Pull ARM DT updates from Arnd Bergmann:
"A total of 380 patches this time, mostly adding support for more
hardware in the device tree descriptions. There is not much exciting
here for 4.11, but I've tried my best to condense the information from
the pull requests I got into a readable summary.
Noteworthy changes to existing platforms include:
- The GIC memory map was a bit wrong almost everywhere and now gets
fixed up
- The Allwinner platforms convert to the generic pinmux properties
- The Marvell EBU platforms now use the new DSA binding
- Samsung Exynos4212 was unused and gets removed
- The Renesas power management got improved
New production machines:
- Lego Mindstorms EV3:
https://www.lego.com/en-us/mindstorms/about-ev3
- Beelink X2 Android media box:
http://linux-sunxi.org/Beelink_X2
- "Romulus" baseboard management controller for OpenPower
- Axentia TSE-850 Data Radio Channel (DARC) encoder:
http://www.axentia.se/db/equipment.html
- Luxul XAP-1410 and XWR-1200 wireless access points:
https://luxul.com/xap-1410
New SoCs:
- Allwinner H2+ and V3s, both minor variations of already supported
chips:
http://www.allwinnertech.com/index.php?c=product&a=index&id=38
- Marvell Prestera DX packet processors based on Armada XP
architecture:
http://www.marvell.com/switching/prestera-dx/
- Samsung Exynos4412 Prime gets added, a minor variation of
Exynos4412
New developer and reference boards:
- Lichee Pi One, Lichee Pi Zero and Orange Pi Zero, all based on
Allwinner SoCs:
http://linux-sunxi.org/LicheePi_One
http://www.orangepi.org/orangepizero/
- SAMA5d36ek Reference platform:
http://www.atmel.com/tools/sama5d36-ek.aspx
- Beaglebone Green Wireless and Black Wireless:
https://beagleboard.org/black-wireless
https://beagleboard.org/green-wireless
- phyCORE-AM335x System on Module:
http://phytec.com/products/system-on-modules/phycore/am335x/
- New revision of "vf610-zii" Zodiac Inflight Innovations board
- Various i.MX System-on-Module: Is.IoT MX6UL, SavageBoard, Engicam
i.Core:
http://www.opossom.com/english/index.html
http://www.savageboard.org/
http://www.engicam.com/en/products/embedded/som/sodimm/is-iot-mx6ul
http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q
- Liebherr (LWN) monitor 6 based on i.MX6 Quad, no idea what this is
- Cleanups and bugfixes on at91, bcm53xx, i.MX, mvebu, omap, oxnas,
qcom, rockchip, sti, stm32 and tegra
New device supports added to some boards and SoCs, briefly by platform:
- Allwinner: SPDIF, A33 cpufreq, A33 Mali GPU
- Aspeed: network, ipmi bt, gpio, pinmux
- Broadcom: video encoder for raspberry pi, qspi, ethernet, sd/mmc
- TI DaVinci: gpio, lcdc, usb, video-in, uart
- TI Keystone 2: MSM RAM, power/reset, uart
- Mediatek MT2701: clocks, iommu, spi, nand, adc, thermal
- Marvell EBU: ethernet switch on Turris Omnia
- NXP i.MX: otp ram, USB, wifi, bluetooth, spdif, spi, pmic, eeprom,
mmc, nand
- TI OMAP:
- Qualcomm: coresight, gyro/accelerometer, hdmi
- Renesas: pmic, soc-id
- Rockchip: qos
- Samsung: audio on Odroid-X
- Socfpga: FPGA manager, i2c, led, can, watchdog, nand, power monitor
- STi: video in/out
- STM32: timer, pwm, i2c, rtc, add, i2s
- NVIDIA Tegra: tpm
- Uniphier: mmc/sd pinmux"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (380 commits)
ARM: dts: armada-385-linksys: fix DSA compatible property
ARM: dts: Fix typo in armada-xp-98dx4251
ARM: DTS: Fix register map for virt-capable GIC
dt-bindings: arm,gic: Fix binding example for a virt-capable GIC
ARM: dts: sun8i: sinlinx: Enable audio nodes
ARM: dts: sun8i: parrot: Enable audio nodes
ARM: dts: sun8i: Add audio codec, dai and card for A33
ARM: dts: Add EMAC AXI settings for Arria10
