path: root/arch/arm/boot/dts/imx1-apf9328.dts
2016-06-11ARM: dts: imx: Use generic uart-has-rtscts DT propertyGeert Uytterhoeven
As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts DT property"), the Freescale IMX UART driver recognizes the generic "uart-has-rtscts" DT property, deprecating the vendor-specific "fsl,uart-has-rtscts" DT property. Hence replace the latter by the former in all DTS files. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2014-09-16ARM: dts: Add support for the i.MX1 Armadeus APF9328 boardAlexander Shiyan
This patch adds support for the i.MX1 APF9328 from Armadeus. This change is intended to further remove non-DT support for this board. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
