path: root/arch/arm/boot/dts/imx51-digi-connectcore-som.dtsi
2017-01-02ARM: dts: imx: remove obsoleted property fsl,spi-num-chipselectsVladimir Zapolskiy
Since commit b36581df7e78 ("spi: imx: Using existing properties for chipselects") the device tree property 'fsl,spi-num-chipselects' is unused and it is already marked as obsolete in device tree binding documentation. Remove the property from the existing DTS files to avoid its reoccurence on copying. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-02-29ARM: dts: imx: replace legacy wakeup property with 'wakeup-source'Sudeep Holla
Though the keyboard and other driver will continue to support the legacy "gpio-key,wakeup", "linux,wakeup" and "enable-sdio-wakeup" boolean property to enable the wakeup source, "wakeup-source" is the new standard binding. This patch replaces all the legacy wakeup properties with the unified "wakeup-source" property in order to avoid any futher copy-paste duplication. Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2014-05-16ARM: dts: i.MX51: Allow to define partitions onto NFCAlexander Shiyan
This patch allow to define partitions onto NFC in user defined devicetrees. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM i.MX51: Add Digi ConnectCore devicetreeAlexander Shiyan
This patch adds support for Digi ConnectCore® i.MX51/Wi-i.MX51 SOM and basic support for the ConnectCore for i.MX51 JumpStart Kit. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
