cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios
should be changed to GPIO_ACTIVE_HIGH.
Otherwise, the SD may not work properly due to wrong polarity inversion
specified in DT after switch to common parsing function mmc_of_parse().
Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
The DAI mode is and should be configured by the sound card driver as
codec and ssi have to be in the right modes to communicate with each
other. It is possible to operate the ssi unit or the codec in master mode,
sometimes even on the same board in different configurations.
With the latest changes in the fsl-ssi driver, the 'fsl,mode' property
is only handled as a fallback property. If the sound card sets the DAI
mode correctly, this fallback configuration is dropped.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Supported peripherals: Audio -- headphone output, LEDs, Buttons
(using keyboard controller), SD-card.
Signed-off-by: Rostislav Lisovy <lisovy@gmail.com>
