path: root/arch/arm/boot/dts/imx53-qsb-common.dtsi
2018-11-04ARM: dts: imx53-qsb: disable 1.2GHz OPPSascha Hauer
[ Upstream commit eea96566c189c77e5272585984eb2729881a2f1d ] The maximum CPU frequency for the i.MX53 QSB is 1GHz, so disable the 1.2GHz OPP. This makes the board work again with configs that have cpufreq enabled like imx_v6_v7_defconfig on which the board stopped working with the addition of cpufreq-dt support. Fixes: 791f416608 ("ARM: dts: imx53: add cpufreq-dt support") Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2017-06-05ARM: dts: imx: Fix Ethernet PHY reset polarityFabio Estevam
The FEC driver ignores the GPIO polarity from 'phy-reset-gpios' and considers that the Ethernet PHY is active low, unless the property 'phy-reset-active-high' is present. Fix the device tree description by explicitly passing the 'GPIO_ACTIVE_LOW' flag to the 'phy-reset-gpios' property. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-29ARM: dts: imx53-qsb-common: fix FEC pinmux configPatrick Bruenn
The pinmux configuration in device tree was different from manual muxing in <u-boot>/board/freescale/mx53loco/mx53loco.c All pins were configured as NO_PAD_CTL(1 << 31), which was fine as the bootloader already did the correct pinmuxing for us. But recently u-boot is migrating to reuse device tree files from the kernel tree, so it seems to be better to have the correct pinmuxing in our files, too. Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-03-01ARM: dts: imx53-qsb: Fix gpio button polaritySascha Hauer
The polarity of the gpio buttons is defined to '0' which is active high. The buttons are active low though which has been verified by testing it and by looking into the schematics. While at it use defines rathers than numbers for the key codes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-02-29ARM: dts: imx: replace legacy wakeup property with 'wakeup-source'Sudeep Holla
Though the keyboard and other driver will continue to support the legacy "gpio-key,wakeup", "linux,wakeup" and "enable-sdio-wakeup" boolean property to enable the wakeup source, "wakeup-source" is the new standard binding. This patch replaces all the legacy wakeup properties with the unified "wakeup-source" property in order to avoid any futher copy-paste duplication. Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-09-01Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Olof Johansson: "Ladies and gentlemen, we proudly announce to you the latest branch of ARM device tree contents for the mainline kernel. Come and see, come and see! No less than twentythree thousand lines of additions! Just imagine the joy you will have of using your mainline kernel on newly supported hardware such as Rockchip Chromebooks, Freescale i.MX6UL boards or UniPhier hardware! For those of you feeling less adventurous, added hardware support on platforms such as TI DM814x and Gumstix Overo platforms might be more of your liking. We've got something for everyone here! Ahem. Cough. So, anyway... This is the usual large batch of DT updates. Lots and lots of smaller changes, some of the larger ones to point out are: - Rockchip veyron (Chromebook) support, as well as several other new boards - DRM support on Atmel AT91SAM9N12EK - USB additions on some Allwinner platforms - Mediatek MT6580 support - Freescale i.MX6UL support - cleanups for Renesas shmobile platforms - lots of added devices on LPC18xx - lots of added devices and boards on UniPhier There's also some dependent code added here, in particular some branches that are primarily merged through the clock tree" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (389 commits) ARM: tegra: Add gpio-ranges property ARM: tegra: Fix AHB base address on Tegra20, Tegra30 and Tegra114 ARM: tegra: Add Tegra124 PMU support ARM: tegra: jetson-tk1: Add GK20A GPU DT node ARM: tegra: venice2: Add GK20A GPU DT node ARM: tegra: Add IOMMU node to GK20A ARM: tegra: Add CPU regulator to the Jetson TK1 device tree ARM: tegra: Add entries for cpufreq on Tegra124 ARM: tegra: Enable the DFLL on the Jetson TK1 ARM: tegra: Add the DFLL to Tegra124 device tree ARM: dts: zynq: Add devicetree entry for Xilinx Zynq reset controller. ARM: dts: UniPhier: fix PPI interrupt CPU mask of timer nodes ARM: dts: rockchip: correct regulator power states for suspend ARM: dts: rockchip: correct regulator PM properties ARM: dts: vexpress: Use assigned-clock-parents for sp810 pinctrl: tegra: Only set the gpio range if needed arm: boot: dts: am4372: add ARM timers and SCU nodes ARM: dts: AM4372: Add the am4372-rtc compatible string ARM: shmobile: r8a7794 dtsi: Add CPG/MSTP Clock Domain ARM: shmobile: r8a7793 dtsi: Add CPG/MSTP Clock Domain ...
