The i.MX53 has an integrated secure real time clock. Add it to the dtsi.
Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
Commit 7f107887d199 ("ARM: dts: imx: Remove skeleton.dtsi") causes boot
issues when the bootloader does not create a 'chosen' node if such node
is not present in the dtb.
The reason for the boot failure is well explained by Javier Martinez
Canillas: "the decompressor relies on a pre-existing chosen node to be
available to insert the command line and merge other ATAGS info."
, so pass an empty 'chosen' node to fix the boot problem.
This issue has been seen in the kernelci reports with Barebox as
bootloader.
Also pass the 'memory' node in order to fix boot issues on the SolidRun
iMX6 platforms.
Fixes: 7f107887d199 ("ARM: dts: imx: Remove skeleton.dtsi")
Reported-by: kernelci.org bot <bot@kernelci.org>
Reported-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
As explained by commit 9c0da3cc61f1233c ("ARM: dts: explicitly mark
skeleton.dtsi as deprecated"), including skeleton.dtsi is deprecated.
This fixes the following warning with W=1:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
Fixed code indent tabs in respetcive imx23, imx51, imx53, imx6dl, imx6q
and imx6sx dtsi and dts files.
Signed-off-by: Jagan Teki <jagan@openedev.com>
We have the following messages that tell csi devices are not used:
imx-ipuv3 18000000.ipu: no port@0 node in /soc/ipu@18000000, not using CSI0
imx-ipuv3 18000000.ipu: no port@1 node in /soc/ipu@18000000, not using CSI1
So we add them in the common device tree to make CSI ports available on
imx53 boards.
Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.co.uk>
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
In order to use sdma with UART, we need to add DMA configuration in device tree.
Allows to use the more meaningful IRQ flag defines instead of
the raw values.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
The chipidea driver adds an extra line of spam to the log when a
host-only chipidea instance is left set to the default of a dual role
controller.
[ 2.010873] ci_hdrc ci_hdrc.1: doesn't support gadget
Set the dr_mode property to host on all the host-only nodes
to avoid this warning.
Signed-off-by: Matt Porter <mporter@konsulko.com>
Acked-by: Peter Chen <peter.chen@freescale.com>
The i.MX53 has a SAHARA v4 core. Add it to the dtsi.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Update the VPU compatible strings to also use "cnm,coda<model>".
Add all required properties for the cpufreq-dt driver.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
SSI block has 'ipg' clock for internal peripheral access and also 'baud' clock
for generating bit clock when SSI operates in master mode.
Add the extra 'baud' clock so that we can have SSI functional in master mode.
Pull ARM SoC DT updates from Arnd Bergmann:
"As usual, this is the largest branch, though this time a little under
half of the total changes with 307 individual non-merge changesets.
The largest changes are the addition of new machines, in particular
the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support
for the old i.MX1 platform.
Other changes include
- at91: various sam9 and sama5 updates
- exynos: much extended Peach Pi/Pit (Chromebook 2) support
- keystone: new peripherals
- meson: added DT for meson6 SoC
- mvebu: new device support for Armada 370/375
- qcom: improved support for IPQ8064 and MSM8x60
- rockchip: much improved support for rk3288
- shmobile: lots of updates all over the place
- sunxi: dts license change
- sunxi: more a23 device support
- vexpress: CLCD DT description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits)
ARM: DTS: meson: update DTSI to add watchdog node
ARM: dts: keystone-k2l: fix mdio io start address
ARM: dts: keystone-k2e: fix mdio io start address
ARM: dts: keystone-k2e: update usb1 node for dma properties
ARM: dts: keystone: fix io range for usb_phy0
Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt"
Revert "ARM: dts: hix5hd2: add wdg node"
ARM: dts: add rk3288 i2s controller
ARM: vexpress: Add CLCD Device Tree properties
ARM: bcm2835: add I2S pinctrl to device tree
ARM: meson: documentation: add bindings documentation
ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS
ARM: dts: mt6589: Change compatible string for GIC
ARM: dts: mediatek: Add compatible property for aquaris5
ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk
ARM: dts: mt6589: Fix typo in GIC unit address
ARM: dts: Build dtb for Mediatek board
ARM: dts: keystone: fix bindings for pcie and usb clock nodes
ARM: dts: keystone: k2l: Fix chip selects for SPI devices
ARM: dts: keystone: add dsp gpio controllers nodes
The i.MX53 has a Cortex-A8 Performance Monitor Unit.
Add it to the dtsi.
