path: root/arch/arm/boot/dts/imx53-voipac-bsb.dts
2014-07-18ARM: dts: imx: remove ssi fsl,mode for audio cardsMarkus Pargmann
The DAI mode is and should be configured by the sound card driver as codec and ssi have to be in the right modes to communicate with each other. It is possible to operate the ssi unit or the codec in master mode, sometimes even on the same board in different configurations. With the latest changes in the fsl-ssi driver, the 'fsl,mode' property is only handled as a fallback property. If the sound card sets the DAI mode correctly, this fallback configuration is dropped. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-02-09ARM: dts: i.MX53: Devicetree for Voipac Baseboard using x53-dmm-668 moduleRostislav Lisovy
Supported peripherals: Audio -- headphone output, LEDs, Buttons (using keyboard controller), SD-card. Signed-off-by: Rostislav Lisovy <lisovy@gmail.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
