Pull ARM DT updates from Arnd Bergmann:
"A total of 380 patches this time, mostly adding support for more
hardware in the device tree descriptions. There is not much exciting
here for 4.11, but I've tried my best to condense the information from
the pull requests I got into a readable summary.
Noteworthy changes to existing platforms include:
- The GIC memory map was a bit wrong almost everywhere and now gets
fixed up
- The Allwinner platforms convert to the generic pinmux properties
- The Marvell EBU platforms now use the new DSA binding
- Samsung Exynos4212 was unused and gets removed
- The Renesas power management got improved
New production machines:
- Lego Mindstorms EV3:
https://www.lego.com/en-us/mindstorms/about-ev3
- Beelink X2 Android media box:
http://linux-sunxi.org/Beelink_X2
- "Romulus" baseboard management controller for OpenPower
- Axentia TSE-850 Data Radio Channel (DARC) encoder:
http://www.axentia.se/db/equipment.html
- Luxul XAP-1410 and XWR-1200 wireless access points:
https://luxul.com/xap-1410
New SoCs:
- Allwinner H2+ and V3s, both minor variations of already supported
chips:
http://www.allwinnertech.com/index.php?c=product&a=index&id=38
- Marvell Prestera DX packet processors based on Armada XP
architecture:
http://www.marvell.com/switching/prestera-dx/
- Samsung Exynos4412 Prime gets added, a minor variation of
Exynos4412
New developer and reference boards:
- Lichee Pi One, Lichee Pi Zero and Orange Pi Zero, all based on
Allwinner SoCs:
http://linux-sunxi.org/LicheePi_One
http://www.orangepi.org/orangepizero/
- SAMA5d36ek Reference platform:
http://www.atmel.com/tools/sama5d36-ek.aspx
- Beaglebone Green Wireless and Black Wireless:
https://beagleboard.org/black-wireless
https://beagleboard.org/green-wireless
- phyCORE-AM335x System on Module:
http://phytec.com/products/system-on-modules/phycore/am335x/
- New revision of "vf610-zii" Zodiac Inflight Innovations board
- Various i.MX System-on-Module: Is.IoT MX6UL, SavageBoard, Engicam
i.Core:
http://www.opossom.com/english/index.html
http://www.savageboard.org/
http://www.engicam.com/en/products/embedded/som/sodimm/is-iot-mx6ul
http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q
- Liebherr (LWN) monitor 6 based on i.MX6 Quad, no idea what this is
- Cleanups and bugfixes on at91, bcm53xx, i.MX, mvebu, omap, oxnas,
qcom, rockchip, sti, stm32 and tegra
New device supports added to some boards and SoCs, briefly by platform:
- Allwinner: SPDIF, A33 cpufreq, A33 Mali GPU
- Aspeed: network, ipmi bt, gpio, pinmux
- Broadcom: video encoder for raspberry pi, qspi, ethernet, sd/mmc
- TI DaVinci: gpio, lcdc, usb, video-in, uart
- TI Keystone 2: MSM RAM, power/reset, uart
- Mediatek MT2701: clocks, iommu, spi, nand, adc, thermal
- Marvell EBU: ethernet switch on Turris Omnia
- NXP i.MX: otp ram, USB, wifi, bluetooth, spdif, spi, pmic, eeprom,
mmc, nand
- TI OMAP:
- Qualcomm: coresight, gyro/accelerometer, hdmi
- Renesas: pmic, soc-id
- Rockchip: qos
- Samsung: audio on Odroid-X
- Socfpga: FPGA manager, i2c, led, can, watchdog, nand, power monitor
- STi: video in/out
- STM32: timer, pwm, i2c, rtc, add, i2s
- NVIDIA Tegra: tpm
- Uniphier: mmc/sd pinmux"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (380 commits)
ARM: dts: armada-385-linksys: fix DSA compatible property
ARM: dts: Fix typo in armada-xp-98dx4251
ARM: DTS: Fix register map for virt-capable GIC
dt-bindings: arm,gic: Fix binding example for a virt-capable GIC
ARM: dts: sun8i: sinlinx: Enable audio nodes
ARM: dts: sun8i: parrot: Enable audio nodes
ARM: dts: sun8i: Add audio codec, dai and card for A33
ARM: dts: Add EMAC AXI settings for Arria10
ARM: dts: am335x-chiliboard: Support charger
ARM: dts: am335x-chiliboard: Support power button
ARM: sun8i: dt: Add mali node
dt-bindings: gpu: Add Mali Utgard bindings
ARM: dts: stm32: Add I2C1 support for STM32429 eval board
ARM: dts: stm32: Add I2C1 support for STM32F429 SoC
ARM: dts: stm32: Use clock DT binding definition on stm32f429 family
dt-bindings: mfd: stm32f4: Add missing binding definition
dt-bindings: mfd: stm32f4: Fix STM32F4_X_CLOCK() macro
ARM: dts: stm32: Enable pwm1 and pwm3 for stm32f469-disco
ARM: dts: stm32: add Timers driver for stm32f429 MCU
ARM: dts: add the AB8500 sysclk to the device trees
Commit 7f107887d199 ("ARM: dts: imx: Remove skeleton.dtsi") causes boot
issues when the bootloader does not create a 'chosen' node if such node
is not present in the dtb.