This patch adds simple-card support to the i.MX SoCs.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
using LVDS channel 1 on an i.MX53 leads to following error:
imx-ldb 53fa8008.ldb: unable to set di0 parent clock to ldb_di1
This comes from imx_ldb_set_clock with mux = 0. Mux parameter must be "1" for
reparenting di1 clock to ldb_di1. The value of the mux param comes from device
tree port settings.
On i.MX5, the internal two-input-multiplexer is used. Due to hardware limitations,
only one port (port@[0,1]) can be used for each channel (lvds-channel@[0,1],
respectively)
Documentation update suggested by Philipp Zabel <p.zabel@pengutronix.de>
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
Fixes: e05c8c9a790a ("ARM: dts: imx53: Add IPU DI ports and endpoints, move imx-drm node to dtsi")
Cc: <stable@vger.kernel.org>
The VPU on i.MX53 has two distinct clocks for register access and
internal function.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Fixes: fbf970f61eb9 ("ARM: dts: mx53qsb: Enable VPU support")
Per the binding doc imx-sata.txt, the first entry of clock-names should
be "sata" than anything else. Correct it for imx53 SATA node.
It works for now only because SATA driver gets clock by index so far.
The AHB to IP bridges (AIPSTZ) allow fine grained access rights management.
Add both bridges to the DT.
All imx5*.dtsi files define the generic dma bindings. Drop the old
non-generic fsl,ssi-dma-events.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next
Pull ARM SoC devicetree updates from Olof Johansson:
"As with previous release, this continues to be among the largest
branches we merge, with lots of new contents.
New things for this release are among other things:
- DTSI contents for the new SoCs supported in 3.16 (see SoC pull request)
- Qualcomm APQ8064 and APQ8084 SoCs and eval boards
- Nvidia Jetson TK1 development board (Tegra T124-based)
Two new SoCs that didn't need enough new platform code to stand out
enough for me to notice when writing the SoC tag, but that adds new DT
contents are:
- TI DRA72
- Marvell Berlin 2Q"
* tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits)
ARM: dts: add secure firmware support for exynos5420-arndale-octa
ARM: dts: add pmu sysreg node to exynos3250
ARM: dts: correct the usb phy node in exynos5800-peach-pi
ARM: dts: correct the usb phy node in exynos5420-peach-pit
ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410
ARM: dts: add dts files for exynos3250 SoC
ARM: dts: add mfc node for exynos5800
ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi
ARM: dts: enable fimd for exynos5800-peach-pi
ARM: dts: enable display controller for exynos5800-peach-pi
ARM: dts: enable hdmi for exynos5800-peach-pi
ARM: dts: add dts file for exynos5800-peach-pi board
ARM: dts: add dts file for exynos5800 SoC
ARM: dts: add dts file for exynos5260-xyref5260 board
ARM: dts: add dts files for exynos5260 SoC
ARM: dts: update watchdog node name in exynos5440
ARM: dts: use key code macros on Origen and Arndale boards
ARM: dts: enable RTC and WDT nodes on Origen boards
ARM: dts: qcom: Add APQ8084-MTP board support
ARM: dts: qcom: Add APQ8084 SoC support
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
This IP module is always present and has no external connections.
There is no reason to disable it in the device tree.
The IPU register space is 128MB, not 2GB.
Fixes: abed9a6bf2bb 'ARM i.MX53: Add IPU support'
Acked-by: Shawn Guo <shawn.guo@freescale.com>
Add alias for FEC ethernet on i.MX to allow bootloaders (like U-Boot)
patch-in the MAC address for FEC using this alias.
Per bindings of fixed-clock, #clock-cells is a required property. Let's
add it for those fixed rate clocks.
The 'remote-endpoint' property should point back to ipu_di1_lvds1
rather than ipu_di0_lvds0.
Pull ARM SoC device tree changes from Arnd Bergmann:
"A large part of the arm-soc patches are nowadays DT changes, adding
support for new SoCs, boards and devices without changing kernel
source. The plan is still to move the devicetree files out of the
kernel tree and reduce the amount of churn going on here, but we keep
finding reasons to delay doing that.
Changes are really all over the place, with little sticking out
particularly. We have contributions from a total of 116 people in
this branch.
Unfortunately, the size of this branch also causes a significant
number of conflicts at the moment, typically when subsystem
maintainers merge patches that change the driver at the same time as
the dts files. In most cases this could be avoided because the dts
changes are supposed to be compatible in both ways, and we are asking
everyone to send ARM dts changes through our tree only"
* tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits)
dts: stmmac: Document the clocks property in the stmmac base document
dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac.
