path: root/arch/arm/boot/dts/imx6dl-riotboard.dts
2019-02-12MLK-11431-4: ARM: DTS: imx: Update IPU and display propertySandor Yu
Update IPU and display property, make sure these dts files can pass build. Signed-off-by: Sandor Yu <R01008@freescale.com>
2017-07-25ARM: dts: imx6: RIoTboard provide gpio-line-namesOleksij Rempel
gpio-line-names may help to make work with GPIOs from user space easier. Following examples are provided with libgpiod https://github.com/brgl/libgpiod : |# Toggle a GPIO by name, then wait for the user to press ENTER. |$ gpioset --mode=wait `gpiofind "USR-LED-2"`=1 |# Pause execution until a single event of any type occurs. Don't print |# anything. Find the line by name. |$ gpiomon --num-events=1 --silent `gpiofind "USR-IN"` Used names was taken from RIoTboard schematics, version 1 (2013.12.07). Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2017-06-05ARM: dts: imx: Fix Ethernet PHY reset polarityFabio Estevam
The FEC driver ignores the GPIO polarity from 'phy-reset-gpios' and considers that the Ethernet PHY is active low, unless the property 'phy-reset-active-high' is present. Fix the device tree description by explicitly passing the 'GPIO_ACTIVE_LOW' flag to the 'phy-reset-gpios' property. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-11-02ARM: dts: imx: Fix "ERROR: code indent should use tabs where possible"Jagan Teki
Fixed code indent tabs in respetcive imx23, imx51, imx53, imx6dl, imx6q and imx6sx dtsi and dts files. Signed-off-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-08-09ARM: dts: imx6qdl: don't configure reserved pad settingsUwe Kleine-König
Several dts files set a bit in the SPEED field for pads RGMII_{R,T}{XC,D0,D1,D2,D3,X_CTL}, but that doesn't exist. Writing there doesn't have an effect and the bit reads as zero. Signed-off-by: Uwe Kleine-König <uwe@kleine-koenig.org> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-06-11ARM: dts: imx6: tag boards that have the HW workaround for ERR006687Lucas Stach
Add the DT property to all boards that have the hardware workaround for erratum ERR006687 present. This allows the CPUidle driver to use the deep idle states, even if the FEC is active. Signed-off-by: Lucas Stach <l.stach@pengutronix.de> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-04-27ARM: dts: imx6: Do not hardcode the CLKO clockFabio Estevam
Using "IMX6QDL_CLK_CKO" for the clock is easier to read instead of the hardcoded clock number. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-07-24dts: imx6: fix sd card gpio polarity specified in device treeDong Aisheng
cd-gpios polarity should be changed to GPIO_ACTIVE_LOW and wp-gpios should be changed to GPIO_ACTIVE_HIGH. Otherwise, the SD may not work properly due to wrong polarity inversion specified in DT after switch to common parsing function mmc_of_parse(). Signed-off-by: Dong Aisheng <aisheng.dong@freescale.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2014-07-18ARM: dts: imx6: RIoTboard explicitly define pad settingsIain Paton
Instead of relying on defaults or bootloader settings, explicitly define all pad settings. This resolves reported issues of no analogue audio output. Signed-off-by: Iain Paton <ipaton0@gmail.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-07-18ARM: dts: imx: remove ssi fsl,mode for audio cardsMarkus Pargmann
The DAI mode is and should be configured by the sound card driver as codec and ssi have to be in the right modes to communicate with each other. It is possible to operate the ssi unit or the codec in master mode, sometimes even on the same board in different configurations. With the latest changes in the fsl-ssi driver, the 'fsl,mode' property is only handled as a fallback property. If the sound card sets the DAI mode correctly, this fallback configuration is dropped. Signed-off-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-05-16ARM: dts: imx6: add new board RIoTboardIain Paton
add element14s RIoTboard http://www.riotboard.org which is an i.MX6Solo based design targeted at makers. Signed-off-by: Iain Paton<ipaton0@gmail.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
