[ Upstream commit fc5b59b945b546e27977e99a5ca6fe61179ff0d2 ]
ethernet-phy is not the right name for mdio, fix it.
Signed-off-by: Corentin Labbe <clabbe@baylibre.com>
The 50ms debounce is too low and give ghost bounces on some
platforms. Bump it to 100ms to make it stable.
This adds the FOTG210 USB host controller to the Gemini
device trees. In the main SoC DTSI it is flagged as disabled
and then it is selectively enabled on the devices that utilize
it.
The DTC was warning a lot about unit names etc, I think I fixed
them all. Stopping to include skeleton.dtsi fixes the last one.
"debounce_interval" was never supported.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: Linus Walleij <linus.walleij@linaro.org>
These platforms have the PHY defined already so we just
need to add a single device node to each of them to activate
the ethernet device.
The PHY skew/delay settings for pin control is known from a
few vendor trees and old OpenWRT patch sets.
These two boards have mini-PCI card slots, so enable PCI
on both of them.
These Gemini boards have Ethernet PHY on GPIO bit-banged
MDIO, clearly defined in the corresponding OpenWRT
ethernet patches since ages. Add them in accordance with
the OpenWRT patch so we can use them when we add ethernet
support.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This adds the basic pin control muliplexing settings for the
Gemini SoC: parallel (NOR) flash, SATA, optional IDE, PCI and
UART.
We also select the right GPIO groups on all applicable systems
so that GPIO keys/LEDs work smoothly.
We can then build upon this for more complex systems.
Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
This devicetree is simply based on the board file in
arch/arm/mach-gemini/board-wbd222.c and contain the
equivalent platform data, mainly just moving the GPIOs
from the global numberspace to explicitly reference their
parent GPIO.
Cc: Janos Laube <janos.dev@gmail.com>
Cc: Paulius Zaleckas <paulius.zaleckas@gmail.com>
Cc: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
