Move the native-mode property inside the display-timings node.
According to
Documentation/devicetree/bindings/display/panel/display-timing.txt.
native-mode is a property of the display-timings node.
If it's located outside of display-timings, the native-mode setting is
ignored and the first display timing is used (which is a problem only if
someone adds another display timing).
Signed-off-by: Martin Kaiser <martin@kaiser.cx>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Boards based on imx25 have duplicate memory nodes:
- One coming from the board dts file: memory@
- One coming from the imx25.dtsi file.
Fix the duplication by removing the memory node from the dtsi file
and by adding 'device_type = "memory";' in the board dts.
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Adopt the SPDX license identifier headers to ease license compliance
management.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
The 'codec-handle' property is an optional one and there is really
no need to be used here.
As per the comment in the fsl_ssi driver:
"Backward compatible for older bindings by manually triggering the
machine driver's probe()."
,so just remove such uneeded property.
This file had several naming inconsistencies for eSDHC:
- the instances were named sometimes SDn, sometimes SDHCn, whereas they
are named ESDHCn in the reference manual, e.g.:
MX25_PAD_SD1_CMD__SD1_CMD
MX25_PAD_D15__SDHC1_DAT7
- the data ports were named sometimes DATAn, sometimes DATn like in the
MX25_PAD_SD1_DATA0__SD1_DATA0
- in one case, the clock port was named DAT_CLK instead of CLK:
MX25_PAD_CSI_D7__SDHC2_DAT_CLK
This change:
- introduces new definitions using the naming from the reference
manual,
- keeps definitions using the legacy naming in order not to break
compatibility for out-of-tree users (they can be removed later),
- updates the in-tree files that were using the legacy naming.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Rob Herring <robh@kernel.org>
Fix the following warnings from dtc by adding the unit name to memory
nodes:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
Converted using the following command:
perl -p0777i -e 's/memory \{\n\t\treg = \<0x+([0-9a-f])/memory\@$1$\0000000 \{\n\t\treg = <0x$1/m' `find ./arch/arm/boot/dts -name "imx*"`
The files below were manually fixed:
-imx1-ads.dts
-imx1-apf9328.dts
-imx6q-pistachio.dts
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/dt
Pull "i.MX device tree updates for 4.15" from Shawn Guo:
- New board support: i.MX51 ZII RDU1, i.MX53 GE Healthcare PPD, i.MX6
TX modules for MB7 from Ka-Ro Electronics, i.MX6 Wandboard revd1
variants, i.MX6 LWN DISPLAY5 board, Pistachio i.MX6Q board, i.MX6SX
Vining-2000 board.
- Use the 'vpcie-supply' property for PCIe device for boards
imx6qdl-sabresd, imx6q-novena and imx6q-cm-fx6.
- A series from Jagan Teki to update imx6qdl-icore board with audio,
touch and CAN support.
- Switch to nvmem for accessing OCOTP from tempmon for i.MX6SX and add
tempmon support for i.MX6UL.
- A bunch of patches from Lothar Waßmann updating Ka-Ro i.MX28, i.MX53
and i.MX6 TX modules.
- Fix DTC warnings in i.MX device trees, dropping leading zeros from
unit address, correcting display nodes notation and display port
names, fixing nodes with unit name and no reg property.
- Other random device updates for various board support.