The reason for the boot failure is well explained by Javier Martinez
Canillas: "the decompressor relies on a pre-existing chosen node to be
available to insert the command line and merge other ATAGS info."
, so pass an empty 'chosen' node to fix the boot problem.
This issue has been seen in the kernelci reports with Barebox as
bootloader.
Also pass the 'memory' node in order to fix boot issues on the SolidRun
iMX6 platforms.
Fixes: 7f107887d199 ("ARM: dts: imx: Remove skeleton.dtsi")
Reported-by: kernelci.org bot <bot@kernelci.org>
Reported-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Make CPU nodes consistent throughout the i.MX dts files, which
also matches the description from ePAPR spec.
This also fixes the following W=1 warning in some cases:
Warning (unit_address_vs_reg): Node /cpus/cpu@0 has a unit name, but no reg property
As explained by commit 9c0da3cc61f1233c ("ARM: dts: explicitly mark
skeleton.dtsi as deprecated"), including skeleton.dtsi is deprecated.
This fixes the following warning with W=1:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
For imx27, it needs three clocks to let the controller work,
the old code is wrong, and usbmisc has not included clock handling
code any more. Without this patch, it will cause below data
abort when accessing usbmisc registers.
usbcore: registered new interface driver usb-storage
Unhandled fault: external abort on non-linefetch (0x008) at 0xf4424600
pgd = c0004000
[f4424600] *pgd=10000452(bad)
Internal error: : 8 [#1] PREEMPT ARM
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 4.1.0-next-20150701-dirty #3089
Hardware name: Freescale i.MX27 (Device Tree Support)
task: c7832b60 ti: c783e000 task.ti: c783e000
PC is at usbmisc_imx27_init+0x4c/0xbc
LR is at usbmisc_imx27_init+0x40/0xbc
pc : [<c03cb5c0>] lr : [<c03cb5b4>] psr: 60000093
sp : c783fe08 ip : 00000000 fp : 00000000
r10: c0576434 r9 : 0000009c r8 : c7a773a0
r7 : 01000000 r6 : 60000013 r5 : c7a776f0 r4 : c7a773f0
r3 : f4424600 r2 : 00000000 r1 : 00000001 r0 : 00000001
Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 0005317f Table: a0004000 DAC: 00000017
Process swapper (pid: 1, stack limit = 0xc783e190)
Stack: (0xc783fe08 to 0xc7840000)
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Reported-by: Fabio Estevam <fabio.estevam@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Cc: <stable@vger.kernel.org> #v4.1+
Acked-by: Shawn Guo <shawnguo@kernel.org>
Pull ARM DT updates from Olof Johansson:
"Ladies and gentlemen, we proudly announce to you the latest branch of
ARM device tree contents for the mainline kernel. Come and see, come
and see!
No less than twentythree thousand lines of additions! Just imagine the
joy you will have of using your mainline kernel on newly supported
hardware such as Rockchip Chromebooks, Freescale i.MX6UL boards or
UniPhier hardware!
For those of you feeling less adventurous, added hardware support on
platforms such as TI DM814x and Gumstix Overo platforms might be more
of your liking.
We've got something for everyone here!
Ahem. Cough. So, anyway...
