path: root/arch/arm/boot/dts/imx6q-cm-fx6.dts
2014-02-09ARM: dts: Add initial support for cm-fx6.Valentin Raevsky
Add initial support for cm-fx6 module. cm-fx6 is a module based on mx6q SoC with the following features: - Up to 4GB of DDR3 - 1 LCD/DVI output port - 1 HDMI output port - 2 LVDS LCD ports - Gigabit Ethernet - Analog Audio - CAN - SATA - NAND - PCIE This patch allows to boot up the module, configures the serial console, the Ethernet adapter and the heartbeat led. cm-fx6 is embedded inside the Utilite computer. Signed-off-by: Valentin Raevsky <valentin@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