* tag 'imx-dt-4.15' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (63 commits)
ARM: dts: imx53-tx53: fix interrupt flags
ARM: dts: imx28-tx28: fix interrupt flags
ARM: dts: display5: Device tree description of LWN's DISPLAY5 board
ARM: dts: imx53-qsb-common: Fix 'led_gpio7_7@0' node with unit name and no reg property
ARM: dts: imx53-m53evk: Fix 'led_gpio@0' node with unit name and no reg property
ARM: dts: imx53: Fix 'usbphy@x' node with unit name and no reg property
ARM: dts: imx51-ts4800: Fix 'port@0' node with unit name and no reg property
ARM: dts: imx51-apf51dev: Fix 'backlight@bl1' node with unit name and no reg property
ARM: dts: imx: add ZII RDU1 board
ARM: dts: imx: add support for TX6 modules on MB7 baseboard
ARM: dts: imx: add support for TX6QP
ARM: dts: imx6-tx6: add a .dtsi file for the MB7 baseboard
ARM: dts: imx6-tx6: move display configuration to .dtsi file
ARM: dts: imx6-tx6: add support for I2C bus recovery
ARM: dts: imx6-tx6: convert to using simple-audio-card
ARM: dts: imx6-tx6: specify ethernet phy reset post-delay
ARM: dts: imx6-tx6: improve ethernet related pinctrl setup
ARM: dts: imx6-tx6: add trickle-charge config for DS1339
ARM: dts: imx6-tx6: remove obsolete ipu1 alias
ARM: dts: imx6-tx6: remove obsolete eeti,egalax_ts
[arnd: made sure we have no new leading zeroes in unit address during merge]
Fix dtc warnings for 'simple_bus_reg' due to leading 0s. Converted using
perl -p -i -e 's/\@0+([0-9a-f])/\@$1/g' `find arch/arm/boot/dts -type -f -name '*.dts*'
Dropped changes to ARM, Ltd. boards LED nodes and manually fixed up some
occurrences of uppercase hex.
Signed-off-by: Rob Herring <robh@kernel.org>
Add support for the built-in touchscreen controller present on MX25.
The FEC driver ignores the GPIO polarity from 'phy-reset-gpios' and
considers that the Ethernet PHY is active low, unless the
property 'phy-reset-active-high' is present.
Fix the device tree description by explicitly passing the
'GPIO_ACTIVE_LOW' flag to the 'phy-reset-gpios' property.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
All currently supported i.MX25-based machines use phy_type = "utmi" and
dr_mode = "otg". So this seems to be a sensible default.
This also doesn't hurt out-of-tree machines because up to now they had
to specify these two properties in the machine.dts which still takes
precedence by just overwriting the defaults added here.
As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts
DT property"), the Freescale IMX UART driver recognizes the generic
"uart-has-rtscts" DT property, deprecating the vendor-specific
"fsl,uart-has-rtscts" DT property. Hence replace the latter by the
former in all DTS files.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Add support for the CLAA057VC01CW display.
Tested by loading the g_ether module and doing a ping between mx25pdk and the
host PC via USB.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
The DAI mode is and should be configured by the sound card driver as
codec and ssi have to be in the right modes to communicate with each
other. It is possible to operate the ssi unit or the codec in master mode,
sometimes even on the same board in different configurations.
With the latest changes in the fsl-ssi driver, the 'fsl,mode' property
is only handled as a fallback property. If the sound card sets the DAI
mode correctly, this fallback configuration is dropped.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Tested with evtest.
mx25pdk has a sgtl5000 codec connected to the I2C1 port.
Add support for it.
GPIO4_8 is connected to the Ethernet PHY reset line, so populate the
'phy-reset-gpios' property accordingly.
GPIO2_3 controls the power to the Ethernet PHY, so provide a regulator node
for this.
Instead of relying on the bootloader for configuring the FEC pins, pass the
FEC pin configuration via device tree instead.
UART1 is the console port on mx25pdk board.
Add the pin configuration for UART1 port and also pass 'fsl,uart-has-rtscts'
to indicate that the port has RTS and CTS pins.
Keep the dt nodes sorted for better readability.
Replace /include/ (dtc) with #include (C pre-processor) for all imx DT
files, so that gcc -E handles the entire include tree, and hence any of
those files can #include some other file e.g. for constant definitions.
This allows future use of #defines and header files in order to define
names for various constants, such as pinctrl settings. Use of those
features will increase the readability of the device tree files.
Add basic device tree support for mx25pdk board.
