board
ARM: dts: Add TMU clock entries to exynos4210.dtsi
ARM: dts: Update MFC documentation for clock entries
EXYNOS5440 includes both OHCI and EHCI usb host controllers.
This patch adds device tree nodes for both of them. And the
EHCI and OHCI controllers on exynos5440 do not need any
explicit phy configuration. So need to assign a different
compatible value for these controllers.
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
This patch adds dts support for the sata controller
RTC is a basic feature of EXYNOS5440. But it was disabled
by issue that comes from EXYNOS5250. (commit id: 522ccdb6)
That issue only applies to EXYNOS5250 not EXYNOS5440. So,
there is no issue with enabled RTC on EXYNOS5440. This
change was tested on EXYNOS5440.
Signed-off-by: Youngmin Nam <youngmin.nam@samsung.com>
This patch updates the in-kernel dts files according to the latest cpus
and cpu bindings updates for ARM.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Pull ARM SoC device tree updates (part 2) from Arnd Bergmann:
"These are mostly new device tree bindings for existing drivers, as
well as changes to the device tree source files to add support for
those devices, and a couple of new boards, most notably Samsung's
Exynos5 based Chromebook.
The changes depend on earlier platform specific updates and touch the
usual platforms: omap, exynos, tegra, mxs, mvebu and davinci."
* tag 'dt-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (169 commits)
ARM: exynos: dts: cros5250: add EC device
ARM: dts: Add sbs-battery for exynos5250-snow
ARM: dts: Add i2c-arbitrator bus for exynos5250-snow
ARM: dts: add mshc controller node for Exynos4x12 SoCs
ARM: dts: Add chip-id controller node on Exynos4/5 SoC
ARM: EXYNOS: Create virtual I/O mapping for Chip-ID controller using device tree
ARM: davinci: da850-evm: add SPI flash support
ARM: davinci: da850: override SPI DT node device name
ARM: davinci: da850: add SPI1 DT node
spi/davinci: add DT binding documentation
spi/davinci: no wildcards in DT compatible property
ARM: dts: mvebu: Convert mvebu device tree files to 64 bits
ARM: dts: mvebu: introduce internal-regs node
ARM: dts: mvebu: Convert all the mvebu files to use the range property
ARM: dts: mvebu: move all peripherals inside soc
ARM: dts: mvebu: fix cpus section indentation
ARM: davinci: da850: add EHRPWM & ECAP DT node
ARM/dts: OMAP3: fix pinctrl-single configuration
ARM: dts: Add OMAP3430 SDP NOR flash memory binding
ARM: dts: Add NOR flash bindings for OMAP2420 H4
This change makes the rtc on the exynos5250 and 5440 disabled by
default to match exynos4.
Ever since the common clock framework came in, exynos5250 boards
have dumped lots of warnings in the boot log. It turns out that
we don't see those on exynos4 since the rtc is disabled by default.
While we need to get to the bottom of the problems with the RTC,
it still makes sense to have the default state of the RTC on exynos
boards match.
For the record, warnings look like this:
WARNING: at drivers/clk/clk.c:771 __clk_enable+0x34/0xb0()
Modules linked in:
[<80015bfc>] (unwind_backtrace+0x0/0xec) from [<804717f0>] (dump_stack+0x20/0x24)
[<804717f0>] (dump_stack+0x20/0x24) from [<80023cd0>] (warn_slowpath_common+0x5c/0x7c)
[<80023cd0>] (warn_slowpath_common+0x5c/0x7c) from [<80023d1c>] (warn_slowpath_null+0x2c/0x34)
[<80023d1c>] (warn_slowpath_null+0x2c/0x34) from [<8035ddb0>] (__clk_enable+0x34/0xb0)
[<8035ddb0>] (__clk_enable+0x34/0xb0) from [<8035de54>] (clk_enable+0x28/0x3c)
[<8035de54>] (clk_enable+0x28/0x3c) from [<8031a160>] (s3c_rtc_probe+0xf4/0x434)
[<8031a160>] (s3c_rtc_probe+0xf4/0x434) from [<8028e288>] (platform_drv_probe+0x24/0x28)
[<8028e288>] (platform_drv_probe+0x24/0x28) from [<8028ce10>] (driver_probe_device+0xbc/0x22c)
[<8028ce10>] (driver_probe_device+0xbc/0x22c) from [<8028cff8>] (__driver_attach+0x78/0x9c)
[<8028cff8>] (__driver_attach+0x78/0x9c) from [<8028bdfc>] (bus_for_each_dev+0x64/0xac)
[<8028bdfc>] (bus_for_each_dev+0x64/0xac) from [<8028c7e0>] (driver_attach+0x28/0x30)
[<8028c7e0>] (driver_attach+0x28/0x30) from [<8028c43c>] (bus_add_driver+0xe0/0x234)
[<8028c43c>] (bus_add_driver+0xe0/0x234) from [<8028d55c>] (driver_register+0xac/0x13c)
[<8028d55c>] (driver_register+0xac/0x13c) from [<8028e4f4>] (platform_driver_register+0x54/0x68)
[<8028e4f4>] (platform_driver_register+0x54/0x68) from [<8065c944>] (s3c_rtc_driver_init+0x14/0x1c)
[<8065c944>] (s3c_rtc_driver_init+0x14/0x1c) from [<800086d8>] (do_one_initcall+0x60/0x138)
[<800086d8>] (do_one_initcall+0x60/0x138) from [<80633a8c>] (kernel_init_freeable+0x108/0x1d0)
[<80633a8c>] (kernel_init_freeable+0x108/0x1d0) from [<8046d2f8>] (kernel_init+0x1c/0xf4)
[<8046d2f8>] (kernel_init+0x1c/0xf4) from [<8000e358>] (ret_from_fork+0x14/0x20)
---[ end trace 4bcdc801c868d73f ]---
Signed-off-by: Doug Anderson <dianders@chromium.org>
PDMA0@0x121000 changes are added into the architecture DTS file.
Signed-off-by: Subash Patel <subash.rp@samsung.com>
Add cpufreq controller device node for Exynos5440 SoC for passing
parameters like controller base address, interrupt and cpufreq
table. This node is added outside cpu0 as this driver is now a platform
driver and a new device structure is needed.
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
The Exynos5440 common clock driver has changed the clock ID's for
some of the clocks. Fix the gmac clock entries in Exynos5440 dtsi
file accordingly.
PMU in exynos5440 generates one interrupt per core and needs to be
passed from DT to GIC to register it.
This patch adds node for GMAC for exynos5440 SoC supported by GMAC
driver.
Signed-off-by: Byungho An <bh74.an@samsung.com>
Exynos5440 pin-controller generates eight interrupts to support
gpio interrupts. List those interrupt numbers in the pin-controller
node.
Cc: Linus Walleij <linus.walleij@linaro.org>
Exynos5440 has GIC which has virtualization support
in them. These are used by KVM.
arch/arm/boot/dts/exynos4.dtsi
arch/arm/boot/dts/exynos5440.dtsi
