path: root/arch/arm/boot/dts/imx51-apf51.dts
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 159Thomas Gleixner
Based on 1 normalized pattern(s): the code contained herein is licensed under the gnu general public license you may obtain a copy of the gnu general public license version 2 or later at the following locations http www opensource org licenses gpl license html http www gnu org copyleft gpl html extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 161 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Richard Fontana <rfontana@redhat.com> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070033.383790741@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-10ARM: dts: imx51: Fix memory node duplicationFabio Estevam
Boards based on imx51 have duplicate memory nodes: - One coming from the board dts file: memory@ - One coming from the imx51.dtsi file. Fix the duplication by removing the memory node from the dtsi file and by adding 'device_type = "memory";' in the board dts. Reported-by: Rob Herring <robh@kernel.org> Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-02-12ARM: dts: imx: Add memory node unit nameMarco Franchi
Fix the following warnings from dtc by adding the unit name to memory nodes: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Converted using the following command: perl -p0777i -e 's/memory \{\n\t\treg = \<0x+([0-9a-f])/memory\@$1$\0000000 \{\n\t\treg = <0x$1/m' `find ./arch/arm/boot/dts -name "imx*"` The files below were manually fixed: -imx1-ads.dts -imx1-apf9328.dts -imx6q-pistachio.dts Signed-off-by: Marco Franchi <marco.franchi@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-06-05ARM: dts: imx: Fix Ethernet PHY reset polarityFabio Estevam
The FEC driver ignores the GPIO polarity from 'phy-reset-gpios' and considers that the Ethernet PHY is active low, unless the property 'phy-reset-active-high' is present. Fix the device tree description by explicitly passing the 'GPIO_ACTIVE_LOW' flag to the 'phy-reset-gpios' property. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2014-02-09ARM: dts: i.MX51 boards: Switch to use standard GPIO flags definitionsAlexander Shiyan
Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: imx51: make pinctrl nodes board specificShawn Guo
Currently, all pinctrl setting nodes are defined in <soc>.dtsi, so that boards that share the same pinctrl setting do not have to define it time and time again in <board>.dts. However, along with the devices and use cases being added continuously, the pinctrl setting nodes under iomuxc becomes more than expected. This bloats device tree blob for particular board unnecessarily since only a small subset of those pinctrl setting nodes will be used by the board. It impacts not only the DTB file size but also the run-time device tree lookup efficiency. The patch moves all the pinctrl data into individual boards as needed. With the changes, the pinctrl setting nodes becomes local to particular board, and it makes no sense to continue numbering the setting for given peripheral. Thus, all the pinctrl phandler name gets updated to have only peripheral name in there. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-08-22ARM: i.MX5 clocks: Remove optional clock setup (CKIH1) from i.MX51 templateAlexander Shiyan
External high frequency clock CKIH1 is optional for i.MX51, so move it setup into boards where it is used. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: imx: apf51: add nfc supportGwenhael Goavec-Merou
Signed-off-by: Gwenhael Goavec-Merou <gwenhael.goavec-merou@armadeus.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-09ARM: imx: use #include for all device treesShawn Guo
Replace /include/ (dtc) with #include (C pre-processor) for all imx DT files, so that gcc -E handles the entire include tree, and hence any of those files can #include some other file e.g. for constant definitions. This allows future use of #defines and header files in order to define names for various constants, such as pinctrl settings. Use of those features will increase the readability of the device tree files. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-02-10ARM: dts: Add apf51 basic supportLaurent Cans
Signed-off-by: Laurent Cans <laurent.cans@gmail.com> Signed-off-by: Gwenhael Goavec-Merou <gwenhael.goavec-merou@armadeus.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