This is the usual large batch of DT updates. Lots and lots of smaller
changes, some of the larger ones to point out are:
- Rockchip veyron (Chromebook) support, as well as several other new boards
- DRM support on Atmel AT91SAM9N12EK
- USB additions on some Allwinner platforms
- Mediatek MT6580 support
- Freescale i.MX6UL support
- cleanups for Renesas shmobile platforms
- lots of added devices on LPC18xx
- lots of added devices and boards on UniPhier
There's also some dependent code added here, in particular some
branches that are primarily merged through the clock tree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (389 commits)
ARM: tegra: Add gpio-ranges property
ARM: tegra: Fix AHB base address on Tegra20, Tegra30 and Tegra114
ARM: tegra: Add Tegra124 PMU support
ARM: tegra: jetson-tk1: Add GK20A GPU DT node
ARM: tegra: venice2: Add GK20A GPU DT node
ARM: tegra: Add IOMMU node to GK20A
ARM: tegra: Add CPU regulator to the Jetson TK1 device tree
ARM: tegra: Add entries for cpufreq on Tegra124
ARM: tegra: Enable the DFLL on the Jetson TK1
ARM: tegra: Add the DFLL to Tegra124 device tree
ARM: dts: zynq: Add devicetree entry for Xilinx Zynq reset controller.
ARM: dts: UniPhier: fix PPI interrupt CPU mask of timer nodes
ARM: dts: rockchip: correct regulator power states for suspend
ARM: dts: rockchip: correct regulator PM properties
ARM: dts: vexpress: Use assigned-clock-parents for sp810
pinctrl: tegra: Only set the gpio range if needed
arm: boot: dts: am4372: add ARM timers and SCU nodes
ARM: dts: AM4372: Add the am4372-rtc compatible string
ARM: shmobile: r8a7794 dtsi: Add CPG/MSTP Clock Domain
ARM: shmobile: r8a7793 dtsi: Add CPG/MSTP Clock Domain
Add support of internal rtc on imx27.
Signed-off-by: Philippe Reynes <tremyfr@gmail.com>
include/soc/imx/timer.h describes well the different versions of
the GPT block among the imx family:
enum imx_gpt_type {
GPT_TYPE_IMX1, /* i.MX1 */
GPT_TYPE_IMX21, /* i.MX21/27 */
GPT_TYPE_IMX31, /* i.MX31/35/25/37/51/6Q */
GPT_TYPE_IMX6DL, /* i.MX6DL/SX/SL */
So the proper compatible string for the MX27 case should be
"fsl,imx21-gpt".
Reviewed-by: Philippe Reynes <tremyfr@gmail.com>
According to the imx27 documentation, fec has a 4 Kbyte
memory space map. Moreover, the actual 16 Kbyte mapping
overlaps the SCC (Security Controller) memory register
space. So, we reduce the memory register space to 4 Kbyte.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Fixes: 9f0749e3eb88 ("ARM i.MX27: Add devicetree support")
The chipidea driver adds an extra line of spam to the log when a
host-only chipidea instance is left set to the default of a dual role
controller.
[ 2.010873] ci_hdrc ci_hdrc.1: doesn't support gadget
Set the dr_mode property to host on all the host-only nodes
to avoid this warning.
Signed-off-by: Matt Porter <mporter@konsulko.com>
Acked-by: Peter Chen <peter.chen@freescale.com>
Update the VPU compatible strings to also use "cnm,coda<model>".
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Use clock definitions in i.MX27 DTS files.
Additional changes included in this patch (imx27.dtsi):
- Fix IPG clock for UART6.
- Use EMI_AHB_GATE clock for WEIM.
- Added GPIO_IPG_GATE clock for GPIO nodes. Currently this clock is
not used by the driver, but it can be added in the future.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
It is not a good approach to have the USB PHY nodes inside imx27.dtsi since
the USB PHYs on mx27 are not internal to the SoC.
Place the USB PHY nodes in the board dts files instead.
Also, each board may have a different clock source for the USB PHY, so do not
hardcode it.
