The dr_mode of usb0 on imx233-olinuxino is left to default "otg".
Since the green LED (GPIO2_1) on imx233-olinuxino is connected to the
same pin as USB_OTG_ID it's possible to disable USB host by LED toggling:
echo 0 > /sys/class/leds/green/brightness
[ 1068.890000] ci_hdrc ci_hdrc.0: remove, state 1
[ 1068.890000] usb usb1: USB disconnect, device number 1
[ 1068.920000] usb 1-1: USB disconnect, device number 2
[ 1068.920000] usb 1-1.1: USB disconnect, device number 3
[ 1069.070000] usb 1-1.2: USB disconnect, device number 4
[ 1069.450000] ci_hdrc ci_hdrc.0: USB bus 1 deregistered
[ 1074.460000] ci_hdrc ci_hdrc.0: timeout waiting for 00000800 in 11
This patch fixes the issue by setting dr_mode to "host" in the dts file.
Reported-by: Harald Geyer <harald@ccbib.org>
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Acked-by: Peter Chen <peter.chen@freescale.com>
Fixes: b49312948285 ("ARM: dts: imx23-olinuxino: Add USB host support")
Cc: stable@vger.kernel.org
On imx23-olinuxino the LED turns on when level logic high is aplied to
GPIO2_1.
Fix the gpios property accordingly.
Fixes: b34aa1850244 ("ARM: dts: imx23-olinuxino: Remove unneeded "default-on"")
Reported-by: Stefan Wahren <stefan.wahren@i2se.com>
Tested-by: Stefan Wahren <stefan.wahren@i2se.com>
The device tree specification recommends that generic name should be
used for nodes. So instead of naming those fixed regulator nodes
arbitrarily, let's use the generic name 'regulator@num' for those nodes.
Convert mx23/mx28 dts files to use the padconfig defintions from
mxs-pinfunc.h.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Convert mx23/mx28 dts filed to use the pinctrl header files.
NOTE: During automatic conversion of these files to use the pinconfig
definitions an inconsistency has been found in:
arch/arm/boot/dts/imx28-apx4devkit.dts
According to the comment the function for pad SSP2_SS0 should have
been MX28_PAD_SSP2_SS0__GPIO_2_19, while the given value 0x2131
represents: MX28_PAD_SSP2_SS0__AUART3_TX
I used the later (though probably wrong) definition because that's
what is actually being used in the DTB.
The i.MX23 has a internal Low Resolution ADC; this enables the support
for this device.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
The imx23-olinuxino sdcard doesn't have card detect.
Signed-off-by: Alexandre Pereira da Silva <aletes.xgr@gmail.com>
On the imx23-olinuxino board GPIO2_1 is connected to the LED and GPIO0_17
is the USB PHY reset.
So make the IOMUX assignment properly.
imx23-olinuxino board has spi pins exposed on external connector.
This patch add spi support.
Signed-off-by: Fadil Berisha <f.koliqi@gmail.com>
Since commit 8fe4554f (leds: leds-gpio: adopt pinctrl support) gpio-led driver
has pinctrl support, so setup the gpio led pin via pinctrl and avoid the
following warning:
leds-gpio leds.5: pins are not configured from the driver
The initial state of the gpio led can be set directly in "gpios" node.
Hence, linux,default-trigger can be removed.
Add USB host support.
Olinuxino has a LED connected to MX23_PAD_SSP1_DETECT__GPIO_2_1 pin.
Add support for it.
Add AUART0 support.
mx23-olinuxino is a low cost board designed by Olimex.
It has the following features:
- Freescale iMX233 ARM926J processor at 454MHz
-64 MB RAM
-SD-card connector
-TV PAL/NTSC video output
-2 USB High Speed Hosts
-Ethernet 100 Mbit
-Stereo Audio Input
-Stereo Headphones Audio Output
More information at:
http://www.olimex.com/dev/imx233-olinuxino-maxi.html
