Currently, all pinctrl setting nodes are defined in <soc>.dtsi, so that
boards that share the same pinctrl setting do not have to define it time
and time again in <board>.dts. However, along with the devices and use
cases being added continuously, the pinctrl setting nodes under iomuxc
becomes more than expected. This bloats device tree blob for particular
board unnecessarily since only a small subset of those pinctrl setting
nodes will be used by the board. It impacts not only the DTB file size
but also the run-time device tree lookup efficiency.
The patch moves all the pinctrl data into individual boards as needed.
With the changes, the pinctrl setting nodes becomes local to particular
board, and it makes no sense to continue numbering the setting for
given peripheral. Thus, all the pinctrl phandler name gets updated to
have only peripheral name in there.
Currently, all imx pinctrl drivers maintain a big array of struct
imx_pin_reg which hard-codes data like register offset and mux mode
setting for each pin function. Every time a new imx SoC support is
added, we need to add such a big mount of data. With moving to single
kernel build, it's only matter of time to be blamed on memory consuming.
With DTC pre-processor support in place, the patch moves all these data
into device tree by redefining the PIN_FUNC_ID in imxXX-pinfunc.h and
changing the PIN_FUNC_ID parsing code a little bit.
The pin id gets re-numbered based on mux register offset, or config
register offset if the pin has no mux register, so that kernel can
identify the pin id from register offsets provided by device tree.
As a bonus point of the change, those arbitrary magic numbers standing
for particular PIN_FUNC_ID in device tree sources are now replaced by
macros to improve the readability of dts files.
Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
Replace /include/ (dtc) with #include (C pre-processor) for all imx DT
files, so that gcc -E handles the entire include tree, and hence any of
those files can #include some other file e.g. for constant definitions.
This allows future use of #defines and header files in order to define
names for various constants, such as pinctrl settings. Use of those
features will increase the readability of the device tree files.
Following omap3-evm.dts way, it changes all imx dts files to use label
in board dts to refer to nodes defined by soc dtsi. Thus, the board
dts files become easier to read and edit with the least indentation
levels.
Add pinctrl settings for the exsiting devices in imx53-smd.dts.
Instead of adding sdma-ram-script-name into each board dts file, move
it to the SoC dtsi file instead.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Instead of enabling the watchdog in each individual dts file, select in
Changes in the dt2 branch move stuff around that gets changed
in the drivers/mmc branch. I chose a non-obvious resolution by
adding the new bus-width property into all the tegra sdhci device
nodes.
arch/arm/boot/dts/tegra-cardhu.dts
arch/arm/boot/dts/tegra-harmony.dts
arch/arm/boot/dts/tegra-ventana.dts
This patch unifies the current DT MMC bindings documentation and code,
adds generic MMC DT bindings documentation, and updates .dts files for
consistency.
[cjb: typo fixes, addition of max-frequency property]
Signed-off-by: Chris Ball <cjb@laptop.org>
It has been pointed out by device tree maintainer for several times
that the generic names 'serial' and 'ethernet' should be used for
those devices per ePAPR. Renames imx uart and fec device tree nodes
to stop them being bad examples.
Remove bootargs field as this information is retrieved from the bootloader.
UART1/UART2/... is more readable than UART0/UART1/... .
Remove redundant UART comments.
Signed-off-by: Richard Zhao <richard.zhao@linaro.org>
GPIO1/GPIO2/... is more readable than GPIO0/GPIO1/... .
Remove redundant gpio comments.
It adds device tree support for imx53 boards.
