Based on 1 normalized pattern(s):
the code contained herein is licensed under the gnu general public
license you may obtain a copy of the gnu general public license
version 2 or later at the following locations http www opensource
org licenses gpl license html http www gnu org copyleft gpl html
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 161 file(s).
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.383790741@linutronix.de
Boards based on imx28 have duplicate memory nodes:
- One coming from the board dts file: memory@
- One coming from the imx28.dtsi file.
Fix the duplication by removing the memory node from the dtsi file
and by adding 'device_type = "memory";' in the board dts.
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Fix the following warnings from dtc by adding the unit name to memory
nodes:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
Converted using the following command:
perl -p0777i -e 's/memory \{\n\t\treg = \<0x+([0-9a-f])/memory\@$1$\0000000 \{\n\t\treg = <0x$1/m' `find ./arch/arm/boot/dts -name "imx*"`
The files below were manually fixed:
-imx1-ads.dts
-imx1-apf9328.dts
-imx6q-pistachio.dts
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Signed-off-by: Gwenhael Goavec-Merou <gwenhael.goavec-merou@armadeus.com>
Signed-off-by: Sebastien Szymanski <sebastien.szymanski@armadeus.com>
Convert mx23/mx28 dts filed to use the pinctrl header files.
NOTE: During automatic conversion of these files to use the pinconfig
definitions an inconsistency has been found in:
arch/arm/boot/dts/imx28-apx4devkit.dts
According to the comment the function for pad SSP2_SS0 should have
been MX28_PAD_SSP2_SS0__GPIO_2_19, while the given value 0x2131
represents: MX28_PAD_SSP2_SS0__AUART3_TX
I used the later (though probably wrong) definition because that's
what is actually being used in the DTB.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
The APF28 is a small SOM built around an i.MX28 processor with 128MBytes DDR2,
256MBytes NAND Flash and an Ethernet PHY.
Signed-off-by: Julien Boibessot <julien.boibessot@armadeus.com>
