commit cf75eb15be2bdd054a76aeef6458beaa4a6ab770 upstream.
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Add support for the CLAA057VC01CW display.
Tested by loading the g_ether module and doing a ping between mx25pdk and the
host PC via USB.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
The DAI mode is and should be configured by the sound card driver as
codec and ssi have to be in the right modes to communicate with each
other. It is possible to operate the ssi unit or the codec in master mode,
sometimes even on the same board in different configurations.
With the latest changes in the fsl-ssi driver, the 'fsl,mode' property
is only handled as a fallback property. If the sound card sets the DAI
mode correctly, this fallback configuration is dropped.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Tested with evtest.
mx25pdk has a sgtl5000 codec connected to the I2C1 port.
Add support for it.
GPIO4_8 is connected to the Ethernet PHY reset line, so populate the
'phy-reset-gpios' property accordingly.
GPIO2_3 controls the power to the Ethernet PHY, so provide a regulator node
for this.
Instead of relying on the bootloader for configuring the FEC pins, pass the
FEC pin configuration via device tree instead.
UART1 is the console port on mx25pdk board.
Add the pin configuration for UART1 port and also pass 'fsl,uart-has-rtscts'
to indicate that the port has RTS and CTS pins.
Keep the dt nodes sorted for better readability.
Replace /include/ (dtc) with #include (C pre-processor) for all imx DT
files, so that gcc -E handles the entire include tree, and hence any of
those files can #include some other file e.g. for constant definitions.
This allows future use of #defines and header files in order to define
names for various constants, such as pinctrl settings. Use of those
features will increase the readability of the device tree files.
Add basic device tree support for mx25pdk board.
