path: root/arch/arm/boot/dts/gemini-dlink-dir-685.dts
2019-02-12ARM: dts: Fix up the D-Link DIR-685 MTD partition infoLinus Walleij
[ Upstream commit 738a05e673435afb986b53da43befd83ad87ec3b ] The vendor firmware was analyzed to get the right idea about this flash layout. /proc/mtd contains: dev: size erasesize name mtd0: 01e7ff40 00020000 "rootfs" mtd1: 01f40000 00020000 "upgrade" mtd2: 00040000 00020000 "rgdb" mtd3: 00020000 00020000 "nvram" mtd4: 00040000 00020000 "RedBoot" mtd5: 00020000 00020000 "LangPack" mtd6: 02000000 00020000 "flash" Here "flash" is obviously the whole device and we know "rootfs" is a bogus hack to point to a squashfs rootfs inside of the main "upgrade partition". We know "RedBoot" is the first 0x40000 of the flash and the "upgrade" partition follows from 0x40000 to 0x1f8000. So we have mtd0, 1, 4 and 6 covered. Remains: mtd2: 00040000 00020000 "rgdb" mtd3: 00020000 00020000 "nvram" mtd5: 00020000 00020000 "LangPack" Inspecting the flash at 0x1f8000 and 0x1fa000 reveals each of these starting with "RGCFG1" so we assume 0x1f8000-1fbfff is "rgdb" of 0x40000. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2017-08-08ARM: dts: gemini: add pin control set-up for the SoCLinus Walleij
This adds the basic pin control muliplexing settings for the Gemini SoC: parallel (NOR) flash, SATA, optional IDE, PCI and UART. We also select the right GPIO groups on all applicable systems so that GPIO keys/LEDs work smoothly. We can then build upon this for more complex systems. Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-08-08ARM: dts: Add DTS file for D-Link DIR-685Linus Walleij
This adds a device tree file for the Gemini-based D-Link DIR-685 router, supporting all devices that are currently supported in the main DTSI SoC file. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
