Fixes: commit: 5d2a26667010640e33ca0a52c73310f158179711
This commit unifys the backlight settings. All displays sold by Toradex
are now supporting 150Hz as a PWM backlight typical frequency.
Use this value for all SoM's and put also some better default values
for different brightness.
Further clean-up Apalis iMX6 device trees.
In 4.14 devicetress are based on the mainline DT's and only necessary
stuff for downstream is put into those devicetrees.
This commit holds the changes for imx6*(colibri|apalis)* from 4.9.
Those devices are used in conjunction with Toradex's carrier boards.
This commit adds the touchscreens from Toradex so one can enable it.
The pinctrl properties on the IOMUXC node get overwritten by the
carrier board level device tree, hence the pinctrl_reset_moci
pinctrl does not get applied.
Associate the pinctrl_reset_moci pinctrl with the PCIe node where
we also make use of the pin as a reset GPIO.
Since the pin is muxed as a GPIO by default not muxing it explicitly
worked fine in practise.
Signed-off-by: Stefan Agner <stefan@agner.ch>
(cherry picked from commit 78f10734f95873c22255f536e894c704bb5e8fa2)
Add Apalis UART1 as default serial console.
(cherry picked from commit 6c74366b8db6fc70b65266bf52c58a89ebc946f1)
All Toradex Carrier Boards use a st,m41t0 compatible RTC. Compared
to a st,m41t00 this RTC has also an oscillator fail bit which allows
to detect when the RTC lost track of time.
Cc: Sanchayan Maity <maitysanchayan@gmail.com>
Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
(cherry picked from commit c53bec16b150a84f6b5395af1bc45335293d3c64)
Add support for the Toradex Ixora V1.1 carrier board.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
