path: root/arch/arm/boot/dts/imx53-tx53.dtsi
2016-06-11ARM: dts: imx: Use generic uart-has-rtscts DT propertyGeert Uytterhoeven
As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts DT property"), the Freescale IMX UART driver recognizes the generic "uart-has-rtscts" DT property, deprecating the vendor-specific "fsl,uart-has-rtscts" DT property. Hence replace the latter by the former in all DTS files. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-02-29ARM: dts: imx53-tx53: set correct mclk frequencyLothar Waßmann
The reference clock for the SGTL5000 is generated by a 26MHz crystal oscillator on the Ka-Ro electronics STK5 eval kits. Use the correct frequency setting in DTB. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-02-29ARM: dts: imx: replace legacy wakeup property with 'wakeup-source'Sudeep Holla
Though the keyboard and other driver will continue to support the legacy "gpio-key,wakeup", "linux,wakeup" and "enable-sdio-wakeup" boolean property to enable the wakeup source, "wakeup-source" is the new standard binding. This patch replaces all the legacy wakeup properties with the unified "wakeup-source" property in order to avoid any futher copy-paste duplication. Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-07-24dts: imx53: fix sd card gpio polarity specified in device treeDong Aisheng
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios should be changed to GPIO_ACTIVE_HIGH. Otherwise, the SD may not work properly due to wrong polarity inversion specified in DT after switch to common parsing function mmc_of_parse(). Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2014-07-18ARM: dts: imx: remove ssi fsl,mode for audio cardsMarkus Pargmann
The DAI mode is and should be configured by the sound card driver as codec and ssi have to be in the right modes to communicate with each other. It is possible to operate the ssi unit or the codec in master mode, sometimes even on the same board in different configurations. With the latest changes in the fsl-ssi driver, the 'fsl,mode' property is only handled as a fallback property. If the sound card sets the DAI mode correctly, this fallback configuration is dropped. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-02-10ARM: dts: mx53: Remove 'enable-active-low' propertyFabio Estevam
'enable-active-low' is not a valid property for a GPIO controlled regulator. According to Documentation/devicetree/bindings/regulator/gpio-regulator.txt: "Optional properties: ... - enable-active-high : Polarity of GPIO is active high (default is low)." ,so the correct way to define an active-low GPIO controlled regulator is to simply not pass 'enable-active-high'. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: imx53: add support for Ka-Ro TX53 modulesLothar Waßmann
This patch adds support for the Ka-Ro electronics GmbH TX53 modules. There are two distinct module types. One with an LVDS display interface and SATA support, the other with a parallel LCD interface and no SATA interface. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-02-09ARM: dts: imx: use generic node name for fixed regulatorShawn Guo
The device tree specification recommends that generic name should be used for nodes. So instead of naming those fixed regulator nodes arbitrarily, let's use the generic name 'regulator@num' for those nodes. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-17ARM: dts: add Ka-Ro tx53 devicetreeSteffen Trumtrar
This adds support for the Ka-Ro TX53 System-On-Module. As a baseboard is needed to operate it, only a *.dtsi and no Makefile entry. Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
