Pass the memory unit-adress to fix the following build warnings with W=1:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
There are cases where dts passes an empty memory node, which will be filled
by the bootloader. Passing the memory base address still allows the
bootloader to fill the memory size.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-By: Lothar Waßmann <LW@KARO-electronics.de>
(cherry picked from commit edc05819786fd5eee330b89bd5892dad1199effc)
arch/arm/boot/dts/imx6dl-colibri-eval-v3.dts
arch/arm/boot/dts/imx6dl-dfi-fs700-m60.dts
arch/arm/boot/dts/imx6dl-ts4900.dts
arch/arm/boot/dts/imx6dl-ts7970.dts
arch/arm/boot/dts/imx6q-dfi-fs700-m60.dts
arch/arm/boot/dts/imx6q-h100.dts
arch/arm/boot/dts/imx6q-novena.dts
arch/arm/boot/dts/imx6q-ts4900.dts
arch/arm/boot/dts/imx6q-ts7970.dts
arch/arm/boot/dts/imx6q-zii-rdu2.dts
arch/arm/boot/dts/imx6qdl-apalis.dtsi
arch/arm/boot/dts/imx6qdl-cubox-i.dtsi
arch/arm/boot/dts/imx6qdl-hummingboard.dtsi
arch/arm/boot/dts/imx6qdl-hummingboard2.dtsi
arch/arm/boot/dts/imx6qp-zii-rdu2.dts
arch/arm/boot/dts/imx6ul-tx6ul.dtsi
arch/arm/boot/dts/imx6ull-colibri-nonwifi.dtsi
arch/arm/boot/dts/imx6ull-colibri-wifi.dtsi
