path: root/arch/arm/boot/dts/hi3620-hi4511.dts
2015-10-09ARM: hisilicon: DT: Drop console= and earlyprintk bootargs parameterWei Xu
Replace console with stdout-path so that we don't have to put the console on the kernel command line. Remove earlyprintk to allow the kernel to boot on a system even if DEBUG_LL is configured for another system. Signed-off-by: Wei Xu <xuwei5@hisilicon.com>
2013-12-20ARM: dts: rename hi4511 dts fileHaojian Zhuang
We want to follow the name style of DTS that is SoC-board.dts. Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
