path: root/arch/arm/boot/dts/imx53-voipac-bsb.dts
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 159Thomas Gleixner
Based on 1 normalized pattern(s): the code contained herein is licensed under the gnu general public license you may obtain a copy of the gnu general public license version 2 or later at the following locations http www opensource org licenses gpl license html http www gnu org copyleft gpl html extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 161 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Richard Fontana <rfontana@redhat.com> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070033.383790741@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-08ARM: dts: imx: Add missing #sound-dai-cells for sgtl5000 codecRob Herring
dtc now warns about missing #sound-dai-cells: arch/arm/boot/dts/imx6ul-geam.dtb: Warning (sound_dai_property): /sound/simple-audio-card,codec: Missing property '#sound-dai-cells' in node /soc/aips-bus@2100000/i2c@21a0000/codec@a or bad phandle (referred from sound-dai[0]) arch/arm/boot/dts/imx6ul-isiot-emmc.dtb: Warning (sound_dai_property): /sound/simple-audio-card,codec: Missing property '#sound-dai-cells' in node /soc/aips-bus@2100000/i2c@21a0000/codec@a or bad phandle (referred from sound-dai[0]) arch/arm/boot/dts/imx6ul-isiot-nand.dtb: Warning (sound_dai_property): /sound/simple-audio-card,codec: Missing property '#sound-dai-cells' in node /soc/aips-bus@2100000/i2c@21a0000/codec@a or bad phandle (referred from sound-dai[0]) Lots of i.MX boards use the SGTL5000 codec, but not all get the warning because only some reference the codec with "sound-dai" property. However, the codec should always provide #sound-dai-cells regardless, so fix all the occurrences. Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-10-20arm: dts: fix unit-address leading 0sRob Herring
Fix dtc warnings for 'simple_bus_reg' due to leading 0s. Converted using the following command: perl -p -i -e 's/\@0+([0-9a-f])/\@$1/g' `find arch/arm/boot/dts -type -f -name '*.dts*' Dropped changes to ARM, Ltd. boards LED nodes and manually fixed up some occurrences of uppercase hex. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-07-24dts: imx53: fix sd card gpio polarity specified in device treeDong Aisheng
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios should be changed to GPIO_ACTIVE_HIGH. Otherwise, the SD may not work properly due to wrong polarity inversion specified in DT after switch to common parsing function mmc_of_parse(). Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2014-07-18ARM: dts: imx: remove ssi fsl,mode for audio cardsMarkus Pargmann
The DAI mode is and should be configured by the sound card driver as codec and ssi have to be in the right modes to communicate with each other. It is possible to operate the ssi unit or the codec in master mode, sometimes even on the same board in different configurations. With the latest changes in the fsl-ssi driver, the 'fsl,mode' property is only handled as a fallback property. If the sound card sets the DAI mode correctly, this fallback configuration is dropped. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-02-09ARM: dts: i.MX53: Devicetree for Voipac Baseboard using x53-dmm-668 moduleRostislav Lisovy
Supported peripherals: Audio -- headphone output, LEDs, Buttons (using keyboard controller), SD-card. Signed-off-by: Rostislav Lisovy <lisovy@gmail.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
