Leave pca953x P06,P07 pins on b850v3 platform and P06 pin on
b450v3/b650v3 unconfigured in the kernel space since they could be
configured as DP1_RST and DP2_RST by the applications for the DP FW
update support.
Signed-off-by: Ken Lin <ken.lin@advantech.com>
The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com>
Acked-by: Michael Trimarchi <michael@amarulasolutions.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Calibrate the USB PHY TX settings to pass the eye diagram signal
integrity test. The settings are taken from the i.MX6 reference
manual's recommended configuration for USB certification (66.2.6).
Signed-off-by: Jaret Cantu <jaret.cantu@timesys.com>
At power on, pca953x GPIO pins are configured as input and may cause
unexpected interrupts. Configure the unused pins as GPO low to
avoid unexpected interrupts.
Signed-off-by: Ken Lin <ken.lin@advantech.com.tw>
Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
Previously the LDB_DIx clocks could be specified in the ldb node. With
the ERR009219 errata fix applied, the ldb_di clocks now needs to be
specified in the clks node to ensure the clocks are setup early in the
boot process.
Add support for Advantech/GE B650v3 board.
