Add a group to the cspi pinctrl.
Signed-off-by: Jonas Andersson <jonas@microbit.se>
Add support for CLAA WVGA display for i.MX53 QSB.
Signed-off-by: Rogerio Pimentel <rogerio.pimentel@freescale.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Add a group to the uart2 pinctrl.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Add a group to the uart1 pinctrl.
Add pinctrl for pwm2.
Add a group to the ecspi pinctrl.
Add a group to the csi pinctrl.
Add a group to the audmux pinctrl.
This patch adds pinctrl data for PWM1 on MX53.
This patch adds pinmux for IPU LCD 1 and IPU LVDS.
This patch adds pinctrl data for NAND on MX53.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
This patch adds pinctrl data for different mux of I2C2 on MX53.
This patch adds pinctrl data for different mux of I2C1 on MX53.
This patch adds pinctrl data for different mux of CAN1 on MX53.
This patch adds pinctrl data for the AUDMUX4 on MX53.
This allows to order the i2c character devices correctly,
so that /dev/i2c-0 corresponds to i2c1, /dev/i2c-1 corresponds
to i2c2, and so on. Currently they are ordered by register
address.
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
The CSPI controller has only one clock, but the driver spi-imx.c needs
clock "per" to calculate bitrate divisor.
Also, link SRC to IPU via phandle.
Reviewed-by: Pavel Machek <pavel@ucw.cz>
The GPT is the GPT timer found on i.MX SoCs. This patch adds the
devicetree node for it.
Currently, all imx pinctrl drivers maintain a big array of struct
imx_pin_reg which hard-codes data like register offset and mux mode
setting for each pin function. Every time a new imx SoC support is
added, we need to add such a big mount of data. With moving to single
kernel build, it's only matter of time to be blamed on memory consuming.
With DTC pre-processor support in place, the patch moves all these data
into device tree by redefining the PIN_FUNC_ID in imxXX-pinfunc.h and
changing the PIN_FUNC_ID parsing code a little bit.
The pin id gets re-numbered based on mux register offset, or config
register offset if the pin has no mux register, so that kernel can
identify the pin id from register offsets provided by device tree.
As a bonus point of the change, those arbitrary magic numbers standing
for particular PIN_FUNC_ID in device tree sources are now replaced by
macros to improve the readability of dts files.
Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
Replace /include/ (dtc) with #include (C pre-processor) for all imx DT
files, so that gcc -E handles the entire include tree, and hence any of
those files can #include some other file e.g. for constant definitions.
This allows future use of #defines and header files in order to define
names for various constants, such as pinctrl settings. Use of those
features will increase the readability of the device tree files.
Signed-off-by: Martin Fuzzey <mfuzzey@parkeon.com>
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
Add pinctrl for cspi, csi.
Add new pingroups for can1 and uart3.
The second FlexCAN port uses different clock than the first one, configure
correct clock to prevent hanging of the system during bringing up of the port.
Pull ARM SoC device tree conversions and enablement from Olof Johansson:
"Continued device tree conversion and enablement across a number of
platforms; Kirkwood, tegra, i.MX, Exynos, zynq and a couple of other
smaller series as well.
ux500 has seen continued conversion for platforms. Several platforms
have seen pinctrl-via-devicetree conversions for simpler
multiplatform. Tegra is adding data for new devices/drivers, and
Exynos has a bunch of new bindings and devices added as well.
So, pretty much the same progression in the right direction as the
last few releases."
Fix up conflicts as per Olof.
* tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (185 commits)
ARM: ux500: Rename dbx500 cpufreq code to be more generic
ARM: dts: add missing ux500 device trees
ARM: ux500: Stop registering the PCM driver from platform code
ARM: ux500: Move board specific GPIO info out to subordinate DTS files
ARM: ux500: Disable the MMCI gpio-regulator by default
ARM: Kirkwood: remove kirkwood_ehci_init() from new boards
ARM: Kirkwood: Add support LED of OpenBlocks A6
ARM: Kirkwood: Convert to EHCI via DT for OpenBlocks A6
ARM: kirkwood: Add NAND partiton map for OpenBlocks A6
ARM: kirkwood: Add support second I2C bus and RTC on OpenBlocks A6
ARM: kirkwood: Add support DT of second I2C bus
ARM: kirkwood: Convert mplcec4 board to pinctrl
ARM: Kirkwood: Convert km_kirkwood to pinctrl
ARM: Kirkwood: support 98DX412x kirkwoods with pinctrl
ARM: Kirkwood: Convert IX2-200 to pinctrl.
