Using aliases, the devices will be enumerated properly.
Signed-off-by: Alexander Kurz <akurz@blala.de>
Boards based on imx35 have duplicate memory nodes:
- One coming from the board dts file: memory@
- One coming from the imx35.dtsi file.
Fix the duplication by removing the memory node from the dtsi file
and by adding 'device_type = "memory";' in the board dts.
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
dtc has new checks for SPI buses. Fix the warnings in node names and
unit-addresses.
There's over 100 warnings for FSL boards, a few examples:
arch/arm/boot/dts/imx28-duckbill-2-spi.dtb: Warning (spi_bus_bridge): /apb@80000000/apbh@80000000/ssp@80014000: node name for SPI buses should be 'spi'
arch/arm/boot/dts/imx53-ppd.dtb: Warning (spi_bus_bridge): /soc/aips@50000000/spba@50000000/ecspi@50010000: node name for SPI buses should be 'spi'
arch/arm/boot/dts/imx6dl-colibri-eval-v3.dtb: Warning (spi_bus_reg): /soc/aips-bus@2000000/spba-bus@2000000/spi@2014000/mcp251x@1: SPI bus unit address format error, expected "0"
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Pengutronix Kernel Team <kernel@pengutronix.de>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: NXP Linux Team <linux-imx@nxp.com>
Cc: Li Yang <leoyang.li@nxp.com>
Cc: Stefan Agner <stefan@agner.ch>
Signed-off-by: Rob Herring <robh@kernel.org>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-by: Stefan Agner <stefan@agner.ch>
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/dt
i.MX device tree update for 4.18:
- New boards support: BTicino i.MX6DL Mamoj board, DHCOM iMX6 SoM and
PDK2 board, Engicam i.CoreM6 1.5 Quad/Dual MIPI starter kit,
Kieback & Peter GmbH iMX6Q TPC board.
- A series from Anson Huang to add a bunch of devices for i.MX6SX
SabreAuto board, PMIC, IO expanders, FEC, Watchdog, LED and Touch.
- Update i.MX7D for cpufreq support, using operating-points-v2
bindings, correcting cpu supply name for voltage scaling.
- Clean up unneeded 'codec-handle' property from imx25-pdk and
imx53-tx53 device tree.
- Switch SoC dtsi and NXP board dts files to use SPDX identifier.
- Remove unnecessary '#address-cells/#size-cells' to fix DTC warning
avoid_unnecessary_addr_size seen with W=1 switch.
- A series from Rob Herring to fix DTC warning graph_endpoint seen with
IPU OF graph when W=1 switch is on.
- Update a few boards to use symbol name instead of hard-coding the
input codes.
- Update a number of boards to use IRQ_TYPE specifier instead of the
raw value.
- A few updates for i.MX6 RDU2 board: bumping SoC/PU operating points,
adding assigned clocks for GPU, and enabling eGalax touchscreen.
- A couple of i.MX51 RDU1 updates: limiting usbh1 to full-speed, and
cleaning up eMMC device node.
- Convert Hummingboard audio bindings from imx-audio-sgtl5000 to
simple-audio-card, so that auxiliary audio devices such as external
amplifiers can be supported.
- Replace underscore with hyphen in aliases name to fix DTC warning
alias_paths with W=1 switch.
- A couple of updates on i.MX7D SAI and i.MX6ULL UART5 pin defines.
- Other random and small changes.
* tag 'imx-dt-4.18' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (72 commits)
ARM: dts: imx28/imx53: enable edt-ft5x06 wakeup source
ARM: dts: imx51-zii-rdu1: cleanup eMMC node
ARM: dts: vf610-zii-dev: enable vf610 builtin temp sensor
ARM: dts: imx7d: use operating-points-v2 for cpu
ARM: dts: imx7s-warp: remove unnecessary cpu regulator supply
ARM: dts: imx7d: correct cpu supply name for voltage scaling
ARM: dts: imx51-zii-rdu1: limit usbh1 to full-speed
ARM: dts: imx6/7: Remove unit-address from anatop regulators
ARM: dts: imx: Switch NXP boards to SPDX identifier
ARM: dts: imx6qdl-phytec-pfla02: Use IRQ_TYPE specifier
ARM: dts: imx53-voipac-dmm-668: Use IRQ_TYPE specifier
ARM: dts: imx53-qsb: Use IRQ_TYPE specifier
ARM: dts: vf-colibri-eval-v3: Use IRQ_TYPE specifier
ARM: dts: imx6q-gk802: Do not hardcode input codes
ARM: dts: imx53-smd: Do not hardcode input codes
ARM: dts: imx53-ard: Do not hardcode input codes
ARM: dts: imx7: Fix error in coresight TPIU graph connection
ARM: dts: imx53: Fix LDB OF graph warning
ARM: dts: imx: fix IPU OF graph endpoint node names
ARM: dts: imx: Switch to SPDX identifier
Adopt the SPDX license identifier headers to ease license compliance
management.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Commit d50f4630c2e1 ("arm: dts: Remove p1010-flexcan compatible from imx
series dts") removed the fallback compatible "fsl,p1010-flexcan" from
the imx device trees. As the flexcan cores on i.MX25, i.MX35 and i.MX53
are identical, introduce the first as fallback for the two latter ones.
