As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts
DT property"), the Freescale IMX UART driver recognizes the generic
"uart-has-rtscts" DT property, deprecating the vendor-specific
"fsl,uart-has-rtscts" DT property. Hence replace the latter by the
former in all DTS files.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Though the keyboard and other driver will continue to support the legacy
"gpio-key,wakeup", "linux,wakeup" and "enable-sdio-wakeup" boolean
property to enable the wakeup source, "wakeup-source" is the new
standard binding.
This patch replaces all the legacy wakeup properties with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: Sascha Hauer <kernel@pengutronix.de>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
The DAI mode is and should be configured by the sound card driver as
codec and ssi have to be in the right modes to communicate with each
other. It is possible to operate the ssi unit or the codec in master mode,
sometimes even on the same board in different configurations.
With the latest changes in the fsl-ssi driver, the 'fsl,mode' property
is only handled as a fallback property. If the sound card sets the DAI
mode correctly, this fallback configuration is dropped.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
The following commit:
89d7e5c mmc: sdhci-esdhc-imx: add runtime pm support
has the effect of also disabling the hardware card detect
in runtime pm.
We switch to GPIO based detection to avoid this issue.
This patch is based on:
ARM: dts: imx51-babbage: Fix esdhc setup
Signed-off-by: Denis Carikli <denis@eukrea.com>
Add support for CAN based on a MCP2515 connected to ECSPI1.
Reviewed-by: Eric Bénard <eric@eukrea.com>
The following devices/functionalities were added:
* Main and secondary UARTs.
* i2c and the pcf8563 device.
* Ethernet.
* NAND.
* The BP1 button.
* The LED.
* Watchdog
* SD.
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: devicetree@vger.kernel.org
Cc: Eric Bénard <eric@eukrea.com>
