path: root/arch/arm/boot/dts/imx27-phytec-phycore-rdk.dts
2019-08-12ARM: dts: imx27-phytec-phycore-rdk: native-mode is part of display-timingsMartin Kaiser
Move the native-mode property inside the display-timings node. According to Documentation/devicetree/bindings/display/panel/display-timing.txt. native-mode is a property of the display-timings node. If it's located outside of display-timings, the native-mode setting is ignored and the first display timing is used (which is a problem only if someone adds another display timing). Signed-off-by: Martin Kaiser <martin@kaiser.cx> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 159Thomas Gleixner
Based on 1 normalized pattern(s): the code contained herein is licensed under the gnu general public license you may obtain a copy of the gnu general public license version 2 or later at the following locations http www opensource org licenses gpl license html http www gnu org copyleft gpl html extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 161 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Richard Fontana <rfontana@redhat.com> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070033.383790741@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-26ARM: dts: imx: Add missing #phy-cells to usb-nop-xceivRob Herring
"usb-nop-xceiv" is using the phy binding, but is missing #phy-cells property. This is probably because the binding was the precursor to the phy binding. Fixes the following warning in i.MX dts files: Warning (phys_property): Missing property '#phy-cells' in node ... Signed-off-by: Rob Herring <robh@kernel.org> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-02ARM: dts: imx: remove obsoleted property fsl,spi-num-chipselectsVladimir Zapolskiy
Since commit b36581df7e78 ("spi: imx: Using existing properties for chipselects") the device tree property 'fsl,spi-num-chipselects' is unused and it is already marked as obsolete in device tree binding documentation. Remove the property from the existing DTS files to avoid its reoccurence on copying. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-06-11ARM: dts: imx: Use generic uart-has-rtscts DT propertyGeert Uytterhoeven
As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts DT property"), the Freescale IMX UART driver recognizes the generic "uart-has-rtscts" DT property, deprecating the vendor-specific "fsl,uart-has-rtscts" DT property. Hence replace the latter by the former in all DTS files. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2014-07-18ARM: i.MX27 clk: dts: Use clock defines in DTS filesAlexander Shiyan
Use clock definitions in i.MX27 DTS files. Additional changes included in this patch (imx27.dtsi): - Fix IPG clock for UART6. - Use EMI_AHB_GATE clock for WEIM. - Added GPIO_IPG_GATE clock for GPIO nodes. Currently this clock is not used by the driver, but it can be added in the future. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: Add stdout-path property to i.MX boardsSascha Hauer
This adds the stdout-path property to various i.MX boards. Values of the property have been taken from barebox, so they should be correct. Also, the older linux,stdout-path property is converted to stdout-path. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: imx27-phytec-phycore-rdk: Fix "reg" property for USBH2 PHYAlexander Shiyan
2014-05-16ARM: dts: imx27-phytec-phycore-rdk: Add CSI enable switchAlexander Shiyan
This patch adds a GPIO fixed regulator which used on RDK to enable CSI bus. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: imx27-phytec-phycore-rdk: Remove duplicate entries for USB PHYAlexander Shiyan
"compatible", "#address-cells" and "#size-cells" for USB PHY are already described in the SOM DTS. Remove these duplicate entries. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: imx27: Place the usb phy nodes in the board dts filesFabio Estevam
It is not a good approach to have the USB PHY nodes inside imx27.dtsi since the USB PHYs on mx27 are not internal to the SoC. Place the USB PHY nodes in the board dts files instead. Also, each board may have a different clock source for the USB PHY, so do not hardcode it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: i.MX: Use single naming style for i.MX WEIM deviceAlexander Shiyan
This patch converts all i.MX WEIM users to use single naming style for devices. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: imx27-phytec-phycore-rdk: Add display control signal definitionsAlexander Shiyan
This patch adds display control signal definitions. These fields are not used in the driver yet, but will be used for reference to indicate the polarity of the signals. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: imx27-phytec-phycore-rdk: Add display supportAlexander Shiyan
This patch adds FB, Sharp-LQ035Q7 display (add-on module) and corresponded pinctrl devicetree nodes to the Phytec PCM970 RDK. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-04-30ARM: dts: imx27-phytec-phycore-rdk: Add missing pinctrl definition for SPI CS1Alexander Shiyan
This patch adds missing pinctrl definition for SPI chipselect 1. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-24ARM: dts: imx27-phytec-phycore-rdk: Add USBH2 nodeAlexander Shiyan
This patch adds USBH2 devicetree node of Phytec PCM970 RDK. Additionally, adds fixed regulator to provide functionality without dummy-regulator in the kernel. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-17ARM: dts: imx27-phytec-phycore: Add diagnostic PMIC LEDsAlexander Shiyan
PCM-038 module have three triple LEDs connected to PMIC which can be used for diagnostic purposes. This patch adds support for these LEDs for PCM-038 SOM and adds basic LED-triggers for these LEDs for PCM-970 RDK, the remaining LEDs are available for use from userspace. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: imx27-phytec-phycore-rdk: Add pinctrl definitions for WEIMAlexander Shiyan
This patch adds pinctrl definitions for WEIM CS4 and GPIO used as CAN IRQ line. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: imx27-phytec-phycore-rdk: Add pingrp for SDHCAlexander Shiyan
2014-02-09ARM: dts: imx27-phytec-phycore-rdk: Enable 1-Wire moduleAlexander Shiyan
This patch enables 1-Wire module for Phytec PCM-970 RDK. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: imx27-phytec-phycore-som: Rename file to .dtsiAlexander Shiyan
PCM-038 module cannot be used standalone. This patch renames module file to .dtsi and excludes it from compilation. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: i.MX27 boards: Switch to use standard GPIO and IRQ flags definitionsAlexander Shiyan
2014-02-09ARM: dts: imx27-phytec-phycore-rdk: Add DT node for camera moduleAlexander Shiyan
This patch adds first I2C bus and PCA9536 device. This device is used on Phytec PCM-970 RDK camera addon module. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: imx27 phycore pinctrlMarkus Pargmann
Add pinctrl nodes and properties for phycore device nodes. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: imx27 phycore move uart1 to rdkMarkus Pargmann
uart1 is not used on SOM. It is passed directly to the rdk board. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: imx27-phytec-phycore-rdk: Add CAN nodeAlexander Shiyan
This patch adds CAN (NXP SJA1000) node for Phytec PCM-970 RDK. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: dts: imx27-phytec-phycore-rdk: Add SDHC supportAlexander Shiyan
This patch adds the SHDC devicetree node for PCM970 board. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Sascha Hauer <s.hauer@pengutonix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: dts: imx27-phytec-phycore-som: Add initial support for PCM970 RDKAlexander Shiyan
Patch adds initial dts for Phytec PCM970 Rapid development kit. - Added definition for UART0 and UART1. - Added additional SPI chipselect which used on RDK for ZegBee module. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
