The FEC driver ignores the GPIO polarity from 'phy-reset-gpios' and
considers that the Ethernet PHY is active low, unless the
property 'phy-reset-active-high' is present.
Fix the device tree description by explicitly passing the
'GPIO_ACTIVE_LOW' flag to the 'phy-reset-gpios' property.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Currently, all pinctrl setting nodes are defined in <soc>.dtsi, so that
boards that share the same pinctrl setting do not have to define it time
and time again in <board>.dts. However, along with the devices and use
cases being added continuously, the pinctrl setting nodes under iomuxc
becomes more than expected. This bloats device tree blob for particular
board unnecessarily since only a small subset of those pinctrl setting
nodes will be used by the board. It impacts not only the DTB file size
but also the run-time device tree lookup efficiency.
The patch moves all the pinctrl data into individual boards as needed.
With the changes, the pinctrl setting nodes becomes local to particular
board, and it makes no sense to continue numbering the setting for
given peripheral. Thus, all the pinctrl phandler name gets updated to
have only peripheral name in there.
External high frequency clock CKIH1 is optional for i.MX51, so move
it setup into boards where it is used.
Signed-off-by: Gwenhael Goavec-Merou <gwenhael.goavec-merou@armadeus.com>
Replace /include/ (dtc) with #include (C pre-processor) for all imx DT
files, so that gcc -E handles the entire include tree, and hence any of
those files can #include some other file e.g. for constant definitions.
This allows future use of #defines and header files in order to define
names for various constants, such as pinctrl settings. Use of those
features will increase the readability of the device tree files.
Signed-off-by: Laurent Cans <laurent.cans@gmail.com>