ARM: STi: stih41x: Add support for the FSM Serial Flash Controller
ARM: STi: stih416: Add support for the FSM Serial Flash Controller
ARM: tegra: fix Dalmore pinctrl configuration
ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm
ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND
ARM: dts: Build all keystone dt blobs
ARM: dts: keystone: Fix control register range for clktsip
ARM: dts: keystone: Fix domain register range for clkfftc1
ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot
ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap
ARM: dts: bcm21664: Add device tree files.
ARM: DT: bcm21664: Device tree bindings
ARM: efm32: properly namespace i2c location property
ARM: efm32: fix unit address part in USART2 device nodes' names
ARM: mvebu: Enable NAND controller in Armada 385-DB
ARM: mvebu: Add support for NAND controller in Armada 38x SoC
ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs
ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs
This patch connects IPU and display encoder (VGA, LVDS)
device tree nodes, as well as parallel displays on the DISP0
and DISP1 outputs, using the OF graph bindings described in
Documentation/devicetree/bindings/media/video-interfaces.txt
The IPU ports correspond to the two display interfaces. The
order of endpoints in the ports is arbitrary.
Since the imx-drm node now only needs to contain links to the
display interfaces, it can be moved to the SoC dtsi level. At
the board level, only connections between the display interface
ports and encoders or panels have to be added.
imx51-ssi and imx21-ssi are different IPs. imx51-ssi supports online
reconfiguration and needs this for correct interaction with SDMA. This
patch adds imx51-ssi before each imx21-ssi for all imx5 SoCs.
This is to permit to use of the includes in the boards dts.
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: devicetree@vger.kernel.org
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Eric Bénard <eric@eukrea.com>
Signed-off-by: Denis Carikli <denis@eukrea.com>
The AHCI-IMX driver now supports i.MX53 as well. Add DT node.
Cc: Richard Zhu <r65037@freescale.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Linux-IDE <linux-ide@vger.kernel.org>
For better readability and no need to look up numbers
in the documentation anymore.
Currently, all pinctrl setting nodes are defined in <soc>.dtsi, so that
boards that share the same pinctrl setting do not have to define it time
and time again in <board>.dts. However, along with the devices and use
cases being added continuously, the pinctrl setting nodes under iomuxc
becomes more than expected. This bloats device tree blob for particular
board unnecessarily since only a small subset of those pinctrl setting
nodes will be used by the board. It impacts not only the DTB file size
but also the run-time device tree lookup efficiency.
The patch moves all the pinctrl data into individual boards as needed.
With the changes, the pinctrl setting nodes becomes local to particular
board, and it makes no sense to continue numbering the setting for
given peripheral. Thus, all the pinctrl phandler name gets updated to
have only peripheral name in there.
Signed-off-by: Rostislav Lisovy <lisovy@gmail.com>
Add missing ocram gate clock for imx53 and also represent it in device
tree ocram node.
Updates SSI nodes to adopt generic DMA bindings.
To make it consistent with the other i.mx SoCs, let's add the cpus nodes.
Add the #dma-cells property for all the sdma in all the imx platforms.
Signed-off-by: Huang Shijie <b32955@freescale.com>
Enable Video Processing Unit (VPU) support.
This patch enables the On-Chip SRAM (OCRAM) on i.MX53 and i.MX6 SoCs.
This allows to order the i2c and spi devices correctly.
While at it reorder the aliases entries alphabetically.
The current default pad configuration for UART RX and TX pads sets a 360k
pull-down and writes 1 to a reserved bit (1 << 0). It doesn't seem right to
me that in idle state, the UART has to keep the signal high against a
pull-down resistor.
This patch instead sets a 100k pull-up, which incidentally corresponds to the
register reset value for all but one (MX53_PAD_KEY_ROW0__UART4_RXD_MUX) pad,
and removes the write to the reserved bit.
This adds the Television Encoder (TVEv2) device tree node
to the i.MX53 dtsi.
Add a group to the fec pinctrl, for use with MII interface.
Signed-off-by: Jonas Andersson <jonas@microbit.se>
Add ecspi2 pinctrl.
Add a group to the cspi pinctrl.
Add support for CLAA WVGA display for i.MX53 QSB.
Signed-off-by: Rogerio Pimentel <rogerio.pimentel@freescale.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
