Based on 1 normalized pattern(s):
the code contained herein is licensed under the gnu general public
license you may obtain a copy of the gnu general public license
version 2 or later at the following locations http www opensource
org licenses gpl license html http www gnu org copyleft gpl html
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 161 file(s).
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.383790741@linutronix.de
Boards based on imx53 have duplicate memory nodes:
- One coming from the board dts file: memory@
- One coming from the imx53.dtsi file.
Fix the duplication by removing the memory node from the dtsi file
and by adding 'device_type = "memory";' in the board dts.
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Fix the following warnings from dtc by adding the unit name to memory
nodes:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
Converted using the following command:
perl -p0777i -e 's/memory \{\n\t\treg = \<0x+([0-9a-f])/memory\@$1$\0000000 \{\n\t\treg = <0x$1/m' `find ./arch/arm/boot/dts -name "imx*"`
The files below were manually fixed:
-imx1-ads.dts
-imx1-apf9328.dts
-imx6q-pistachio.dts
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
The at24 driver allows to register I2C EEPROM chips using different vendor
and devices, but the I2C subsystem does not take the vendor into account
when matching using the I2C table since it only has device entries.
But when matching using an OF table, both the vendor and device has to be
taken into account so the driver defines only a set of compatible strings
using the "atmel" vendor as a generic fallback for compatible I2C devices.
So add this generic fallback to the device node compatible string to make
the device to match the driver using the OF device ID table.
Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org>
Since commit b36581df7e78 ("spi: imx: Using existing properties for
chipselects") the device tree property 'fsl,spi-num-chipselects' is
unused and it is already marked as obsolete in device tree binding
documentation. Remove the property from the existing DTS files to
avoid its reoccurence on copying.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts
DT property"), the Freescale IMX UART driver recognizes the generic
"uart-has-rtscts" DT property, deprecating the vendor-specific
"fsl,uart-has-rtscts" DT property. Hence replace the latter by the
former in all DTS files.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
The device tree specification recommends that generic name should be
used for nodes. So instead of naming those fixed regulator nodes
arbitrarily, let's use the generic name 'regulator@num' for those nodes.
Currently, all pinctrl setting nodes are defined in <soc>.dtsi, so that
boards that share the same pinctrl setting do not have to define it time
and time again in <board>.dts. However, along with the devices and use
cases being added continuously, the pinctrl setting nodes under iomuxc
becomes more than expected. This bloats device tree blob for particular
board unnecessarily since only a small subset of those pinctrl setting
nodes will be used by the board. It impacts not only the DTB file size
but also the run-time device tree lookup efficiency.
The patch moves all the pinctrl data into individual boards as needed.
With the changes, the pinctrl setting nodes becomes local to particular
board, and it makes no sense to continue numbering the setting for
given peripheral. Thus, all the pinctrl phandler name gets updated to
have only peripheral name in there.
Add WP/CD pinctrl for esdhc2.
Also, add vmmc-supply for esdhc2.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
I2S_MCLK is moved from pad GPIO19 to GPIO0, which can be muxed to the
ssi_ext1 clock signal. #SYSTEM_DOWN is moved from pad GPIO0 to GPIO19.
Add #PHY_RESET and LCD_CONTRAST.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
BIT(31) is NO_PAD_CTL, not BIT(16)
It's active high, not active low.
Currently, all imx pinctrl drivers maintain a big array of struct
imx_pin_reg which hard-codes data like register offset and mux mode
setting for each pin function. Every time a new imx SoC support is
added, we need to add such a big mount of data. With moving to single
kernel build, it's only matter of time to be blamed on memory consuming.
With DTC pre-processor support in place, the patch moves all these data
into device tree by redefining the PIN_FUNC_ID in imxXX-pinfunc.h and
changing the PIN_FUNC_ID parsing code a little bit.
The pin id gets re-numbered based on mux register offset, or config
register offset if the pin has no mux register, so that kernel can
identify the pin id from register offsets provided by device tree.
As a bonus point of the change, those arbitrary magic numbers standing
for particular PIN_FUNC_ID in device tree sources are now replaced by
macros to improve the readability of dts files.
Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
Replace /include/ (dtc) with #include (C pre-processor) for all imx DT
files, so that gcc -E handles the entire include tree, and hence any of
those files can #include some other file e.g. for constant definitions.
This allows future use of #defines and header files in order to define
names for various constants, such as pinctrl settings. Use of those
features will increase the readability of the device tree files.
The tqma53 is an embedded module that has some features on board (e.g. emmc),
but mostly just provides access to them on its interface.
Going along with the imx53.dtsi, the tqma53.dtsi specifies the existing
devices and their pinctrl for this module. All devices that are not on the
module are disabled by default and need to be enabled in a baseboard DT.
