The backlight PWM is actually pwm4.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The lcdif node has a property named "display" and also a child node
called "display", which causes the following warning:
device-tree: Duplicate name in lcdif@80030000, renamed to "display#1"
Rename the child node name in order to avoid the warning.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
The pins have nothing todo with the phy layer. We better rename them, so
it gets clear they are routed to the ehci core not to any phy.
Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
The device tree specification recommends that generic name should be
used for nodes. So instead of naming those fixed regulator nodes
arbitrarily, let's use the generic name 'regulator@num' for those nodes.
Convert mx23/mx28 dts files to use the padconfig defintions from
mxs-pinfunc.h.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Convert mx23/mx28 dts filed to use the pinctrl header files.
NOTE: During automatic conversion of these files to use the pinconfig
definitions an inconsistency has been found in:
arch/arm/boot/dts/imx28-apx4devkit.dts
According to the comment the function for pad SSP2_SS0 should have
been MX28_PAD_SSP2_SS0__GPIO_2_19, while the given value 0x2131
represents: MX28_PAD_SSP2_SS0__AUART3_TX
I used the later (though probably wrong) definition because that's
what is actually being used in the DTB.
Necessary pins are now grabbed by respective drivers. Unecessary hogpins are
simply removed.
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The CFA-10057 is a breakout board for the CFA-10036 that has Ethernet,
USB and a 4.3" LCD screen on it.
Signed-off-by: Brian Lilly <brian@crystalfontz.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
