commit af92305e567b7f4c9cf48b9e46c1f48ec9ffb1fb upstream.
On i.MX31 AVIC interrupt controller base address is at 0x68000000.
The problem was shadowed by the AVIC driver, which takes the correct
base address from a SoC specific header file.
Fixes: d2a37b3d91f4 ("ARM i.MX31: Add devicetree support")
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
commit 1f87aee6a2e55eda466a43ba6248a8b75eede153 upstream.
i.MX31 Clock Control Module controller is found on AIPS2 bus, move it
there from SPBA bus to avoid a conflict of device IO space mismatch.
Fixes: ef0e4a606fb6 ("ARM: mx31: Replace clk_register_clkdev with clock DT lookup")
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
commit 2e575cbc930901718cc18e084566ecbb9a4b5ebb upstream.
The type of AVIC interrupt controller found on i.MX31 is one-cell,
namely 31 for CCM DVFS and 53 for CCM, however for clock control
module its interrupts are specified as 3-cells, fix it.
Acked-by: Rob Herring <robh@kernel.org>
Add the Keypad Port (KPP) devicetree nodes for IMX31 and IMX35 SOC.
Signed-off-by: Alexander Kurz <akurz@blala.de>
The change corrects cpu compatible property to a defined one,
see Documentation/devicetree/bindings/arm/cpus.txt
Cc: Sascha Hauer <kernel@pengutronix.de>
To make it consistent with the other i.mx SoCs, let's add the cpus nodes.
The GPT is the GPT timer found on i.MX SoCs.
Since this is the first user of the AIPS2 this patch also adds it.
Replace /include/ (dtc) with #include (C pre-processor) for all imx DT
files, so that gcc -E handles the entire include tree, and hence any of
those files can #include some other file e.g. for constant definitions.
This allows future use of #defines and header files in order to define
names for various constants, such as pinctrl settings. Use of those
features will increase the readability of the device tree files.
Similarly as it was done for mx6q, use a DT lookup in order to make maintainance
task for the clock devices easier.
This patch adds basic devicetree support for i.MX31 based SoCs.
Only the UART and interrupts bindings are added.
Signed-off-by: Denis 'GNUtoo' Carikli <GNUtoo@no-log.org>
