This fixes the following dtc warning by removing the unnecessary unit:
Warning (unit_address_vs_reg): Node /matrix-keypad@0 has a unit name,
but no reg property
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Acked-By: Lothar Waßmann <LW@KARO-electronics.de>
The reference clock for the SGTL5000 is generated by a 26MHz crystal
oscillator on the Ka-Ro electronics STK5 eval kits. Use the correct
frequency setting in DTB.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Though the keyboard and other driver will continue to support the legacy
"gpio-key,wakeup", "linux,wakeup" and "enable-sdio-wakeup" boolean
property to enable the wakeup source, "wakeup-source" is the new
standard binding.
This patch replaces all the legacy wakeup properties with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: Sascha Hauer <kernel@pengutronix.de>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Now that the driver respects IRQ trigger settings from device tree, let's
fix them up in individual DTSes (note that the driver is still compatible
with older DTSes).
Acked-by: Felipe Balbi <balbi@ti.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
This alias is used by U-Boot to enable/disable the regulator depending
on baseboard type.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
The spi-mxs driver does not allow full duplex SPI transfers. The
spi-gpio driver may be used as an alternative if this is required.
Make the choice between those drivers easier for the end user by
providing settings for both drivers.
The labels on the spidev nodes are not used and not required, so
remove them. The TX28 supports 3 chipselects on the SPI
interface. Make all those chipselects available to the user.
The lcdif node has a property named "display" and also a child node
called "display", which causes the following warning:
device-tree: Duplicate name in lcdif@80030000, renamed to "display#1"
Rename the child node name in order to avoid the warning.
Acked-by: Lothar Waßmann <LW@KARO-electronics.de>
'enable-active-low' is not a valid property for a GPIO controlled regulator.
According to Documentation/devicetree/bindings/regulator/gpio-regulator.txt:
"Optional properties:
- enable-active-high : Polarity of GPIO is active high (default is low)."
,so the correct way to define an active-low GPIO controlled regulator is to
simply not pass 'enable-active-high'.
The device tree specification recommends that generic name should be
used for nodes. So instead of naming those fixed regulator nodes
arbitrarily, let's use the generic name 'regulator@num' for those nodes.
Update the Ka-Ro TX28 DTS file.
- add Copyright header
- use label references for better readability
- sort the entries alphabetically
- add some aliases used by U-Boot to modify the DT data
Convert mx23/mx28 dts filed to use the pinctrl header files.
NOTE: During automatic conversion of these files to use the pinconfig
definitions an inconsistency has been found in:
arch/arm/boot/dts/imx28-apx4devkit.dts
According to the comment the function for pad SSP2_SS0 should have
been MX28_PAD_SSP2_SS0__GPIO_2_19, while the given value 0x2131
represents: MX28_PAD_SSP2_SS0__AUART3_TX
I used the later (though probably wrong) definition because that's
what is actually being used in the DTB.
hog_pins is used to setup the pin functions, and it is not neccesarily used only
for GPIO pins, so use only 'hog' to describe a more generic term.
For non-DT boot, function tx28_add_fec0 configures all ENET0 pins
into gpio mode for resetting fec phy, and then reconfigures those pins
into ENET function after that.
For DT boot, all the pin configuration is done by pinctrl subsystem.
Ideally, when gpio_request gets called, GPIO subsystem should call
pinctrl to configure pins into gpio mode automatically, and have pins
freed up from pinctrl subsystem when gpio_free is called. But right
now, this cooperation between gpio and pinctrl hasn't been available.
As the result, we have to explicitly call pinctrl_get_select and
pinctrl_put for device tree boot.
Rename mxs dts files with soc name being the prefix, so that the board
dts file can be located easily by soc name, and we also gain the
consistency of naming.
Suggested-by: Marek Vasut <marex@denx.de>