Fixes: d50f4630c2e1 ("arm: dts: Remove p1010-flexcan compatible from imx series dts")
Cc: linux-stable <stable@vger.kernel.org> # >= v4.16
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Remove the empty reg property from the SoC dtsi files in order to avoid
duplicate memory nodes when the correct size is passed in board dts files.
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
Pull ARM SoC device tree updates from Arnd Bergmann:
"We get a moderate number of new machines this time, and only one new
SoC variant (Actions S700):
Actions:
- S700 Soc and CubieBoard7 development board
- Allo.com Sparky Single-board-computer
Allwinner:
- Orange Pi R1 development board
- Libre Computer Board ALL-H3-CC H3 single-board computer
ASpeed ast2x00:
- Witherspoon: OpenPower Power9 server manufactured by IBM that uses the ASPEED ast2500
- Zaius: OpenPower Power9 server manufactured by Invatech that uses the ASPEED ast2500
- Q71L: Intel Xeon server manufactured by Qanta that uses the ASPEED ast2400
AT91:
- Axentia Nattis/Natte digital signage
- sama5d2 PTC-ek Evaluation board
Freescale/NXP i.MX:
- SolidRun Humminboard2 development board
- Variscite DART-MX6 SoM and Carrier-board
- Technologic TS-4600 and TS-7970 development board
- Toradex Colibri iMX7D SoM board
- v1.5 variant of Solidrun Cubox-i and Hummingboard
Freescale/NXP Layerscape:
- Moxa UC-8410A Series industrial computer
Gemini:
- D-Link DNS-313 NAS enclosure
OMAP:
- LogicPD OMAP35xx SOM-LV devkit
- LogicPD OMAP35xx Torpedo devkit
Renesas:
- r8a77970 (V3M) Starter Kit board
- r8a7795 (M3-W) Salvator-XS board
We finally managed to get the dtc warnings under control, with no more
build-time warnings for bad device tree files. This includes fixes for
the majority of platforms, including nomadik, samsung, lpc32xx, STi,
spear, mediatek, freescale, qcom, realview, keystone, omap, kirkwood,
renesas, hisilicon, and broadcom.
Files get rearranged on a few platforms, in particular the Marvell
Armada 7K/8K device tree files are changed in preparation for future
SoC support, based on more than two of the same chips in one package,
and some boards get renamed for oxnas for consistency.
Finally, many existing SoCs gain descriptions for additional on-chip
devices that we can now support with kernel drivers:
- Allwinner A83t (drm, ethernet, i2c, ...), H3/H5 (USB-OTG)
- Amlogic AXG family (clk, pinctrl, pwm, ...), and others (vpu, hdmi)
- Aspeed clk controller support
- Freescale LS1088A, LS1021A device support
- Gemini Ethernet, PCI, TVE, panel
- Keystone gpio, qspi, more uarts
- Mediatek cpufreq, regulator, clock, reset
- Marvell thermal, cpufreq, nand
- Renesas SMP, thermal, timer, PWM, sound, phy, ipmmu
- Rockchip Mipi, GPU, display
- Samsung Exynos5433 PMU, power domain, nfc
- Spreadtrum: sc9860 clocks
- Tegra TX2 PSDI, HDMI, I2C,SMMU, display, fuse, ..."
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (690 commits)
arm64: dts: stratix10: fix SPI settings
ARM: dts: socfpga: add i2c reset signals
arm64: dts: stratix10: add USB ECC reset bit
arm64: dts: stratix10: enable USB on the devkit
ARM: dts: socfpga: disable over-current for Arria10 USB devkit
ARM: dts: Nokia N9: add support for up/down keys in the dts
ARM: dts: nomadik: add interrupt-parent for clcd
ARM: dts: Add ethernet to a bunch of platforms
ARM: dts: Add ethernet to the Gemini SoC
ARM: dts: rename oxnas dts files
ARM: dts: s5pv210: add interrupt-parent for ohci
ARM: lpc3250: fix uda1380 gpio numbers
ARM: dts: STi: Add gpio polarity for "hdmi,hpd-gpio" property
ARM: dts: dra7: Reduce shut down temperature of non-cpu thermal zones
ARM: dts: n900: Add aliases for lcd and tvout displays
ARM: dts: Update ti-sysc data for existing users
ARM: dts: Fix smartreflex compatible for omap3 shared mpu-iva instance
arm64: dts: marvell: armada-80x0: Fix pinctrl compatible string
arm: spear13xx: Fix spics gpio controller's warning
arm: spear13xx: Fix dmas cells
"usb-nop-xceiv" is using the phy binding, but is missing #phy-cells
property. This is probably because the binding was the precursor to the phy
binding.
