path: root/arch/arm/boot/dts/imx51-ts4800.dts
2016-08-01Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Olof Johansson: "Device tree contents continue to be the largest branches we submit. This time around, some of the contents worth pointing out is: New SoC platforms: - Freescale i.MX 7Solo - Broadcom BCM23550 - Cirrus Logic EP7209 and EP7211 (clps711x platforms)_ - Hisilicon HI3519 - Renesas R8A7792 Some of the other delta that is sticking out, line-count wise: - Exynos moves of IP blocks under an SoC bus, which causes a large delta due to indentation changes - a new Tegra K1 board: Apalis - a bunch of small updates to many Allwinner platforms; new hardware support, some cleanup, etc" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (426 commits) ARM: dts: sun8i: Add dts file for inet86dz board ARM: dts: sun8i: Add dts file for Polaroid MID2407PXE03 tablet ARM: dts: sun8i: Use sun8i-reference-design-tablet for ga10h dts ARM: dts: sun8i: Use sun8i-reference-design-tablet for polaroid mid2809pxe04 ARM: dts: sun8i: reference-design-tablet: Add drivevbus-supply ARM: dts: Copy sun8i-q8-common.dtsi sun8i-reference-design-tablet.dtsi ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for utoo p66 dts ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for dit4350 dts ARM: dts: sun5i: reference-design-tablet: Remove mention of q8 ARM: dts: sun5i: reference-design-tablet: Set lradc vref to avcc ARM: dts: sun5i: Rename sun5i-q8-common.dtsi sun5i-reference-design-tablet.dtsi ARM: dts: sun5i: Move q8 display bits to sun5i-a13-q8-tablet.dts ARM: dts: sunxi: Rename sunxi-q8-common.dtsi sunxi-reference-design-tablet.dtsi ARM: dts: at91: Don't build unnecessary dtbs ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitions ARM: dts: at91: at91sam9g25ek: fix isi endpoint node ARM: dts: at91: move isi definition to at91sam9g25ek ARM: dts: at91: fix i2c-gpio node name ARM: dts: at91: vinco: fix regulator name ARM: dts: at91: ariag25 : fix onewire node ...
2016-07-22ARM: dts: fix STMicroelectronics compatible stringsStefan Agner
Replace the non-standard vendor prefix stm with st for STMicroelectronics. The drivers do not specify the vendor prefixes since the I2C Core strips them away from the DT provided compatible string. Therefore, changing existing device trees does not have any impact on device detection. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Rob Herring <robh@kernel.org>
2016-06-09ARM: dts: TS-4800: add CAN supportDamien Riegel
This enables support for the CAN controller located in the FPGA. Signed-off-by: Damien Riegel <damien.riegel@savoirfairelinux.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-06-09ARM: dts: TS-4800: add FPGA's IRQ controller supportDamien Riegel
Enable FPGA's IRQ controller. It is in charge of dispatching interrupts generated by IPs in the FPGA. The SoC is notified that an interrupt occurred through a GPIO. Signed-off-by: Damien Riegel <damien.riegel@savoirfairelinux.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-12-22ARM: dts: TS-4800: add touchscreen supportDamien Riegel
This commit enables the touchscreen on TS-4800, using the ts4800-ts driver. Signed-off-by: Damien Riegel <damien.riegel@savoirfairelinux.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-12-22ARM: dts: ts-4800: Add LCD supportDamien Riegel
This commit adds LCD support for the TS-4800. The panel is an Okaya RS800480T-7X0WQ and the timings have been extracted from Technologic Systems' tree. Signed-off-by: Damien Riegel <damien.riegel@savoirfairelinux.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-12-22ARM: dts: TS-4800: use weim IP to map the FPGADamien Riegel
Previously, the device tree mapped the FPGA like any other IPs inside the SoC, but it is actually mapped through the WEIM (Wireless External Interface Module). This patch updates the device tree to make use of it. About the timings: in the image provided by the manufacturer, only CS0GCR1 is changed. The other values are the default ones, but the WEIM bindings expect them to be all explicitly set in the device tree, so I just put the default values in the dt. Signed-off-by: Damien Riegel <damien.riegel@savoirfairelinux.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-12-22ARM: dts: TS-4800: drop uart rts/cts pin reservationsDamien Riegel
These pins are actually not routed for UARTs, they should not be reserved. Signed-off-by: Damien Riegel <damien.riegel@savoirfairelinux.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-12-22ARM: dts: TS-4800: add basic device treeDamien Riegel
This device tree adds support for TS-4800 by Technologic Systems. This board is based on MX51-babbage, but there are some subtle differences in the pins used, and there is an additional FPGA that is memory-mapped. More details here: http://wiki.embeddedarm.com/wiki/TS-4800 Signed-off-by: Damien Riegel <damien.riegel@savoirfairelinux.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
