path: root/arch/arm/boot/dts/imx6dl-aristainetos_4.dts
2019-06-19treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 500Thomas Gleixner
Based on 2 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation this program is free software you can redistribute it and or modify it under the terms of the gnu general public license version 2 as published by the free software foundation # extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 4122 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Enrico Weigelt <info@metux.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-10ARM: dts: imx6qdl: Fix memory node duplicationMarco Franchi
Boards based on imx6qdl have duplicate memory nodes: - One coming from the board device tree file: memory@ - One coming from the imx6qdl.dtsi file. Fix the duplication by removing the memory node from the imx6qdl.dtsi file and by adding 'device_type = "memory";' in the board Device Tree. Converted using the following command: perl -p0777i -e 's/memory\@10000000 \{\n/memory\@10000000 \{\n\t\tdevice_type = \"memory\";\n/m' `find ./arch/arm/boot/dts -name "imx6*"`` Reported-by: Rob Herring <robh@kernel.org> Signed-off-by: Marco Franchi <marco.franchi@nxp.com> Reviewed-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2018-02-12ARM: dts: imx: Add memory node unit nameMarco Franchi
Fix the following warnings from dtc by adding the unit name to memory nodes: Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name Converted using the following command: perl -p0777i -e 's/memory \{\n\t\treg = \<0x+([0-9a-f])/memory\@$1$\0000000 \{\n\t\treg = <0x$1/m' `find ./arch/arm/boot/dts -name "imx*"` The files below were manually fixed: -imx1-ads.dts -imx1-apf9328.dts -imx6q-pistachio.dts Signed-off-by: Marco Franchi <marco.franchi@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-12-26ARM: dts: imx6qdl-aristainetos: Move display node out of 'soc'Fabio Estevam
Move disp0 node from soc node to root node. disp0 node does not have any register properties and thus shouldn't be placed on the bus. This fixes the following build warnings with W=1: arch/arm/boot/dts/imx6dl-aristainetos_4.dtb: Warning (simple_bus_reg): Node /soc/disp0 missing or empty reg/ranges property Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-10-13ARM: dts: imx: Fix incorrect display nodes notationMarco Franchi
The following build warnings are seen with W=1: Warning (unit_address_vs_reg): Node /display@di0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /display@di1 has a unit name, but no reg property Fix all these warnings by changing 'display@diX' to 'dispX'. Signed-off-by: Marco Franchi <marco.franchi@nxp.com> Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-02ARM: dts: imx: remove obsoleted property fsl,spi-num-chipselectsVladimir Zapolskiy
Since commit b36581df7e78 ("spi: imx: Using existing properties for chipselects") the device tree property 'fsl,spi-num-chipselects' is unused and it is already marked as obsolete in device tree binding documentation. Remove the property from the existing DTS files to avoid its reoccurence on copying. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-03-30ARM: dts: imx6dl-aristainetos: enable backlight PWM explicitlyPhilipp Zabel
All PWM users should explicitly enable the used PWMs in their device tree so they can be disabled by default in imx6qdl.dtsi. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-07-18ARM: dts: imx6: add aristainetos board supportHeiko Schocher
This patch add support for the imx6dl based aristainetos board with following configuration: CPU: Freescale i.MX6DL rev1.1 at 792 MHz DRAM: 1 GiB NAND: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 SF: Detected N25Q128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB As this board can used with 2 different display types, the differences between them are extracted into 2 DTS files, and the common settings are collected in a common file. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