ARM: dts: am335x-chiliboard: Support charger
ARM: dts: am335x-chiliboard: Support power button
ARM: sun8i: dt: Add mali node
dt-bindings: gpu: Add Mali Utgard bindings
ARM: dts: stm32: Add I2C1 support for STM32429 eval board
ARM: dts: stm32: Add I2C1 support for STM32F429 SoC
ARM: dts: stm32: Use clock DT binding definition on stm32f429 family
dt-bindings: mfd: stm32f4: Add missing binding definition
dt-bindings: mfd: stm32f4: Fix STM32F4_X_CLOCK() macro
ARM: dts: stm32: Enable pwm1 and pwm3 for stm32f469-disco
ARM: dts: stm32: add Timers driver for stm32f429 MCU
ARM: dts: add the AB8500 sysclk to the device trees
Commit 7f107887d199 ("ARM: dts: imx: Remove skeleton.dtsi") causes boot
issues when the bootloader does not create a 'chosen' node if such node
is not present in the dtb.
The reason for the boot failure is well explained by Javier Martinez
Canillas: "the decompressor relies on a pre-existing chosen node to be
available to insert the command line and merge other ATAGS info."
, so pass an empty 'chosen' node to fix the boot problem.
This issue has been seen in the kernelci reports with Barebox as
bootloader.
Also pass the 'memory' node in order to fix boot issues on the SolidRun
iMX6 platforms.
Fixes: 7f107887d199 ("ARM: dts: imx: Remove skeleton.dtsi")
Reported-by: kernelci.org bot <bot@kernelci.org>
Reported-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Make CPU nodes consistent throughout the i.MX dts files, which
also matches the description from ePAPR spec.
This also fixes the following W=1 warning in some cases:
Warning (unit_address_vs_reg): Node /cpus/cpu@0 has a unit name, but no reg property
As explained by commit 9c0da3cc61f1233c ("ARM: dts: explicitly mark
skeleton.dtsi as deprecated"), including skeleton.dtsi is deprecated.
This fixes the following warning with W=1:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
This is a prerequisite to remove the static mappings for imx35 devicetree
based machines.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Add the Keypad Port (KPP) devicetree nodes for IMX31 and IMX35 SOC.
Signed-off-by: Alexander Kurz <akurz@blala.de>
For imx35, it needs three clocks to let the controller work,
the old code is wrong, and the usbmisc does not include
clock handling code any more.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
The change corrects cpu compatible property to a defined one,
see Documentation/devicetree/bindings/arm/cpus.txt
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Since commit 3d42a379b6fa5b46058e3302b1802b29f64865bb
("can: flexcan: add 2nd clock to support imx53 and newer")
the can driver requires a dt nodes to have a second clock.
Add them to imx35 to fix probing the flex can driver on the
respective platforms.
Signed-off-by: Denis Carikli <denis@eukrea.com>
Cc: <stable@vger.kernel.org>
The chipidea driver adds an extra line of spam to the log when a
host-only chipidea instance is left set to the default of a dual role
controller.
[ 2.010873] ci_hdrc ci_hdrc.1: doesn't support gadget
Set the dr_mode property to host on all the host-only nodes
to avoid this warning.
Signed-off-by: Matt Porter <mporter@konsulko.com>
Acked-by: Peter Chen <peter.chen@freescale.com>
This patch adds simple-card support to the i.MX SoCs.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
This patch adds the missing (General Purpose Timer) GPT devicetree node
for i.MX35 CPUs.
Like other imx SoCs only one USB clock is needed on mx35.
Add alias for FEC ethernet on i.MX to allow bootloaders (like U-Boot)
patch-in the MAC address for FEC using this alias.
Cc: Eric Bénard <eric@eukrea.com>
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
