path: root/arch/arm/boot/dts/imx28-cfa10037.dts
2014-02-09ARM: i.MX28: dts: rename usbphy pin namesMichael Grzeschik
The pins have nothing todo with the phy layer. We better rename them, so it gets clear they are routed to the ehci core not to any phy. Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: imx: use generic node name for fixed regulatorShawn Guo
The device tree specification recommends that generic name should be used for nodes. So instead of naming those fixed regulator nodes arbitrarily, let's use the generic name 'regulator@num' for those nodes. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-09-26ARM: dts: mxs: modify mx23/mx28 dts files to use padconfig definesLothar Waßmann
Convert mx23/mx28 dts files to use the padconfig defintions from mxs-pinfunc.h. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-09-26ARM: dts: mxs: modify mx23/mx28 dts files to use pinctrl headersLothar Waßmann
Convert mx23/mx28 dts filed to use the pinctrl header files. NOTE: During automatic conversion of these files to use the pinconfig definitions an inconsistency has been found in: arch/arm/boot/dts/imx28-apx4devkit.dts According to the comment the function for pad SSP2_SS0 should have been MX28_PAD_SSP2_SS0__GPIO_2_19, while the given value 0x2131 represents: MX28_PAD_SSP2_SS0__AUART3_TX I used the later (though probably wrong) definition because that's what is actually being used in the DTB. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-16ARM: mxs: dt: cfa10037: make hogpins grabbed by respective driversAlexandre Belloni
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-01-26ARM: mxs: dt: Add Crystalfontz CFA-10037 device tree supportMaxime Ripard
The CFA-10037 is another expansion board for the CFA-10036 module, with only a USB Host, a Ethernet device and a lot of gpios. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