Fixes the following warning in i.MX dts files:
Warning (phys_property): Missing property '#phy-cells' in node ...
Cc: Sascha Hauer <kernel@pengutronix.de>
The flexcan driver has been modified to check for big-endian dts
property for be read/write to flexcan registers/mb.
An exception to this rule is powerpc P1010RDB, which is always
big-endian, even if big-endian is not present in dts. This is
checked using p1010-flexcan compatible in dts.
Therefore, remove p1010-flexcan compatible from imx series dts,
as their flexcan core is little endian.
Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com>
Pull ARM DT updates from Arnd Bergmann:
"A total of 380 patches this time, mostly adding support for more
hardware in the device tree descriptions. There is not much exciting
here for 4.11, but I've tried my best to condense the information from
the pull requests I got into a readable summary.
Noteworthy changes to existing platforms include:
- The GIC memory map was a bit wrong almost everywhere and now gets
fixed up
- The Allwinner platforms convert to the generic pinmux properties
- The Marvell EBU platforms now use the new DSA binding
- Samsung Exynos4212 was unused and gets removed
- The Renesas power management got improved
New production machines:
- Lego Mindstorms EV3:
https://www.lego.com/en-us/mindstorms/about-ev3
- Beelink X2 Android media box:
http://linux-sunxi.org/Beelink_X2
- "Romulus" baseboard management controller for OpenPower
- Axentia TSE-850 Data Radio Channel (DARC) encoder:
http://www.axentia.se/db/equipment.html
- Luxul XAP-1410 and XWR-1200 wireless access points:
https://luxul.com/xap-1410
New SoCs:
- Allwinner H2+ and V3s, both minor variations of already supported
chips:
http://www.allwinnertech.com/index.php?c=product&a=index&id=38
- Marvell Prestera DX packet processors based on Armada XP
architecture:
http://www.marvell.com/switching/prestera-dx/
- Samsung Exynos4412 Prime gets added, a minor variation of
Exynos4412
New developer and reference boards:
- Lichee Pi One, Lichee Pi Zero and Orange Pi Zero, all based on
Allwinner SoCs:
http://linux-sunxi.org/LicheePi_One
http://www.orangepi.org/orangepizero/
- SAMA5d36ek Reference platform:
http://www.atmel.com/tools/sama5d36-ek.aspx
- Beaglebone Green Wireless and Black Wireless:
https://beagleboard.org/black-wireless
https://beagleboard.org/green-wireless
- phyCORE-AM335x System on Module:
http://phytec.com/products/system-on-modules/phycore/am335x/
- New revision of "vf610-zii" Zodiac Inflight Innovations board
- Various i.MX System-on-Module: Is.IoT MX6UL, SavageBoard, Engicam
i.Core:
http://www.opossom.com/english/index.html
http://www.savageboard.org/
http://www.engicam.com/en/products/embedded/som/sodimm/is-iot-mx6ul
http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q
- Liebherr (LWN) monitor 6 based on i.MX6 Quad, no idea what this is
- Cleanups and bugfixes on at91, bcm53xx, i.MX, mvebu, omap, oxnas,
qcom, rockchip, sti, stm32 and tegra
New device supports added to some boards and SoCs, briefly by platform:
- Allwinner: SPDIF, A33 cpufreq, A33 Mali GPU
- Aspeed: network, ipmi bt, gpio, pinmux
- Broadcom: video encoder for raspberry pi, qspi, ethernet, sd/mmc
- TI DaVinci: gpio, lcdc, usb, video-in, uart
- TI Keystone 2: MSM RAM, power/reset, uart
- Mediatek MT2701: clocks, iommu, spi, nand, adc, thermal
- Marvell EBU: ethernet switch on Turris Omnia
- NXP i.MX: otp ram, USB, wifi, bluetooth, spdif, spi, pmic, eeprom,
mmc, nand
- TI OMAP:
- Qualcomm: coresight, gyro/accelerometer, hdmi
- Renesas: pmic, soc-id
- Rockchip: qos
- Samsung: audio on Odroid-X
- Socfpga: FPGA manager, i2c, led, can, watchdog, nand, power monitor
- STi: video in/out
- STM32: timer, pwm, i2c, rtc, add, i2s
- NVIDIA Tegra: tpm
- Uniphier: mmc/sd pinmux"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (380 commits)
ARM: dts: armada-385-linksys: fix DSA compatible property