ARM: Kirkwood: Convert lsxl boards to pinctrl.
ARM: Kirkwood: Convert ib62x0 to pinctrl.
ARM: Kirkwood: Convert GoFlex Net to pinctrl.
ARM: Kirkwood: Convert dreamplug to pinctrl.
ARM: Kirkwood: Convert dockstar to pinctrl.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Similarly as it was done for mx6q, use a DT lookup in order to make maintainance
task for the clock devices easier.
This adds the IPU device to the devicetree.
Having labels before each node allows board bindings to reference
to nodes by using the &nodename {} notation. This way boards do not
have to resemble the whole devicetree layout. Due to less indention
needed the board files also get better readability. Since the label
make the documentation behind the nodes unnecessary it is removed.
This patch supplements pinctl support on i.MX53.
Signed-off-by: Roland Stigge <stigge@antcom.de>
According to Documentation/devicetree/bindings/mmc/mmc.txt bus-width
is a mandatory property. While this is currently enforced nowhere, it's
a good habit to just add the property now to allow to add common helper
functionality for the mmc property parsing later.
This is some amount of work left/forgot from device tree conversion.
Instead of checking cpu_is_xxx to determine the controller type, the
driver should use platform_device_id, which should match the device
tree compatible string.
The patch changes the driver to use platform_device_id rather than
cpu_is_xxx to determine the controller type/version. It also updates
the platform code and device tree source accordingly.
As the result, mach/hardware.h inclusion gets removed from the driver.
Cc: Wolfram Sang <w.sang@pengutronix.de>
Cc: linux-i2c@vger.kernel.org
git://git.infradead.org/users/dhowells/linux-headers
UAPI Disintegration 2012-10-09
MAINTAINERS
arch/arm/configs/bcmring_defconfig
arch/arm/mach-imx/clk-imx51-imx53.c
drivers/mtd/nand/Kconfig
drivers/mtd/nand/bcm_umi_nand.c
drivers/mtd/nand/nand_bcm_umi.h
drivers/mtd/nand/orion_nand.c
Add pinctrl settings for the exsiting devices in imx53-smd.dts.
Add pinctrl settings for the exsiting devices in imx53-evk.dts.
Add pinctrl settings for the exsiting devices in imx53-ard.dts.
Add pinctrl settings for existing devices in imx53-qsb.dts.
Instead of adding sdma-ram-script-name into each board dts file, move
it to the SoC dtsi file instead.
Instead of enabling the watchdog in each individual dts file, select in
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux
Having missed the merge window, update to 3.6-rc2 to avoid conflicts with
new patches.
Add alias for gpio nodes, so that gpio driver can identify the port
number and then specify a sensible gpio base rather than using the
one dynamically allocated by gpio core.
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO changes from Linus Walleij:
- New driver for AMD-8111 southbridge GPIOs
- New driver for Wolfson Micro Arizona devices
- Propagate device tree parse errors
- Probe deferral finalizations - all expected calls to GPIO will now
hopefully request deferral where apropriate
- Misc updates to TCA6424, WM8994, LPC32xx, PCF857x, Samsung MXC, OMAP
and PCA953X drivers.
Fix up gpio_idx conflicts in drivers/gpio/gpio-mxc.c
* tag 'gpio-for-v3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpio: of_get_named_gpio_flags() return -EPROBE_DEFER if GPIO not yet available
gpiolib: Defer failed gpio requests by default
MAINTAINERS: add entry OMAP GPIO driver
gpio/pca953x: increase variables size to support 24 bit of data
GPIO: PCA953X: Increase size of invert variable to support 24 bit
gpio/omap: move bank->dbck initialization to omap_gpio_mod_init()
gpio/mxc: use the edge_sel feature if available
gpio: propagate of_parse_phandle_with_args errors
gpio: samsung: add flags specifier to device-tree binding
gpiolib: Add support for Wolfson Microelectronics Arizona class devices
gpio: gpio-lpc32xx: Add gpio_to_irq mapping
gpio: pcf857x: share 8/16 bit access functions
gpio: LPC32xx: Driver cleanup
MAINTAINERS: Add Wolfson gpiolib drivers to the Wolfson entry
gpiolib: wm8994: Convert to devm_kzalloc()
gpiolib: wm8994: Use irq_domain mappings for gpios
gpio: add a driver for GPIO pins found on AMD-8111 south bridge chips
gpio/tca6424: merge I2C transactions, remove cast
gpio/of: fix a typo of comment message
