path: root/arch/arm/boot/dts/imx6dl-icore.dts
2018-09-03ARM: dts: imx: Switch Engicam boards to use SPDX identifierJagan Teki
Adopt the SPDX license identifier headers to ease license compliance management. Also added Engicam Copyright on missing files. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-10-13ARM: dts: imx6dl-icore: Add touchscreen nodeJagan Teki
max11801 touchscreen on Engicam iCoreM6 DualLite/Solo module is connected via i2c1, so add max11801: touchscreen@48 on i2c1. Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-01-10ARM: dts: imx/vf: Correct license textAlexandre Belloni
The license text has been mangled at some point then copy pasted across multiple files. Restore it to what it should be. Note that this is not intended as a license change. Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com> Acked-by: Michael Trimarchi <michael@amarulasolutions.com> Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-11-01ARM: dts: imx6q: Add Engicam i.CoreM6 DualLite/Solo initial supportJagan Teki
i.CoreM6 DualLite/Solo modules are system on module solutions manufactured by Engicam with following characteristics: CPU NXP i.MX6 DL, 800MHz RAM 1GB, 32, 64 bit, DDR3-800/1066 NAND SLC,512MB Power supply Single 5V MAX LCD RES FULLHD and more info at http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
