path: root/arch/arm/boot/dts/imx31.dtsi
2017-02-23Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Arnd Bergmann: "A total of 380 patches this time, mostly adding support for more hardware in the device tree descriptions. There is not much exciting here for 4.11, but I've tried my best to condense the information from the pull requests I got into a readable summary. Noteworthy changes to existing platforms include: - The GIC memory map was a bit wrong almost everywhere and now gets fixed up - The Allwinner platforms convert to the generic pinmux properties - The Marvell EBU platforms now use the new DSA binding - Samsung Exynos4212 was unused and gets removed - The Renesas power management got improved New production machines: - Lego Mindstorms EV3: https://www.lego.com/en-us/mindstorms/about-ev3 - Beelink X2 Android media box: http://linux-sunxi.org/Beelink_X2 - "Romulus" baseboard management controller for OpenPower - Axentia TSE-850 Data Radio Channel (DARC) encoder: http://www.axentia.se/db/equipment.html - Luxul XAP-1410 and XWR-1200 wireless access points: https://luxul.com/xap-1410 New SoCs: - Allwinner H2+ and V3s, both minor variations of already supported chips: http://www.allwinnertech.com/index.php?c=product&a=index&id=38 - Marvell Prestera DX packet processors based on Armada XP architecture: http://www.marvell.com/switching/prestera-dx/ - Samsung Exynos4412 Prime gets added, a minor variation of Exynos4412 New developer and reference boards: - Lichee Pi One, Lichee Pi Zero and Orange Pi Zero, all based on Allwinner SoCs: http://linux-sunxi.org/LicheePi_One http://www.orangepi.org/orangepizero/ - SAMA5d36ek Reference platform: http://www.atmel.com/tools/sama5d36-ek.aspx - Beaglebone Green Wireless and Black Wireless: https://beagleboard.org/black-wireless https://beagleboard.org/green-wireless - phyCORE-AM335x System on Module: http://phytec.com/products/system-on-modules/phycore/am335x/ - New revision of "vf610-zii" Zodiac Inflight Innovations board - Various i.MX System-on-Module: Is.IoT MX6UL, SavageBoard, Engicam i.Core: http://www.opossom.com/english/index.html http://www.savageboard.org/ http://www.engicam.com/en/products/embedded/som/sodimm/is-iot-mx6ul http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q - Liebherr (LWN) monitor 6 based on i.MX6 Quad, no idea what this is - Cleanups and bugfixes on at91, bcm53xx, i.MX, mvebu, omap, oxnas, qcom, rockchip, sti, stm32 and tegra New device supports added to some boards and SoCs, briefly by platform: - Allwinner: SPDIF, A33 cpufreq, A33 Mali GPU - Aspeed: network, ipmi bt, gpio, pinmux - Broadcom: video encoder for raspberry pi, qspi, ethernet, sd/mmc - TI DaVinci: gpio, lcdc, usb, video-in, uart - TI Keystone 2: MSM RAM, power/reset, uart - Mediatek MT2701: clocks, iommu, spi, nand, adc, thermal - Marvell EBU: ethernet switch on Turris Omnia - NXP i.MX: otp ram, USB, wifi, bluetooth, spdif, spi, pmic, eeprom, mmc, nand - TI OMAP: - Qualcomm: coresight, gyro/accelerometer, hdmi - Renesas: pmic, soc-id - Rockchip: qos - Samsung: audio on Odroid-X - Socfpga: FPGA manager, i2c, led, can, watchdog, nand, power monitor - STi: video in/out - STM32: timer, pwm, i2c, rtc, add, i2s - NVIDIA Tegra: tpm - Uniphier: mmc/sd pinmux" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (380 commits) ARM: dts: armada-385-linksys: fix DSA compatible property ARM: dts: Fix typo in armada-xp-98dx4251 ARM: DTS: Fix register map for virt-capable GIC dt-bindings: arm,gic: Fix binding example for a virt-capable GIC ARM: dts: sun8i: sinlinx: Enable audio nodes ARM: dts: sun8i: parrot: Enable audio nodes ARM: dts: sun8i: Add audio codec, dai and card for A33 ARM: dts: Add EMAC AXI settings for Arria10 ARM: dts: am335x-chiliboard: Support charger ARM: dts: am335x-chiliboard: Support power button ARM: sun8i: dt: Add mali node dt-bindings: gpu: Add Mali Utgard bindings ARM: dts: stm32: Add I2C1 support for STM32429 eval board ARM: dts: stm32: Add I2C1 support for STM32F429 SoC ARM: dts: stm32: Use clock DT binding definition on stm32f429 family dt-bindings: mfd: stm32f4: Add missing binding definition dt-bindings: mfd: stm32f4: Fix STM32F4_X_CLOCK() macro ARM: dts: stm32: Enable pwm1 and pwm3 for stm32f469-disco ARM: dts: stm32: add Timers driver for stm32f429 MCU ARM: dts: add the AB8500 sysclk to the device trees ...