2015-07-24dts: imx53: fix sd card gpio polarity specified in device treeDong Aisheng
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios should be changed to GPIO_ACTIVE_HIGH. Otherwise, the SD may not work properly due to wrong polarity inversion specified in DT after switch to common parsing function mmc_of_parse(). Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2015-07-15ARM: dts: imx53-qsb: select open-drain mode for i2c1 padsLucas Stach
Both imx53-qsb and imx53-qsrb don't have external pull-up resistors on the I2C1 SCL and SDA lines populated. Select open-drain mode and enable the internal pull-up for both. Signed-off-by: Lucas Stach <l.stach@pengutronix.de> Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-07-08ARM: dts: imx53-qsb: fix TVE entryPhilipp Zabel
Correct HSYNC/VSYNC pins and add ddc-i2c-bus property Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-07-18ARM: dts: imx: remove ssi fsl,mode for audio cardsMarkus Pargmann
The DAI mode is and should be configured by the sound card driver as codec and ssi have to be in the right modes to communicate with each other. It is possible to operate the ssi unit or the codec in master mode, sometimes even on the same board in different configurations. With the latest changes in the fsl-ssi driver, the 'fsl,mode' property is only handled as a fallback property. If the sound card sets the DAI mode correctly, this fallback configuration is dropped. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: Add stdout-path property to i.MX boardsSascha Hauer
This adds the stdout-path property to various i.MX boards. Values of the property have been taken from barebox, so they should be correct. Also, the older linux,stdout-path property is converted to stdout-path. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: imx53-qsb-common: Add TVE supportFabio Estevam
Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-04-14ARM: dts: imx53-qsb-common: Fix memory region descriptionFabio Estevam
On mx53qsb there are two DRAM chip selects: CS0 at 0x70000000 CS1 at 0xb0000000 Each bank has a 512MB DRAM, giving a total of 1GB of system DRAM. Fix the memory layout to describe the hardware appropriately. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-04-05Merge tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC device tree changes from Arnd Bergmann: "A large part of the arm-soc patches are nowadays DT changes, adding support for new SoCs, boards and devices without changing kernel source. The plan is still to move the devicetree files out of the kernel tree and reduce the amount of churn going on here, but we keep finding reasons to delay doing that. Changes are really all over the place, with little sticking out particularly. We have contributions from a total of 116 people in this branch. Unfortunately, the size of this branch also causes a significant number of conflicts at the moment, typically when subsystem maintainers merge patches that change the driver at the same time as the dts files. In most cases this could be avoided because the dts changes are supposed to be compatible in both ways, and we are asking everyone to send ARM dts changes through our tree only" * tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits) dts: stmmac: Document the clocks property in the stmmac base document dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac. ARM: STi: stih41x: Add support for the FSM Serial Flash Controller ARM: STi: stih416: Add support for the FSM Serial Flash Controller ARM: tegra: fix Dalmore pinctrl configuration ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND ARM: dts: Build all keystone dt blobs ARM: dts: keystone: Fix control register range for clktsip ARM: dts: keystone: Fix domain register range for clkfftc1 ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap ARM: dts: bcm21664: Add device tree files. ARM: DT: bcm21664: Device tree bindings ARM: efm32: properly namespace i2c location property ARM: efm32: fix unit address part in USART2 device nodes' names ARM: mvebu: Enable NAND controller in Armada 385-DB ARM: mvebu: Add support for NAND controller in Armada 38x SoC ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs ...
2014-02-09ARM: dts: i.MX53: move common QSB nodes to new fileSteffen Trumtrar
There are (atleast) two versions of the i.MX53 LOCO: - the MCIMX53-START board - the MCIMX53-START-R board The MCIMX53-START-R has a mc34708 pmic and is otherwise the similar to the MCIMX53-START. To prepare for the START-R, move all common nodes to a new imx53-qsb-common.dtsi and remove everything but the board name and pmic from the imx53-qsb.dts. Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
