commit 94d76946859b4bcfa0da373357f14feda2af0622 upstream.
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
The DAI mode is and should be configured by the sound card driver as
codec and ssi have to be in the right modes to communicate with each
other. It is possible to operate the ssi unit or the codec in master mode,
sometimes even on the same board in different configurations.
With the latest changes in the fsl-ssi driver, the 'fsl,mode' property
is only handled as a fallback property. If the sound card sets the DAI
mode correctly, this fallback configuration is dropped.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
This adds the stdout-path property to various i.MX boards. Values
of the property have been taken from barebox, so they should be
correct. Also, the older linux,stdout-path property is converted
to stdout-path.
On mx53qsb there are two DRAM chip selects:
CS0 at 0x70000000
CS1 at 0xb0000000
Each bank has a 512MB DRAM, giving a total of 1GB of system DRAM.
Fix the memory layout to describe the hardware appropriately.
Pull ARM SoC device tree changes from Arnd Bergmann:
"A large part of the arm-soc patches are nowadays DT changes, adding
support for new SoCs, boards and devices without changing kernel
source. The plan is still to move the devicetree files out of the
kernel tree and reduce the amount of churn going on here, but we keep
finding reasons to delay doing that.
Changes are really all over the place, with little sticking out
particularly. We have contributions from a total of 116 people in
this branch.
Unfortunately, the size of this branch also causes a significant
number of conflicts at the moment, typically when subsystem
maintainers merge patches that change the driver at the same time as
the dts files. In most cases this could be avoided because the dts
changes are supposed to be compatible in both ways, and we are asking
everyone to send ARM dts changes through our tree only"
* tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits)
dts: stmmac: Document the clocks property in the stmmac base document
dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac.
ARM: STi: stih41x: Add support for the FSM Serial Flash Controller
ARM: STi: stih416: Add support for the FSM Serial Flash Controller
ARM: tegra: fix Dalmore pinctrl configuration
ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm
ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND
ARM: dts: Build all keystone dt blobs
ARM: dts: keystone: Fix control register range for clktsip
ARM: dts: keystone: Fix domain register range for clkfftc1
ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot
ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap
ARM: dts: bcm21664: Add device tree files.
ARM: DT: bcm21664: Device tree bindings
ARM: efm32: properly namespace i2c location property
ARM: efm32: fix unit address part in USART2 device nodes' names
ARM: mvebu: Enable NAND controller in Armada 385-DB
ARM: mvebu: Add support for NAND controller in Armada 38x SoC
ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs
ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs
There are (atleast) two versions of the i.MX53 LOCO:
- the MCIMX53-START board
- the MCIMX53-START-R board
The MCIMX53-START-R has a mc34708 pmic and is otherwise the similar to the
MCIMX53-START. To prepare for the START-R, move all common nodes to a new
imx53-qsb-common.dtsi and remove everything but the board name and pmic from
the imx53-qsb.dts.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
