Based on 1 normalized pattern(s):
the code contained herein is licensed under the gnu general public
license you may obtain a copy of the gnu general public license
version 2 or later at the following locations http www opensource
org licenses gpl license html http www gnu org copyleft gpl html
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 161 file(s).
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.383790741@linutronix.de
Boards based on imx27 have duplicate memory nodes:
- One coming from the board dts file: memory@
- One coming from the imx27.dtsi file.
Fix the duplication by removing the memory node from the dtsi file
and by adding 'device_type = "memory";' in the board dts.
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Instead of copying the whole node hierarchy, let's define a label for
clock osc26m in soc dtsi and use it for overriding clock-frequency.
Fix the following warnings from dtc by adding the unit name to memory
nodes:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
Converted using the following command:
perl -p0777i -e 's/memory \{\n\t\treg = \<0x+([0-9a-f])/memory\@$1$\0000000 \{\n\t\treg = <0x$1/m' `find ./arch/arm/boot/dts -name "imx*"`
The files below were manually fixed:
-imx1-ads.dts
-imx1-apf9328.dts
-imx6q-pistachio.dts
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Per bindings of fixed-clock, #clock-cells is a required property. Let's
add it for those fixed rate clocks.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Signed-off-by: Gwenhael Goavec-Merou <gwenhael.goavec-merou@armadeus.com>
Replace /include/ (dtc) with #include (C pre-processor) for all imx DT
files, so that gcc -E handles the entire include tree, and hence any of
those files can #include some other file e.g. for constant definitions.
This allows future use of #defines and header files in order to define
names for various constants, such as pinctrl settings. Use of those
features will increase the readability of the device tree files.
Following omap3-evm.dts way, it changes all imx dts files to use label
in board dts to refer to nodes defined by soc dtsi. Thus, the board
dts files become easier to read and edit with the least indentation
levels.
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
Signed-off-by: Eric Jarrige <eric.jarrige@armadeus.org>