USB Host1, Host2 and OTG are gated via 'usb_ipg_gate' clock, so fix it in order
to avoid the following kernel oops:
10024000.usb supply vbus not found, using dummy regulator
Unhandled fault: external abort on non-linefetch (0x808) at 0xf4424184
Internal error: : 808 [#1] PREEMPT ARM
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 3.15.0-rc1-26325-g971f9fd-dirty #64
task: c7829aa0 ti: c7836000 task.ti: c7836000
PC is at ci_hdrc_probe+0x3a4/0x634
LR is at ci_hdrc_probe+0x100/0x634
pc : [<c036cc78>] lr : [<c036c9d4>] psr: 60000013
sp : c7837d48 ip : 00000001 fp : 00000000
r10: 00000000 r9 : 00000000 r8 : c791b6c0
r7 : c7945000 r6 : f4424000 r5 : c7945010 r4 : c794e010
r3 : f4424184 r2 : 00000000 r1 : 8c000004 r0 : 0c000004
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Process swapper (pid: 1, stack limit = 0xc78361c0)
Stack: (0xc7837d48 to 0xc7838000)
Add alias for FEC ethernet on i.MX to allow bootloaders (like U-Boot)
patch-in the MAC address for FEC using this alias.
Per bindings of fixed-clock, #clock-cells is a required property. Let's
add it for those fixed rate clocks.
This patch adds the missing (Universal serial bus) USB devicetree
nodes for i.MX27 CPUs.
This patch adds the missing (Synchronous Serial Interface) SSI1 & SSI2
devicetree nodes for i.MX27 CPUs.
Add pinctrl nodes and properties for phyCARD-S device nodes.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
This patch adds a iomux node for imx27 pinctrl driver. The gpio
registers are embedded in the iomux memory area. So this patch moves
them into the iomux node for a better hardware description.
The pwm-node is missing its #pwm-cells property. The pwm-framework will
complain about this.
Add the missing property.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
CSPI PER clock is per2clk (per2_gate id 60) instead of cspiX_ipg_gate.
Signed-off-by: Gwenhael Goavec-Merou <gwenhael.goavec-merou@armadeus.com>
AUDMUX expects additional parameters to be configured correctly,
so turn it off into a template.
Clock name is not needed for "cpufreq-cpu0".
i.MX27 CPU can be clocked with a 32 kHz quartz, and not just 32768 Hz,
so increase "clock-latency" value, which will ensure that we use two
clock cycles on frequency change.
Add a label to i.MX27 CPU node. This change allows the reuse this node
in the upper levels of the DTS.
Patch removes optional "ptp" clock source for FEC. This clock is
missing in i.MX27.
Patch replaces "dummy" clock source for watchdog with "wdog_ipg_gate".
This patch adds core voltages for i.MX27 CPUs. Only 266 and 400 MHz modes
is documented in the datasheet, so we add a 266 MHz frequency for conform this.
This patch adds the missing (Wireless External Interface Module) WEIM
devicetree node for i.MX27 CPUs.
This patch moves IIM node under AIPI2 bus, since this is proper
location for this module.
Set operating-points for imx27. There is no regulator support, so the
voltages are 0. The frequencies should be the same for all imx27 boards,
so it is defined here and can be overwritten if necessary.
On the MX27 Reference Manual the interrupt controller is named AITC:
ARM926EJ-S Interrupt Controller
So use the AITC term instead of AVIC.
Origin: id:1334193132-18944-2-git-send-email-festevam@gmail.com
This allows to order the i2c devices correctly.
While at it reorder the aliases entries alphabetically.
This patch adds the missing (Keypad Port) KPP devicetree node
for i.MX27 CPUs.
Signed-off-by: Alexander Shiyan <eagle.alexander923@gmail.com>
i.MX27 have only one PWM, so index from PWM devicetree node removed.
This patch adds the missing (Digital Audio MUX) AUDMUX devicetree
This patch adds the missing (Symmetric/Asymmetric Hashing and Random
Accelerator) SAHARA2 devicetree node for i.MX27 CPUs.
This patch adds the missing VPU devicetree node for i.MX27 CPUs.
This patch adds the missing SDHC devicetree nodes for i.MX27 SoCs.
Acked-by: Sascha Hauer <s.hauer@pengutonix.de>
This patch adds the missing DMA devicetree node for i.MX27 SoCs.
Add aliases to determine the proper SPI bus number.
The CSPI controller has only one clock, but the driver spi-imx.c needs
clock "per" to calculate bitrate divisor.
Signed-off-by: Jonas Andersson <jonas@microbit.se>