ARM: dts: Fix typo in armada-xp-98dx4251
ARM: DTS: Fix register map for virt-capable GIC
dt-bindings: arm,gic: Fix binding example for a virt-capable GIC
ARM: dts: sun8i: sinlinx: Enable audio nodes
ARM: dts: sun8i: parrot: Enable audio nodes
ARM: dts: sun8i: Add audio codec, dai and card for A33
ARM: dts: Add EMAC AXI settings for Arria10
ARM: dts: am335x-chiliboard: Support charger
ARM: dts: am335x-chiliboard: Support power button
ARM: sun8i: dt: Add mali node
dt-bindings: gpu: Add Mali Utgard bindings
ARM: dts: stm32: Add I2C1 support for STM32429 eval board
ARM: dts: stm32: Add I2C1 support for STM32F429 SoC
ARM: dts: stm32: Use clock DT binding definition on stm32f429 family
dt-bindings: mfd: stm32f4: Add missing binding definition
dt-bindings: mfd: stm32f4: Fix STM32F4_X_CLOCK() macro
ARM: dts: stm32: Enable pwm1 and pwm3 for stm32f469-disco
ARM: dts: stm32: add Timers driver for stm32f429 MCU
ARM: dts: add the AB8500 sysclk to the device trees
Commit 7f107887d199 ("ARM: dts: imx: Remove skeleton.dtsi") causes boot
issues when the bootloader does not create a 'chosen' node if such node
is not present in the dtb.
The reason for the boot failure is well explained by Javier Martinez
Canillas: "the decompressor relies on a pre-existing chosen node to be
available to insert the command line and merge other ATAGS info."
, so pass an empty 'chosen' node to fix the boot problem.
This issue has been seen in the kernelci reports with Barebox as
bootloader.
Also pass the 'memory' node in order to fix boot issues on the SolidRun
iMX6 platforms.
Fixes: 7f107887d199 ("ARM: dts: imx: Remove skeleton.dtsi")
Reported-by: kernelci.org bot <bot@kernelci.org>
Reported-by: Russell King <rmk+kernel@armlinux.org.uk>
Make CPU nodes consistent throughout the i.MX dts files, which
also matches the description from ePAPR spec.
This also fixes the following W=1 warning in some cases:
Warning (unit_address_vs_reg): Node /cpus/cpu@0 has a unit name, but no reg property
As explained by commit 9c0da3cc61f1233c ("ARM: dts: explicitly mark
skeleton.dtsi as deprecated"), including skeleton.dtsi is deprecated.
This fixes the following warning with W=1:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
This is a prerequisite to remove the static mappings for imx35 devicetree
based machines.
Add the Keypad Port (KPP) devicetree nodes for IMX31 and IMX35 SOC.
For imx35, it needs three clocks to let the controller work,
the old code is wrong, and the usbmisc does not include
clock handling code any more.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
The change corrects cpu compatible property to a defined one,
see Documentation/devicetree/bindings/arm/cpus.txt
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Since commit 3d42a379b6fa5b46058e3302b1802b29f64865bb
("can: flexcan: add 2nd clock to support imx53 and newer")
the can driver requires a dt nodes to have a second clock.
Add them to imx35 to fix probing the flex can driver on the
respective platforms.
Signed-off-by: Denis Carikli <denis@eukrea.com>
Cc: <stable@vger.kernel.org>
The chipidea driver adds an extra line of spam to the log when a
host-only chipidea instance is left set to the default of a dual role
controller.
[ 2.010873] ci_hdrc ci_hdrc.1: doesn't support gadget
Set the dr_mode property to host on all the host-only nodes
to avoid this warning.
Signed-off-by: Matt Porter <mporter@konsulko.com>
Acked-by: Peter Chen <peter.chen@freescale.com>
This patch adds simple-card support to the i.MX SoCs.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
This patch adds the missing (General Purpose Timer) GPT devicetree node
for i.MX35 CPUs.
Like other imx SoCs only one USB clock is needed on mx35.
Add alias for FEC ethernet on i.MX to allow bootloaders (like U-Boot)
patch-in the MAC address for FEC using this alias.
Cc: Eric Bénard <eric@eukrea.com>
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