2017-01-29Merge tag 'imx-dt-4.11' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/dt i.MX device tree updates for 4.11: - New board support: vf610-zii-dev-rev-c, imx6ul-opos6uldev, imx6ul-isiot, imx6qdl-savageboard, imx6q-mccmon6. - A patch from Alexandre to correct the mangled license text which has been copied & pasted all over the i.MX device tree files. - Update cpu nodes of some i.MX SoCs to make them consistent and match ePAPR spec. - Add OCOTP device for i.MX6UL SoC. - Add security violation interrupt for i.MX25 DryIce. - Enable USB OTG, WIFI and Bluetooth support for i.MX6SX Udoo Neo board. - Enable S/PDIF and 2nd display pipeline support for CompuLab board.. - Add SPI and LTC3676 PMIC support for Gateworks Ventana boards. - A few random device addition for various boards: TVE DAC regulators for imx53-qsb, EEPROM for vf610-zii-dev, eMMC and NAND support for i.MX6UL Engicam boards. - Cleanups on obsoleted or unused properties. * tag 'imx-dt-4.11' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (32 commits) ARM: dts: udoo_neo: Add Bluetooth support ARM: dts: udoo_neo: Add Wifi support ARM: dts: udoo_neo: Add UDOO Neo USB OTG1 and OTG2 support ARM: dts: imx6ul: Add Engicam Is.IoT MX6UL NAND initial support ARM: dts: imx6ul: Add Engicam Is.IoT MX6UL eMMC initial support ARM: dts: imx6qdl: Fix "ERROR: code indent should use tabs where possible" ARM: dts: vf610-zii-dev: add EEPROM entry to Rev C ARM: dts: add Armadeus Systems OPOS6UL and OPOS6ULDEV support ARM: dts: imx6q-utilite-pro: enable 2nd display pipeline ARM: dts: vf610-zii-dev: Add .dts file for rev. C ARM: dts: vf610-zii-dev-rev-b: Remove leftover PWM pingroup ARM: dts: imx6: Support Savageboard quad ARM: dts: imx6: Support Savageboard dual ARM: dts: imx6: Add Savageboard common file ARM: dts: imx53-qsb: Provide the TVE DAC regulators ARM: dts: imx6q: Add mccmon6 board support Doc: devicetree: bindings: Add vendor prefix entry - lwn ARM: dts: imx/vf: Correct license text ARM: dts: imx25.dtsi: DryIce security violation interrupt ARM: dts: imx: Add ocotp node for imx6ul ... Signed-off-by: Olof Johansson <olof@lixom.net>
2017-01-24ARM: dts: imx: Pass 'chosen' and 'memory' nodesFabio Estevam
Commit 7f107887d199 ("ARM: dts: imx: Remove skeleton.dtsi") causes boot issues when the bootloader does not create a 'chosen' node if such node is not present in the dtb. The reason for the boot failure is well explained by Javier Martinez Canillas: "the decompressor relies on a pre-existing chosen node to be available to insert the command line and merge other ATAGS info." , so pass an empty 'chosen' node to fix the boot problem. This issue has been seen in the kernelci reports with Barebox as bootloader. Also pass the 'memory' node in order to fix boot issues on the SolidRun iMX6 platforms. Fixes: 7f107887d199 ("ARM: dts: imx: Remove skeleton.dtsi") Reported-by: kernelci.org bot <bot@kernelci.org> Reported-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-02ARM: dts: imx31: fix AVIC base addressVladimir Zapolskiy
On i.MX31 AVIC interrupt controller base address is at 0x68000000. The problem was shadowed by the AVIC driver, which takes the correct base address from a SoC specific header file. Fixes: d2a37b3d91f4 ("ARM i.MX31: Add devicetree support") Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-02ARM: dts: imx: Adjust CPU nodesFabio Estevam
Make CPU nodes consistent throughout the i.MX dts files, which also matches the description from ePAPR spec. This also fixes the following W=1 warning in some cases: Warning (unit_address_vs_reg): Node /cpus/cpu@0 has a unit name, but no reg property Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-12-15Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Arnd Bergmann: "Lots of changes as usual, so I'm trying to be brief here. Most of the new hardware support has the respective driver changes merged through other trees or has had it available for a while, so this is where things come together. We get a DT descriptions for a couple of new SoCs, all of them variants of other chips we already support, and usually coming with a new evaluation board: - Oxford semiconductor (now Broadcom) OX820 SoC for NAS devices - Qualcomm MDM9615 LTE baseband - NXP imx6ull, the latest and smallest i.MX6 application processor variant - Renesas RZ/G (r8a7743 and r8a7745) application processors - Rockchip PX3, a variant of the rk3188 chip used in Android tablets - Rockchip rk1108 single-core application processor - ST stm32f746 Cortex-M7 based microcontroller - TI DRA71x automotive processors These are commercially available consumer platforms we now support: - Motorola Droid 4 (xt894) mobile phone - Rikomagic MK808 Android TV stick based on Rockchips rx3066 - Cloud Engines PogoPlug v3 based on OX820 - Various Broadcom based wireless devices: - Netgear R8500 router - Tenda AC9 router - TP-LINK Archer C9 V1 - Luxul XAP-1510 Access point - Turris Omnia open hardware router based on Armada 385 And a couple of new boards targeted at developers, makers or industrial integration: - Macnica Sodia development platform for Altera socfpga (Cyclone V) - MicroZed board based on Xilinx Zynq FPGA platforms - TOPEET itop/elite based on exynos4412 - WP8548 MangOH Open Hardware platform for IOT, based on Qualcomm MDM9615 - NextThing CHIP Pro gadget - NanoPi M1 development board - AM571x-IDK industrial board based on TI AM5718 - i.MX6SX UDOO Neo - Boundary Devices Nitrogen6_SOM2 (i.MX6) - Engicam i.CoreM6 - Grinn i.MX6UL liteSOM/liteBoard - Toradex Colibri iMX6 module Other changes: - added peripherals on renesas, davinci, stm32f429, uniphier, sti, mediatek, integrator, at91, imx, vybrid, ls1021a, omap, qualcomm, mvebu, allwinner, broadcom, exynos, zynq - Continued fixes for W=1 dtc warnings - The old STiH415/416 SoC support gets removed, these never made it into products and have served their purpose in the kernel as a template for teh newer chips from ST - The exynos4415 dtsi file is removed as nothing uses it. - Intel PXA25x can now be booted using devicetree" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (422 commits) arm: dts: zynq: Add MicroZed board support ARM: dts: da850: enable high speed for mmc ARM: dts: da850: Add node for pullup/pulldown pinconf ARM: dts: da850: enable memctrl and mstpri nodes per board ARM: dts: da850-lcdk: Add ethernet0 alias to DT ARM: dts: artpec: add pcie support ARM: dts: add support for Turris Omnia devicetree: Add vendor prefix for CZ.NIC ARM: dts: berlin2q-marvell-dmp: fix typo in chosen node ARM: dts: berlin2q-marvell-dmp: fix regulators' name ARM: dts: Add xo to sdhc clock node on qcom platforms ARM: dts: r8a7794: Add device node for PRR ARM: dts: r8a7793: Add device node for PRR ARM: dts: r8a7792: Add device node for PRR ARM: dts: r8a7791: Add device node for PRR ARM: dts: r8a7790: Add device node for PRR ARM: dts: r8a7779: Add device node for PRR ARM: dts: r8a73a4: Add device node for PRR ARM: dts: sk-rzg1e: add Ether support ARM: dts: sk-rzg1e: initial device tree ...
2016-11-14ARM: dts: imx: Remove skeleton.dtsiFabio Estevam
As explained by commit 9c0da3cc61f1233c ("ARM: dts: explicitly mark skeleton.dtsi as deprecated"), including skeleton.dtsi is deprecated. This fixes the following warning with W=1: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-11-01ARM: dts: imx31: move CCM device node to AIPS2 bus devicesVladimir Zapolskiy
i.MX31 Clock Control Module controller is found on AIPS2 bus, move it there from SPBA bus to avoid a conflict of device IO space mismatch. Fixes: ef0e4a606fb6 ("ARM: mx31: Replace clk_register_clkdev with clock DT lookup") Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-11-01ARM: dts: imx31: fix clock control module interrupts descriptionVladimir Zapolskiy
The type of AVIC interrupt controller found on i.MX31 is one-cell, namely 31 for CCM DVFS and 53 for CCM, however for clock control module its interrupts are specified as 3-cells, fix it. Fixes: ef0e4a606fb6 ("ARM: mx31: Replace clk_register_clkdev with clock DT lookup") Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-04-18ARM: dts: i.MX3x: add keypad port devicetree nodesAlexander Kurz
Add the Keypad Port (KPP) devicetree nodes for IMX31 and IMX35 SOC. Signed-off-by: Alexander Kurz <akurz@blala.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-10-19ARM: dts: i.MX31: fix cpu compatible valueVladimir Zapolskiy
The change corrects cpu compatible property to a defined one, see Documentation/devicetree/bindings/arm/cpus.txt Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2013-08-22ARM: dts: imx: Add the missing cpus nodeFabio Estevam
To make it consistent with the other i.mx SoCs, let's add the cpus nodes. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: dts: i.MX31: Add iim nodeSascha Hauer
Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-09ARM: i.MX31: Add GPT devicetree nodeSascha Hauer
The GPT is the GPT timer found on i.MX SoCs. Since this is the first user of the AIPS2 this patch also adds it. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-09ARM: imx: use #include for all device treesShawn Guo
Replace /include/ (dtc) with #include (C pre-processor) for all imx DT files, so that gcc -E handles the entire include tree, and hence any of those files can #include some other file e.g. for constant definitions. This allows future use of #defines and header files in order to define names for various constants, such as pinctrl settings. Use of those features will increase the readability of the device tree files. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-01-25ARM: mx31: Replace clk_register_clkdev with clock DT lookupFabio Estevam
Similarly as it was done for mx6q, use a DT lookup in order to make maintainance task for the clock devices easier. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-07-10ARM i.MX31: Add devicetree supportDenis 'GNUtoo' Carikli
This patch adds basic devicetree support for i.MX31 based SoCs. Only the UART and interrupts bindings are added. Signed-off-by: Denis 'GNUtoo' Carikli <GNUtoo@no-log.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
